发表于 2014-10-10 14:21:38
请教楼主,CodeBlocks中使用SDCC编译楼主的代码,无法生成目标文件 ihx。编译结果如下:没有错误和警告,最后两行是红色的是怎么回事?
-------------- Build: Release in test (compiler: Small Device C Compiler)---------------
sdcc.exe -L"C:\Program Files\SDCC2.9.0\lib" -o bin\Release\test.ihx -mmcs51 --model-medium --opt-code-size --out-fmt-ihx --no-pack-iram --xstack --xram-size 4096 --iram-size 256 --code-size 65536 --out-fmt-ihx obj\Release\main.o
at 1: warning 119: don't know what to do with file 'obj\Release\main.o'. file extension unsupported
SDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.9.0 #5416 (Mar 22 2009) (MINGW32)
Usage : sdcc [options] filename
Options :-
General options:
--help Display this help
-v --version Display sdcc's version
--verbose Trace calls to the preprocessor, assembler, and linker
-V Execute verbosely. Show sub commands as they are run
-d
-D Define macro as in -Dmacro
-I Add to the include (*.h) path, as in -Ipath
-A
-U
-M Preprocessor option
-W Pass through options to the pre-processor (p), assembler (a) or linker (l)
-S Compile only; do not assemble or link
-c --compile-only Compile and assemble, but do not link
-E --preprocessonly Preprocess only, do not compile
--c1mode Act in c1 mode. The standard input is preprocessed code, the output is assembly code.
-o Place the output into the given path resp. file
--print-search-dirs display the directories in the compiler's search path
--vc messages are compatible with Micro$oft visual studio
--use-stdout send errors to stdout instead of stderr
--nostdlib Do not include the standard library directory in the search path
--nostdinc Do not include the standard include directory in the search path
--less-pedantic Disable some of the more pedantic warnings
--disable-warning <nnnn> Disable specific warning
--Werror Treat the warnings as errors
--debug Enable debugging symbol output
--cyclomatic Display complexity of compiled functions
--std-c89 Use C89 standard only
--std-sdcc89 Use C89 standard with SDCC extensions (default)
--std-c99 Use C99 standard only (incomplete)
--std-sdcc99 Use C99 standard with SDCC extensions (incomplete)
--fdollars-in-identifiers Permit '$' as an identifier character
--funsigned-char Make "char" unsigned by default
Code generation options:
-m Set the port to use e.g. -mz80.
-p Select port specific processor e.g. -mpic14 -p16f84
--model-large external data space is used
--model-medium external paged data space is used
--model-small internal data space is used (default)
--stack-auto Stack automatic variables
--xstack Use external stack
--int-long-reent Use reentrant calls on the int and long support functions
--float-reent Use reentrant calls on the float support functions
--main-return Issue a return after main()
--xram-movc Use movc instead of movx to read xram (xdata)
--callee-saves <func[,func,...]> Cause the called function to save registers insted of the caller
--profile On supported ports, generate extra profiling information
--fommit-frame-pointer Leave out the frame pointer.
