将本文件拷贝到...\CMSIS\CM0\DeviceSupport\Nuvoton\M051Series内。
#ifndef __M051Seriescfg_H__
#define __M051Seriescfg_H__
#ifdef __cplusplus
extern "C" {
#if defined (__CC_ARM)
#pragma anon_unions
#include "M051Series.h"
typedef volatile unsigned int NU_REG;// Hardware register definition
#define __noinit__ __attribute__((zero_init))//变量不初始化为0
typedef enum
__0 = (NU_REG)0,
__1 = (NU_REG)1,
__2 = (NU_REG)2,
__3 = (NU_REG)3,
__4 = (NU_REG)4,
__5 = (NU_REG)5,
__6 = (NU_REG)6,
__7 = (NU_REG)7,
__8 = (NU_REG)8,
__9 = (NU_REG)9,
__10 = (NU_REG)10,
__11 = (NU_REG)11,
__12 = (NU_REG)12,
__13 = (NU_REG)13,
__14 = (NU_REG)14,
__15 = (NU_REG)15,
__16 = (NU_REG)16,
__17 = (NU_REG)17,
__18 = (NU_REG)18,
__19 = (NU_REG)19,
__20 = (NU_REG)20,
__21 = (NU_REG)21,
__22 = (NU_REG)22,
__23 = (NU_REG)23,
__24 = (NU_REG)24,
__25 = (NU_REG)25,
__26 = (NU_REG)26,
__27 = (NU_REG)27,
__28 = (NU_REG)28,
__29 = (NU_REG)29,
__30 = (NU_REG)30,
__31 = (NU_REG)31
}Number_enum;
typedef volatile struct
NU_REG Bit0: 1;
NU_REG Bit1: 1;
NU_REG Bit2: 1;
NU_REG Bit3: 1;
NU_REG Bit4: 1;
NU_REG Bit5: 1;
NU_REG Bit6: 1;
NU_REG Bit7: 1;
NU_REG Bit8: 1;
NU_REG Bit9: 1;
NU_REG Bit10: 1;
NU_REG Bit11: 1;
NU_REG Bit12: 1;
NU_REG Bit13: 1;
NU_REG Bit14: 1;
NU_REG Bit15: 1;
NU_REG Bit16: 1;
NU_REG Bit17: 1;
NU_REG Bit18: 1;
NU_REG Bit19: 1;
NU_REG Bit20: 1;
NU_REG Bit21: 1;
NU_REG Bit22: 1;
NU_REG Bit23: 1;
NU_REG Bit24: 1;
NU_REG Bit25: 1;
NU_REG Bit26: 1;
NU_REG Bit27: 1;
NU_REG Bit28: 1;
NU_REG Bit29: 1;
NU_REG Bit30: 1;
NU_REG Bit31: 1;
}NU_BITs;
NU_REG Pin0: 1;
NU_REG Pin1: 1;
NU_REG Pin2: 1;
NU_REG Pin3: 1;
NU_REG Pin4: 1;
NU_REG Pin5: 1;
NU_REG Pin6: 1;
NU_REG Pin7: 1;
NU_REG Pin8: 1;
NU_REG Pin9: 1;
NU_REG Pin10: 1;
NU_REG Pin11: 1;
NU_REG Pin12: 1;
NU_REG Pin13: 1;
NU_REG Pin14: 1;
NU_REG Pin15: 1;
NU_REG Pin16: 1;
NU_REG Pin17: 1;
NU_REG Pin18: 1;
NU_REG Pin19: 1;
NU_REG Pin20: 1;
NU_REG Pin21: 1;
NU_REG Pin22: 1;
NU_REG Pin23: 1;
NU_REG Pin24: 1;
NU_REG Pin25: 1;
NU_REG Pin26: 1;
NU_REG Pin27: 1;
NU_REG Pin28: 1;
NU_REG Pin29: 1;
NU_REG Pin30: 1;
NU_REG Pin31: 1;
}NU_PINs;
typedef volatile union
__IO NU_REG Regs;
__IO NU_BITs Bits;
}NU_REG_BITs;
__IO NU_REG Regs;
__IO NU_PINs Bits;
}NU_REG_PINs;
typedef struct
