中断有关设置如下:
void Isr_Init(void)
unsigned int cc;
pISR_UNDEF = (unsigned)HaltUndef;
pISR_SWI = (unsigned)HaltSwi;
pISR_PABORT = (unsigned)HaltPabort;
pISR_DABORT = (unsigned)HaltDabort;
for (cc = _RAM_STARTADDRESS;cc < (_RAM_STARTADDRESS + 0x30);cc += 4)
*((volatile unsigned *)cc) = 0xEA000000 + ((unsigned int)Image$$RO$$Base - 0x0c000000 - 8) / 4;
//rINTCON=0x1; // Vectored Int. IRQ enable,FIQ disable
rINTCON = 0x5; // Non-vectored,IRQ enable,FIQ disable
rINTMOD = 0x0; // All=IRQ mode
//rINTMSK |= BIT_GLOBAL | BIT_EINT4567 ; // All interrupt is masked.
rINTMSK &= ~( BIT_GLOBAL | BIT_EINT4567| BIT_TIMER0 | BIT_TIMER1 |BIT_TIMER2 |BIT_TIMER3 );
rINTCON = 0x5;时可以进行 time0 time1等中断,串口也可打印中断信息,但如果换成 rINTCON = 0x1;设置为向量中断,则进入仿真时程序马上跑飞,
axd只能进行非向量中断,不能进行向量中断 是不是这个原因?请高手指教。
我用的是s3c44b0,ads1.2编译,H-jtag。 |
