Internal Error: Sub-system: TIM, File: /quartus/db/tim/tim_manager.cpp, Line: 222
m_process_model != NULL
Stack Trace:
0x2b3f: TIM_MANAGER_IMPL::conclude_io_simulations + 0x3f (db_tim)
0x2965: TIM_MANAGER_IMPL::~TIM_MANAGER_IMPL + 0x1a5 (db_tim)
0x23b7: TIM_MANAGER_IMPL::`vector deleting destructor' + 0x7 (db_tim)
0x9d15: TIM_DB_MANAGER_IMPL::delete_timing_manager_in_memory + 0x55 (db_tim)
0x5e06: TAPI_DB_MANAGER_IMPL::delete_timing_manager_in_memory + 0xf6 (TSM_TAPI_MGR)
0x5d31: TAPI_DB_MANAGER_IMPL::delete_timing_manager_in_memory + 0x21 (TSM_TAPI_MGR)
0x6433: DBMUI_MANAGER::delete_timing_manager + 0xc3 (DB_DBMUI)
0x6cb8: DBMUI_MANAGER::clear_cached_info + 0xf8 (DB_DBMUI)
0x6fa2: DBMUI_MANAGER::on_flow_finish + 0x32 (DB_DBMUI)
0x11fb: NTFQ_NOTIFY_TARGET::dispatch_notify_msg + 0x3b (ccl_ntfq)
0x1312: NTFQ_NOTIFY_TARGET::on_ntfq_notify + 0x22 (ccl_ntfq)
0x1750: NTFQ_NOTIFY_MGR::broadcast_notify + 0x60 (ccl_ntfq)
0x1947: ntfq_broadcast_notify + 0x17 (ccl_ntfq)
0x4625: flow_reset + 0x55 (sys_flow)
0x15006: _flow_execute_custom + 0x10c6 (sys_flow)
0x15074: _flow_execute + 0x44 (sys_flow)
0x69d42: QUI_APP::on_start_flow + 0x2a2 (SYS_QUI)
0x50dea: QUI_APP::qt_metacall + 0xba (SYS_QUI)
0xdb39e: QMetaObject::metacall + 0x3e (QtCore4)
0x1c089: QApplication::event + 0x359 (QtGui4)
0xf59c2: QEventDispatcherWin32::event + 0x112 (QtCore4)
0xd5eec: QCoreApplicationPrivate::sendThroughApplicationEventFilters + 0x5c (QtCore4)
0x1a0e8: QApplicationPrivate::notify_helper + 0xb8 (QtGui4)
0x1de11: QApplication::notify + 0x11a1 (QtGui4)
0x1ce1: msg_main_thread + 0x11 (CCL_MSG)
0x7bf3: QUI_APP::metaObject + 0x5 (SYS_QGQ)
0x106f: QGQ_APP::~QGQ_APP + 0x3f (SYS_QGQ)
0x7e63: QUI_FRAME_WND::on_locate_in_design_file + 0x5 (SYS_QGQ)
0x8091: QLabel::focusNextPrevChild + 0x5 (SYS_QGQ)
0x8097: QObject::eventFilter + 0x5 (SYS_QGQ)
0x809d: QObject::timerEvent + 0x5 (SYS_QGQ)
0x80a3: QObject::childEvent + 0x5 (SYS_QGQ)
0x80a9: QObject::customEvent + 0x5 (SYS_QGQ)
0x80af: QObject::connectNotify + 0x5 (SYS_QGQ)
0x7e69: QApplication::event + 0x5 (SYS_QGQ)
0x80b5: QObject::disconnectNotify + 0x5 (SYS_QGQ)
0x7e6f: QApplication::notify + 0x5 (SYS_QGQ)
0x7e75: QApplication::compressEvent + 0x5 (SYS_QGQ)
0x7e7b: QApplication::commitData + 0x5 (SYS_QGQ)
0x663f: _Dinkum_std::basic_string<char,_Dinkum_std::char_traits<char>,MEM_STL_ALLOCATOR<char> >::basic_string<char,_Dinkum_std::char_traits<char>,MEM_STL_ALLOCATOR<char> > + 0x3f (SYS_QGQ)
0x7bff: QUI_APP::qt_metacall + 0x5 (SYS_QGQ)
0x7c05: QUI_APP::exit_instance + 0x5 (SYS_QGQ)
0x7c0b: QUI_APP::get_main_window + 0x5 (SYS_QGQ)
0x7c11: QUI_APP::get_prj_ui_mgr + 0x5 (SYS_QGQ)
0x7c17: QUI_APP::process_cmdline_arguments_pre_main_wnd_create + 0x5 (SYS_QGQ)
0x7c1d: QUI_APP::process_cmdline_arguments_post_main_wnd_show + 0x5 (SYS_QGQ)
0x7c23: QUI_APP::process_cmdline_arguments_post_main_wnd_create + 0x5 (SYS_QGQ)
End-trace
Quartus II Version 10.1 Build 153 11/29/2010 SJ Full Version |
