6楼
发表于 2011-1-24 12:15:23
只看该作者
破_解固件包,请参照原文使用
点击此处下载 ourdev_613132LNWL6B.rar(文件大小:6.99M) (原文件名:Tekway.rar)
固件更新为用户Tekway
This is inofficial version, it will update all Tekway DSO to firmware version 2.06.2这是非官方的版本,将更新所有Tekway DSO来固件版本2.06.2
- French/German/Chinese/English menu language supported instead of only Chinese/English - 法语/德语/中/英文菜单,而不是只支持中文/英文
- CSV export to USB (up to 40k samples only, but better than nothinig) - CSV导出到USB(最多只有40K的样品,但比没有更好)
- a bit better export menu (much easier to recognize what your saving) - 好一点的出口菜单(更容易识别你的储蓄)
- more colors for menu/submenu/background (black/green/pink/yellow/blue instead of only blue) - 为菜单/子菜单/背景(黑/绿/粉红/黄/蓝,而不是仅黑色)更多颜色
- trigger works now stable up to 300MHz (of course after hacked to 200MHz bw) - 触发的作品现在是稳定至300MHz(当然砍死后200MHz的体重)
- zoom up to 1000x - 变焦可达1000倍
This firmware update is replacing only binaries, nothing will be hacked or changed.此固件更新只替换二进制,什么都不会被攻破或改变。
How to use :如何使用:
- download attached do_firmware_Tekway_2.06.2.exe and do_firmware_Tekway_2.06.2.r00 - 下载附加do_firmware_Tekway_2.06.2.exe和do_firmware_Tekway_2.06.2.r00
(it is packed with WinRAR just because of size limit here in forum) (这是用WinRAR打包只是因为这里的大小限制在论坛)
- unrar or execute it and copy dst1kb_2.06.2_cli(101028.0).up to your USB stick and proceed with firmware update - 或执行它的unrar并复制dst1kb_2.06.2_cli(101028.0)到您的USB棒和进行固件更新。
- reboot, recalibrate your DSO - 重新启动,重新校准示波器
Generic Tekway hack 通用Tekway劈
Hack is now updated to work with any Tekway firmware versions, it will change your DSO model but it will not anylonger replace any binary files哈克现在已更新与任何Tekway固件版本,它会改变你的DSO模式,但它不会取代任何anylonger二进制文件
How to use:如何使用:
- download one of the attached version - 下载一个附加的版本
do_Tekway_DST1062B.zip - if you wish to change your DSO to DST1062B (60MHz bw) do_Tekway_DST1062B.zip - 如果你想改变你的DSO来DST1062B(60MHz的带宽)
do_Tekway_DST1102B.zip - if you wish to change your DSO to DST1102B (100MHz bw) do_Tekway_DST1102B.zip - 如果你想改变你的DSO来DST1102B(100MHz的体重)
do_Tekway_DST1202B.zip - if you wish to change your DSO to DST1202B (200MHz bw) do_Tekway_DST1202B.zip - 如果你想改变你的DSO来DST1202B(200MHz的体重)
- unzip and copy the dst1kb_9.99.9_cli(111111.0).up to your USB stick and proceed with firmware update - 解压缩并复制dst1kb_9.99.9_cli(111111.0)到您的USB棒和进行固件更新。
- reboot and recalibrate your DSO - 重新启动和重新校准示波器
Generic Hantek hack 通用Hantek劈
Hack is now updated to work with any Hantek firmware versions, it will change your DSO model but it will not anylonger replace any binary files哈克现在已更新与任何Hantek固件版本,它会改变你的DSO模式,但它不会取代任何anylonger二进制文件
How to use:如何使用:
do_Hantek_DSO5062B.zip - if you wish to change your DSO to DSO5062B (60MHz bw) do_Hantek_DSO5062B.zip - 如果你想改变你的DSO来DSO5062B(60MHz的带宽)
do_Hantek_DSO5102B.zip - if you wish to change your DSO to DSO5102B (100MHz bw) do_Hantek_DSO5102B.zip - 如果你想改变你的DSO来DSO5102B(100MHz的体重)
