发表于 2010-12-15 12:26:29
初始化中:
//创建接收数据的信号量
modem.rxdsem = rt_sem_create("modem_sem", 0, RT_IPC_FLAG_FIFO);
rt_device_set_rx_indicate(modem.device, _modem_rxind);
rt_err_t _modem_rxind(rt_device_t dev, rt_size_t size)
rt_sem_release(modem.rxdsem);
return RT_EOK;
//处理线程
static void _modem_rxd_thread_entry(void* parameter)
rt_device_open(modem.device, RT_DEVICE_OFLAG_RDWR);
while (1)
if (rt_sem_take(modem.rxdsem, RT_WAITING_FOREVER) != RT_EOK) continue;
/*read rx ind data*/
readcnt = rt_device_read(modem.device, 0, &buff[okindex], rxbuff_maxsize - okindex);
okindex += readcnt;
//下面是处理数据过程。。。。
okindex = 0;
读串口buffer里面的数据
static rt_size_t rt_serial_read (rt_device_t dev, rt_off_t pos, void* buffer, rt_size_t size)
rt_uint8_t* ptr;
struct serial_device* serial = (struct serial_device*)dev;
RT_ASSERT(dev != RT_NULL);
ptr = (rt_uint8_t*)buffer + pos;
if (dev->flag & RT_DEVICE_FLAG_INT_RX)
/* interrupt mode Rx */
while (size)
/* interrupt receive */
rt_base_t level;
/* disable interrupt */
level = rt_hw_interrupt_disable();
if (serial->rxd.read_index != serial->rxd.save_index)
*ptr = serial->rxd.rx_buffer[serial->rxd.read_index];
serial->rxd.read_index++;
if (serial->rxd.read_index == RT_UART_BUFFER_SIZE)
serial->rxd.read_index = 0;
/* no data in rx buffer */
/* enable interrupt */
rt_hw_interrupt_enable(level);
ptr ++; size --;
/* polling mode */
/* not support right now */
RT_ASSERT(0);
return (rt_uint32_t)ptr - ((rt_uint32_t)buffer + pos);
串口中断调用的函数
static void _rt_serial_handle_rxd(struct serial_device* serial)
rt_uint8_t Buffer[UART_FIFO_SIZE];
rt_uint8_t BufferCount;
rt_uint8_t* pBuf;
rt_uint8_t freebuffer;
rt_uint8_t receive_size;
if (serial == RT_NULL)
return;
pBuf = Buffer;
receive_size = 0;
BufferCount = Uart_ReadBytesfromFIFO(serial->uart.Port, Buffer);
if (serial->rxd.read_index <= serial->rxd.save_index)
{freebuffer = RT_UART_BUFFER_SIZE - (serial->rxd.save_index - serial->rxd.read_index) - 1;}
{freebuffer = serial->rxd.read_index - serial->rxd.save_index - 1;}
if (freebuffer == 0)
receive_size = RT_UART_BUFFER_SIZE - 1;
while (freebuffer && BufferCount)
serial->rxd.rx_buffer[serial->rxd.save_index++] = *pBuf++;
if (serial->rxd.save_index == RT_UART_BUFFER_SIZE)
serial->rxd.save_index = 0;
receive_size++;
freebuffer--;
BufferCount--;
/* invoke callback */
if (serial->parent.rx_indicate != RT_NULL)
serial->parent.rx_indicate(&serial->parent, receive_size);
还请帮忙验证一下,看问题出在哪里 |
