发表于 2010-12-13 09:46:41
``但是我让它通过了啊,但电脑不能上网,怎么解决?
debug as时不能运行的提示好几种
提示1
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
提示2
Pausing target processor: OK
Reading System ID at address 0x01002040:
ID value does not match: read 0x00000000; expected 0x5CEFDD2D
Timestamp value does not match: image on board is older than expected
Read timestamp 8:00:00 1970/01/01; expected 8:07:51 2010/12/13
The software you are downloading may not run on the system which is currently
configured into the device. Please download the correct SOF or recompile.
Restarting target processor
提示2
assertion "m_state == STATE_DEBUG" failed: file "nios2oci.cpp", line 157
Resetting and trying again: D:\altera\90\nios2eds\bin\nios2-download: line 594:
620 Hangup nios2-gdb-server --instance 0 --sidp 0x01002040 --
id 1559223597u --timestamp 1292198871u --tcpport none --write-pid ./Debug/nios2-
download.pid ./Debug/NIOSLCD.elf.srec |
