module top(
output [18:0] m_addr, // Memory address
output m_nce, // memory chip enable
output m_noe, // memory output enable
output m_nwe, // memory write enable
output [1:0] wstate, // only for simulation
output i0_read_le, // latch enable when reading
output i1_vga_le, // vga latch enable
output i2_mem_be, // buffer enable for memory write cycle
input in_clk, // input clock, two times desired pixel clock
input in_pixel_en, // clock enable, pixel clock will be active when this signal is 1
input in_dataw, // data write signal
input in_datar, // data read signal
input [7:0] in_data // data bus from propeller
parameter MEM_AWIDTH = 19;
parameter MEM_DWIDTH = 8;
parameter MAX_PIXELS = 11'b01010110000;
reg [MEM_AWIDTH-1:0] r_pixel_counter;
reg [MEM_AWIDTH-1:0] r_memory_ptr;
reg clk_pixel;
reg [1:0] r_wstate, r_nwstate;
reg [1:0] r_rstate, r_nrstate; // not needed
reg r_pixel_en;
reg [1:0] r_ridx;
reg r_mem_noe;
reg r_mem_nwe;
wire w_video_noe;
wire clk_mem = ~clk_pixel;
wire w_cmd_write = in_datar & in_dataw; // command write when both are asserted
wire w_dataw = in_dataw & (in_dataw ^ in_datar); // internal write signal
wire w_datar = in_datar & (in_dataw ^ in_datar); // internal read signal
assign wstate = r_wstate;
// every other clock we refresh the display if needed
always @ (posedge in_clk)
begin
clk_pixel <= ~clk_pixel;
if (in_pixel_en == 0) begin
r_pixel_en <= 0;
end else begin
r_pixel_en <= 1;
end
end
// Command write on the rising edge
always @ (posedge w_cmd_write)
begin
r_ridx [1:0] <= in_data[1:0];
end
// Value write to the right register on the falling edge
always @ (negedge w_cmd_write)
begin
case (r_ridx[1:0])
2'b00: r_memory_ptr[7:0] = in_data;
2'b01: r_memory_ptr[15:8] = in_data;
2'b10: r_memory_ptr[MEM_AWIDTH-1:16] = in_data[MEM_AWIDTH-17:0];
//2'b11: r_memory_ptr[MEM_AWIDTH-1:16] = in_data[MEM_AWIDTH-17:0]; // we do the same...
endcase
end
// Increments pointer
always @ (posedge clk_mem)
begin
if (r_pixel_counter[18:8] == MAX_PIXELS)
r_pixel_counter = 0;
if (r_pixel_en == 1)
r_pixel_counter = r_pixel_counter + 1;
end
// CPLD <-> Propeller comm
// Write
always @(*)
begin
r_nwstate = 0;
r_mem_nwe = (r_wstate == 2) ? 0:1;
if (r_wstate == 0)
if (w_dataw) r_nwstate = 1; // changes state when w_dataw goes high
if (r_wstate == 1)
if (clk_mem) r_nwstate = 2; // changes state when memory cycle is active
else r_nwstate = 1; // keep current state
if (r_wstate == 2)
if (clk_mem) r_nwstate = 2; // keeps current state
end
r_wstate <= r_nwstate;
always @(*)
begin
r_nrstate = 0;
r_mem_noe = (r_rstate == 2) ? 0:1;
if (r_rstate == 0)
if (w_datar) r_nrstate = 1; // changes state when w_dataw goes high
if (r_rstate == 1)
if (clk_mem) r_nrstate = 2; // changes state when memory cycle is active
else r_nrstate = 1; // keep current state
if (r_rstate == 2)
if (clk_mem) r_nrstate = 2; // keeps current state
end
r_rstate <= r_nrstate;
// Memory interface
assign w_video_noe = ~(clk_pixel & r_pixel_en);
assign m_addr = (w_video_noe == 0) ? r_pixel_counter:r_memory_ptr;
assign m_nce = r_mem_nwe & r_mem_noe & w_video_noe;
assign m_noe = r_mem_noe & w_video_noe;
assign m_nwe = r_mem_nwe;
assign i0_read_le = r_mem_noe;
assign i1_vga_le = w_video_noe;
assign i2_mem_be = !r_mem_nwe;
initial
begin
clk_pixel = 0;
r_wstate = 0;
r_nwstate = 0;
//r_mem_noe = 1;
//r_mem_nwe = 1;
end
endmodule
The text code for the propeller is shown below
' VGA driver by Chip Gracey (c) 2006 Parallax Inc.