do_Hantek_DSO5202B.zip - if you wish to change your DSO to DSO5202B (200MHz bw) do_Hantek_DSO5202B.zip - 如果你想改变你的DSO来DSO5202B(200MHz的体重)
I don't have DSO5062B and DSO5202B boot screen logos, so your DSO will always show during boot DSO5102B.我没有DSO5062B和DSO5202B开机画面标志,所以你的DSO将始终显示在启动DSO5102B。
If you have such logos please let me know.如果你有搜查标志,请让我知道。 If you wish to change the DSO5102 logos (see attached hantek_logo.zip content)如果你想改变DSO5102标识(见附件hantek_logo.zip内容)
to "proper" name, then do it and send them back to me (so i will update again this hack).以“适当”的名字,然后执行它并发送回给我(所以我会再次更新这个技巧)。
I would do it, but i prefer to spend my time on other things我会做,但我更喜欢把钱花在其他东西我的时间
I got the proper logos for DSO5102B and DSO5202B, for DSO5062B is did my own.我得到了DSO5102B和DSO5202B适当的标志,也为我自己是DSO5062B。 Generic hacks in below updated now.在下面的通用破_解更新了。
Firmware Dump utility 固件转储实用工具
as already posted here:正如已经张贴在这里:
http://www.eevblog.com/forum/index.php?topic=1571.msg23807#msg23807 http://www.eevblog.com/forum/index.php?topic=1571.msg23807#msg23807
this tool has been again updated此工具已再次更新
Firmware Update Counter Reset 固件更新计数器复位
This tool will reset fw-update and DSO-usage counter to 0 on your Hantek/Tekway DSO.这个工具将重置固件更新和DSO使用率柜台上的Hantek / Tekway DSO的0。
How to use:如何使用:
- download attached do_ResetUpdateCounter.zip - 下载附加do_ResetUpdateCounter.zip
NOTE: This tool is deleting sys.inf from your DSO root file system. All currently known firmware versions are re-creating this file during reboot,注意:此工具删除从根文件系统sys.inf DSO的所有目前已知的固件版本是重新创建此文件时重新启动,
however be warrned that i'm not responsible for any modifications done by you.不过需要warrned,我不是为你做任何修改的责任。
ALL Hacks/tools has been tested on both Tekway and Hantek DSOs (DST1xxxB series and DSO5xxxB series) with all currently known 所有黑客/工具进行了测试和数字存储示波器都Tekway Hantek(DST1xxxB DSO5xxxB系列和系列)与目前已知的所有
firmware versions, however i'm still not responsible for any resulting issues (warranty, bricked DSO, whatever). 固件版本,但我还是不负责由此造成的问题(保修,砖砌示波器,等等)。
If you brick your DSO with one of in above posted hacks/tools you will still be able to un-brick it via JTAG.如果你的砖以上一张贴在黑客的DSO /工具,你仍然可以向联合国砖通过JTAG它。 "ARM JTAG cable for H-JTAG" “ARM的JTAG电缆的H - JTAG的”
costs 10$, eg ebay item 300453556955费为10美元,如易趣项目300 453 556 955
If you don't want to play with JTAG and wish to unbrick your DSO, unsolder the NAND memory (K9F1208xxx) and send it to如果你不想玩,你的JTAG希望unbrick示波器,未售出的NAND记忆体(K9F1208xxx)并将其发送到
me (i'm located in Europe ...), i can definitely reprogram the NAND with working firmware (however you will have to know how我(我是位于欧洲...),我可以肯定地重新编程,有工作的固件(但你必须知道如何在NAND
to unsolder/solder such IC).对未售出/焊点测试集成电路)。 A empty NAND will not work, there is some factory calibration data stored, so it is always recommended to have a original firmware backup (created via JTAG/UART or with the "Firmware Dump utility" hack/tool)一个NAND空将不能正常工作,有一些工厂校准数据存储,因此它总是建议有一个备份原始固件(通过JTAG / UART或与“固件转储实用程序”黑客/工具创建) |
