module cd16
input start ,
input clk,
input rst,
input [7:0] dat_i,
output reg e,
output reg rw,
output reg di,
output reg[7:0] dat
parameter DIV_WORK_CLOCK = 6600;//产生10kHz信号控制lcd.e,设置为100kHz时复位不灵敏
parameter DIV_WORK_CLOCK_WIDTH = 16;
//wire p_clk ;
//reg[wigth-1:0] clk_e_counter ;
reg [3:0] state ;
reg [3:0] instruction_state ;
reg [3:0] instruction_next_state ;
reg [9:0] instruction[3:0] ;
reg instruction_set ;
reg [3:0] instruction_length ;
reg [3:0] instruction_index ;
wire [9:0] action_struction ;
wire p_clk_e;//10kHz
reg[DIV_WORK_CLOCK_WIDTH-1:0] clk_e_counter;
assign action_struction = instruction[instruction_length-1-instruction_index] ;
assign p_clk_e = (clk_e_counter==0)?1'B1:1'B0;
always@(posedge clk,negedge rst,posedge instruction_set)
begin
if(rst == 0)
begin
e <= 0 ;
rw <= 0 ;
di <= 0 ;
//instruction_set <= 0 ;
state <= 0 ;
end
else if(instruction_set == 1'B1)
begin
instruction_index <= instruction_length - 1'B1 ;
end
else if(clk == 1'B1)
begin
case(state)
4'd0 :
begin
e <= 0 ;
rw <= 0 ;
di <= 0 ;
if(instruction_length > 0)
begin
state <= 4'd1 ;
end
end
4'd1:
begin
di <= action_struction[9] ;
rw <= action_struction[8] ;
dat <= action_struction[7:0] ;
state <= 4'd2 ;
end
4'd2:
begin
e <= 0 ;
if(p_clk_e == 1'b1)
begin
state <= 4'd3 ;
end
end
4'd3:
begin
e <= 1'b1 ;
if(p_clk_e == 1'b1)
begin
state <= 4'd4 ;
end
end
4'd4:
begin
e <= 0 ;
if(p_clk_e == 1'b1)
begin
if(instruction_index == 1'B0)
begin
state <= 4'd5 ;
end
begin
instruction_index <= instruction_index - 1'b1 ;
state <= 4'd1 ;
end
end
end
4'd5:
begin
if(instruction_length == 0)
state <= 4'd0 ;
end
default: state <= 4'd0 ;
endcase
end
end
always@(posedge clk,negedge rst)
begin
if(rst == 0)
begin
instruction_length <= 0 ;
instruction_state <= 4'd1 ;
end
else if(clk == 1'b1)
begin
case(instruction_state)
4'd0:
begin
if(start == 1'b1) instruction_state <= 4'd4;
end
4'd1:
begin
instruction[0] <= 10'b0000110000 ;
instruction[1] <= 10'b0000001111 ;
instruction[2] <= 10'b0000000110 ;
instruction[3] <= 10'b0000000001 ;
instruction_length <= 4 ;
instruction_set <= 1'b1 ;
instruction_next_state <= 4'd0;
instruction_state <=4'd2 ;
end
4'd2:
begin
instruction_set <= 1'B0 ;
instruction_state <=4'd3 ;
end
4'd3:
begin
if(start == 1'b0)
instruction_state <= instruction_next_state ;
end
4'd4:
begin
instruction[0] <= {2'b10,dat_i} ;
instruction_length <= 1 ;
instruction_next_state <= 4'd0 ;
instruction_state <= 4'd2 ;
end
default:
instruction_state <= 4'd0 ;
endcase
end
end
always@(negedge clk, negedge rst)
begin
if (rst == 1'B0)
clk_e_counter <= 0;
else if(clk == 1'B0)
begin
if (clk_e_counter == DIV_WORK_CLOCK-1'B1)
clk_e_counter <= 0;
clk_e_counter <= clk_e_counter+1'B1;
end
end
endmodule
![](http://cache.amobbs.com/bbs_upload782111/files_35/ourdev_603602SWWZ07.png)
(原文件名:shixu2.png)
仿真光标所指处,两个状态机分别执行到了state=4'd2,instruction_state=4'd2。但是奇怪instruction_index怎么会变成0的? |