' CPLD code by me (c) 2009 Pacito.Sys
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VGASYNCPINS = 8
VGACLK = 27
VGAPIXEN = 26
DATAR = 25
DATAW = 24
hp = 640 'horizontal pixels
vp = 240 'vertical pixels
hf = 24 'horizontal front porch pixels
hs = 40 'horizontal sync pixels
hb = 128 'horizontal back porch pixels
vf = 9 'vertical front porch lines
vs = 3 'vertical sync lines
vb = 28 'vertical back porch lines
hn = 1 'horizontal normal sync state (0|1)
vn = 1 'vertical normal sync state (0|1)
pr = 25 'pixel rate in MHz at 80MHz system clock (5MHz granularity)
' Tiles
xtiles = hp / 32
ytiles = vp / 32
' H/V inactive states
hv_inactive = (hn << 1 + vn) * $0101
OBJ
term : "FullDuplexSerial"
VAR
byte buffer[16]
PUB start
cognew(@vgasync, 0) ' starts VGA subsystem
cognew(@memctrl, @buffer)
term.start(31, 30, 0, 115200)
term.str(string("Test, new run...", 13))
term.hex(buffer[0], 2)
term.hex(buffer[1], 2)
term.hex(buffer[2], 2)
term.hex(buffer[3], 2)
term.tx(13)
DAT
{ This COG generates the synchronismus signals needed for VGA refresh
the clock signal and the pixel enable signals
org 0
memctrl mov DIRA, c6_cnt_dira
mov c6_v_buff, PAR
mov c6_v_addr, #511
mov c6_v_data0, #$00
call #c6_writedata
mov c6_v_data0, #$ff
mov c6_v_addr, #1
call #c6_writedata
mov c6_v_addr, #511
mov c6_v_data0, #$77
call #c6_writedata
mov c6_v_addr, #51
call #c6_writedata
mov c6_v_addr, #511
call #c6_readdata
wrbyte c6_v_data0, c6_v_buff
add c6_v_buff, #1
wrbyte c6_v_data1, c6_v_buff
add c6_v_buff, #1
wrbyte c6_v_data2, c6_v_buff
add c6_v_buff, #1
wrbyte c6_v_data3, c6_v_buff
add c6_v_buff, #1
jmp #$
c6_writeaddr or DIRA, #$ff
mov OUTA, c6_cnt_reg0
mov OUTA, c6_v_addr
mov OUTA, c6_cnt_reg1
shr c6_v_addr, #8
mov OUTA, c6_v_addr
mov OUTA, c6_cnt_reg2
shr c6_v_addr, #8
mov OUTA, c6_v_addr
andn DIRA, #$ff
c6_writeaddr_ret ret
c6_writedata call #c6_writeaddr
or DIRA, #$ff
mov OUTA, c6_v_data0
or OUTA, c6_cnt_dataw
andn DIRA, #$ff ' data has been latched
andn OUTA, c6_cnt_dataw
c6_writedata_ret ret
c6_readdata call #c6_writeaddr
or OUTA, c6_cnt_datar
andn OUTA, c6_cnt_datar
mov c6_v_data0, INA
mov c6_v_data1, INA
mov c6_v_data2, INA
mov c6_v_data3, INA
'andn OUTA, c6_cnt_datar
c6_readdata_ret ret
c6_cnt_cmdw
c6_cnt_reg0 long (1<<DATAR)|(1<<DATAW)
c6_cnt_reg1 long (1<<DATAR)|(1<<DATAW)|1
c6_cnt_reg2 long (1<<DATAR)|(1<<DATAW)|2
c6_cnt_pe long (1<<VGAPIXEN)
c6_cnt_dataw long (1<<DATAW)
c6_cnt_datar long (1<<DATAR)
c6_cnt_dira long (1<<DATAR)|(1<<DATAW)|(1<<VGAPIXEN)
c6_v_addr long 0
c6_v_buff long 0
c6_v_data0 long 0
c6_v_data1 long 0
c6_v_data2 long 0
c6_v_data3 long 0
DAT
org 0
vgasync mov DIRA, c7_cnt_dira
movi ctra, #%00001_101 'enable PLL in ctra (VCO runs at 4x)
movi frqa, #(pr / 5) << 3 'set pixel rate
mov ctrb, #VGACLK ' clock output
movi ctrb, #%00010_110 ' PLL 2 times pixel rate
movi frqb, #(pr / 5) << 3 'set pixel rate
mov vcfg,reg_vcfg 'set video configuration
' Main loop, display field and do invisible sync lines
field mov color_ptr,color_base 'reset color pointer
mov pixel_ptr,pixel_base 'reset pixel pointer
mov y,#ytiles 'set y tiles
:ytile mov yl,#32 'set y lines per tile
:yline mov yx,#2 'set y expansion
:yexpand mov x,#xtiles 'set x tiles
mov vscl,vscl_pixel 'set pixel vscl
:xtile rdword color,#0 'get color word
mov color,hv 'set h/v inactive states
rdlong pixel,#0 'get pixel long
waitvid color,#0 'pass colors and pixels to video
djnz x,#:xtile 'another x tile?
mov x,#1 'do horizontal sync
call #hsync
djnz yx,#:yexpand 'y expand?
djnz yl,#:yline 'another y line in same tile?
djnz y,#:ytile 'another y tile?
'wrlong colormask,par 'visible done, write non-0 to sync
mov x,#vf 'do vertical front porch lines
call #blank
mov x,#vs 'do vertical sync lines
call #vsync
mov x,#vb 'do vertical back porch lines
call #vsync
jmp #field 'field done, loop
' Subroutine - do blank lines
vsync xor hvsync,#$101 'flip vertical sync bits
blank mov vscl,hvis 'do blank pixels
waitvid hvsync,#0
hsync mov vscl,#hf 'do horizontal front porch pixels
waitvid hvsync,#0
mov vscl,#hs 'do horizontal sync pixels
waitvid hvsync,#1
mov vscl,#hb 'do horizontal back porch pixels
waitvid hvsync,#0
djnz x,#blank 'another line?
hsync_ret
blank_ret
vsync_ret ret
' Data
reg_dira long 0 'set at runtime
reg_dirb long 0 'set at runtime
reg_vcfg long $200002ff 'set at runtime
color_base long 0 'set at runtime (2 contiguous longs)
pixel_base long 0 'set at runtime
vscl_pixel long 1 << 12 + 32 '1 pixel per clock and 32 pixels per set
colormask long $FCFC 'mask to isolate R,G,B bits from H,V
hvis long hp 'visible pixels per scan line
hv long hv_inactive '-H,-V states
hvsync long hv_inactive ^ $200 '+/-H,-V states
c7_cnt_dira long (1<<VGACLK)|(1<<VGAPIXEN)|(3<<VGASYNCPINS)
' Uninitialized data
color_ptr res 1
pixel_ptr res 1
color res 1
pixel res 1
x res 1
y res 1
yl res 1
yx res 1 |
