发表于 2011-1-22 11:14:03
回复【1楼】JinBao
回复【2楼】armok 阿莫
多谢两位。
这个问题已解决。原因是我用笔记本,试了JinBao提供的下面的信息,将笔记本设成标准PC后,电机速度曾变得正常一次,但重起笔记本后,仍有相同问题。在artSoft的讨论区也看到了相同的问题,用上面的方法解决了,但在我的机器上不行。最后,我只能改到我的desktop机上。好象是正常了。我的桌面PC是3GHz CPU,不必改动设置,装上直接用。
******** NOte ****************************
(The following step shoudl not be done unless all else fails. It is usually only necessary
for laptops that vary their frequency badly, and sometimes fails to help. So skip this unless
everythign else fails to fix any trouble )!!!!!!!!!!!!!!!!!!!!!!!!!
9. Set Computer to Standard PC NOT ACPI PC
NOTE: This is only necessary if you wish to remove ACPI AFTER install.
If you followed step 0, you don't need to do this.
1. Right Click My Computer and select Properties
2. Click Hardware tab.
3. Click Device Manager Button in the middle.
4. Double click "Computer".
5. Right click on Standard ACPI PC and choose Update Driver.
6. Choose "Install the software from a Specific Location (Advanced)"
7. Click Next.
8. Choose "Don't search. I will choose driver to install."
9. Click Next.
10. Choose "Standard PC" from the listing.
11. Click Next.
12. Click OK.
