// MSP-FET430P140 Demo - Timer_A0, Capture of ACLK/8 using SMCLK
// Description: Input capture of ACLK/8 on P1.1(TA0)
// Run to breakpoint at the _NOP() instruction to see 16 capture
// values and the differences.
// ACLK = 32768Hz, MCLK = SMCLK = default ~800kHz
// //* An external watch crystal on XIN XOUT is required for ACLK *//
// MSP430F149
// /|\| XIN|-
// | | | 32kHz
// --|RST XOUT|-
// | P2.0/ACLK|---+
// | P1.1/TA0|<--+
// | P1.0|--->LED
// H. Grewal
// Texas Instruments Inc.
// Feb 2005
// Built with IAR Embedded Workbench Version: 3.21A
#include <msp430x14x.h>
unsigned int new_cap=0;
unsigned int old_cap=0;
unsigned int cap_diff=0;
unsigned int diff_array[16]; // RAM array for differences
unsigned int capture_array[16]; // RAM array for captures
unsigned char index=0;
unsigned char count = 0;
volatile unsigned int i;
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
for (i=0; i<20000; i++) // Delay for crystal stabilization
P1DIR = 0x01; // Set P1.0 out,1.1 input dir
P1OUT &= ~0x01; // LED off
P1SEL = 0x02; // Set P1.1 to TA0
P2DIR = 0x01; // P2.0-ACLK
P2SEL |= 0x01;
BCSCTL1 |= DIVA_3; // ACLK/8
CCTL0 = CM_1 + SCS + CCIS_0 + CAP + CCIE; // Rising edge + CCI0A (P1.1)
// + Capture Mode + Interrupt
TACTL = TASSEL_2 + MC_2; // SMCLK + Continuous Mode
_BIS_SR(LPM0_bits + GIE); // LPM0 + Enable global ints
#pragma vector=TIMERA0_VECTOR
__interrupt void TimerA0(void)
new_cap = TACCR0;
cap_diff = new_cap - old_cap;
diff_array[index] = cap_diff; // record difference to RAM array
capture_array[index++] = new_cap;
if (index == 16)
index = 0;
P1OUT ^= 0x01; // Toggle P1.0 using exclusive-OR
old_cap = new_cap; // store this capture value
count ++;
if (count == 32)
count = 0;
_NOP(); // SET BREAKPOINT HERE
今天做了这个捕捉模式的程序,使用BCSCTL1 |= DIVA_3;时,计算出来的频率是对的,是4096Hz。但我改成BCSCTL1 |= DIVA_0,就不对了,后来我打开高频晶振,主时钟MCLK设置成8MHz或者4MHz时,计算出的频率是对的,但设置成2Mhz或1Mhz时还是不对。这是为什么呢,定时器用的是子时钟SMCLK,为什么非要开主时钟呢?
请高手帮帮我,解释一下 |