--all-callee-saves callee will always save registers used
--stack-probe insert call to function __stack_probe at each function prologue
--no-xinit-opt don't memcpy initialized xram from code
--no-c-code-in-asm don't include c-code as comments in the asm file
--no-peep-comments don't include peephole optimizer comments
--fverbose-asm include code generator comments
--short-is-8bits Make short 8 bits (for old times sake)
--codeseg <name> use this name for the code segment
--constseg <name> use this name for the const segment
Optimization options:
--nooverlay Disable overlaying leaf function auto variables
--nogcse Disable the GCSE optimisation
--nolabelopt Disable label optimisation
--noinvariant Disable optimisation of invariants
--noinduction Disable loop variable induction
--nojtbound Don't generate boundary check for jump tables
--noloopreverse Disable the loop reverse optimisation
--no-peep Disable the peephole assembly file optimisation
--no-reg-params On some ports, disable passing some parameters in registers
--peep-asm Enable peephole optimization on inline assembly
--peep-file <file> use this extra peephole file
--opt-code-speed Optimize for code speed rather than size
--opt-code-size Optimize for code size rather than speed
Internal debugging options:
--dumpraw Dump the internal structure after the initial parse
--dumpgcse
--dumploop
--dumpdeadcode
--dumpliverange
--dumpregpack
--dumpregassign
--dumptree dump front-end AST before generating iCode
--dumpall Dump the internal structure at all stages
--i-code-in-asm include i-code as comments in the asm file
Linker options:
-l Include the given library in the link
-L Add the next field to the library search path
--lib-path <path> use this path to search for libraries
--out-fmt-ihx Output in Intel hex format
--out-fmt-s19 Output in S19 hex format
--xram-loc <nnnn> External Ram start location
--xram-size <nnnn> External Ram size
--iram-size <nnnn> Internal Ram size
--xstack-loc <nnnn> External Stack start location
--code-loc <nnnn> Code Segment Location
--code-size <nnnn> Code Segment size
--stack-loc <nnnn> Stack pointer initial value
--data-loc <nnnn> Direct data start location
--idata-loc
Special options for the mcs51 port:
--stack-size Tells the linker to allocate this space for stack
--parms-in-bank1 use Bank1 for parameter passing
--pack-iram Tells the linker to pack variables in internal ram (default)
--no-pack-iram Tells the linker not to pack variables in internal ram
--acall-ajmp Use acall/ajmp instead of lcall/ljmp
Special options for the gbz80 port:
-bo <num> use code bank <num>
-ba <num> use data bank <num>
--callee-saves-bc Force a called function to always save BC
--no-std-crt0 For the z80/gbz80 do not link default crt0.o
Special options for the z80 port:
--portmode= Determine PORT I/O mode (z80/z180)
--asm= Define assembler name (rgbds/asxxxx/isas/z80asm)
Special options for the ds390 port:
--model-flat24 use the flat24 model for the ds390 (default)
--stack-8bit use the 8bit stack for the ds390 (not supported yet)
--stack-10bit use the 10bit stack for ds390 (default)
--use-accelerator generate code for ds390 arithmetic accelerator
--protect-sp-update will disable interrupts during ESP:SP updates
Special options for the pic16 port:
--pstack-model= use stack model 'small' (default) or 'large'
-y --extended enable Extended Instruction Set/Literal Offset Addressing mode
--pno-banksel do not generate BANKSEL assembler directives
--obanksel= set banksel optimization level (default=0 no)
--denable-peeps explicit enable of peepholes
--no-optimize-goto do NOT use (conditional) BRA instead of GOTO
--optimize-cmp try to optimize some compares
--optimize-df thoroughly analyze data flow (memory and time intensive!)
--asm= Use alternative assembler
--mplab-comp enable compatibility mode for MPLAB utilities (MPASM/MPLINK)
--link= Use alternative linker
--preplace-udata-with= Place udata variables at another section: udata_acs, udata_ovr, udata_shr
--ivt-loc= Set address of interrupt vector table.
--nodefaultlibs do not link default libraries when linking
--use-crt= use <crt-o> run-time initialization module
--no-crt do not link any default run-time initialization module
--debug-xtra show more debug info in assembly output
--debug-ralloc dump register allocator debug file *.d
--pcode-verbose dump pcode related info
--calltree dump call tree in .calltree file
--gstack trace stack pointer push/pop to overflow
Special options for the pic14 port:
--no-pcode-opt disable (slightly faulty) optimization on pCode
--stack-size sets the size if the argument passing stack (default: 16, minimum: 4)
Special options for the TININative port:
--tini-libid <nnnn> LibraryID used in -mTININative
Special options for the ds400 port:
--model-flat24 use the flat24 model for the ds400 (default)
--stack-8bit use the 8bit stack for the ds400 (not supported yet)
--stack-10bit use the 10bit stack for ds400 (default)
--use-accelerator generate code for ds400 arithmetic accelerator
Special options for the hc08 port:
--out-fmt-elf Output executable in ELF format
Process terminated with status 1 (0 minute(s), 0 second(s))
0 error(s), 0 warning(s) (0 minute(s), 0 second(s)) |