__IO NU_REG RESERVED:16;
__IO NU_REG OFFD0:1;
__IO NU_REG OFFD1:1;
__IO NU_REG OFFD2:1;
__IO NU_REG OFFD3:1;
__IO NU_REG OFFD4:1;
__IO NU_REG OFFD5:1;
__IO NU_REG OFFD6:1;
__IO NU_REG OFFD7:1;
__IO NU_REG OFFD8:1;
__IO NU_REG OFFD9:1;
__IO NU_REG OFFD10:1;
__IO NU_REG OFFD11:1;
__IO NU_REG OFFD12:1;
__IO NU_REG OFFD13:1;
__IO NU_REG OFFD14:1;
__IO NU_REG OFFD15:1;
}NU_GPIO_OFFD_Bits;
NU_REG Regs;
GPIO_PMD_T Bits;
}NU_GPIO_PMD_T;
NU_REG Regs;
NU_GPIO_OFFD_Bits Bits;
}NU_GPIO_OFFD_T;
//改造GPIO为结构(不占用空间)
typedef struct
NU_GPIO_PMD_T PMD;//模式控制(0输入1输出2开漏3准双向)
union{
NU_REG_PINs SCH;
NU_GPIO_OFFD_T OFFD;//数字使能(高16位)
NU_REG_PINs DOUT;//数据输出值(低16位)
NU_REG_PINs DMASK;//数据输出写屏蔽
NU_REG_PINs PIN;//管脚数值(低16位)
NU_REG_PINs DBEN;//防反弹使能
NU_REG_PINs IMD;//中断模式控制(0边沿触发中断1电平触发中断)
NU_REG_BITs IEN;//中断使能(高16位上升沿或高电平,低16位下降沿或低电平)
NU_REG_PINs ISRC;//中断源标志
NU_REG RESERVED[7];//保留,为了构造GPIO结构数组
} NU_GPIO_T;
NU_REG Regs;
GPIO_DBNCECON_T Bits;
}NU_GPIO_DBNCECON_T;
typedef struct {
union {
__IO NU_GPIO_T Px[5];//GPIOs.Px[0].DOUT.Regs |= 1;GPIOs.Px[0].DOUT.Bits.Pin0 = 1;
struct {
__IO NU_GPIO_T P0;//GPIOs.P0.DOUT.Regs |=1;GPIOs.P0.DOUT.Bits.Pin0=1;
__IO NU_GPIO_T P1;//GPIOs.P1.DOUT.Regs |=2;GPIOs.P1.DOUT.Bits.Pin1=1;
__IO NU_GPIO_T P2;//GPIOs.P2.DOUT.Regs |=4;GPIOs.P2.DOUT.Bits.Pin2=1;
__IO NU_GPIO_T P3;//GPIOs.P3.DOUT.Regs |=8;GPIOs.P3.DOUT.Bits.Pin3=1;
__IO NU_GPIO_T P4;//GPIOs.P4.DOUT.Regs |=16;GPIOs.P4.DOUT.Bits.Pin4=1;
__I NU_REG RESERVED0[16];
__IO NU_GPIO_DBNCECON_T DBNCECON;
__I NU_REG RESERVED1[15];
__I NU_REG RESERVED2[16];
__IO NU_REG_PINs BIT_DOUT;
}NUS_GPIO, *NUPS_GPIO;
#define NU_BASE_GPIO ((NUPS_GPIO) GPIOA_BASE)//定义硬件结构指针(硬件地址)
#define GPIOs (*NU_BASE_GPIO)//定位全局结构变量GPIOs
#define GPIO0s (*((NU_GPIO_T *) PORT0_BASE))//定位全局结构变量GPIO0s
#define GPIO1s (*((NU_GPIO_T *) PORT1_BASE))//定位全局结构变量GPIO1s
#define GPIO2s (*((NU_GPIO_T *) PORT2_BASE))//定位全局结构变量GPIO2s
#define GPIO3s (*((NU_GPIO_T *) PORT3_BASE))//定位全局结构变量GPIO3s
#define GPIO4s (*((NU_GPIO_T *) PORT4_BASE))//定位全局结构变量GPIO4s
#define P0s GPIO0s
#define P1s GPIO1s
#define P2s GPIO2s
#define P3s GPIO3s
#define P4s GPIO4s
#define PORT0s GPIO0s
#define PORT1s GPIO1s
#define PORT2s GPIO2s
#define PORT3s GPIO3s
#define PORT4s GPIO4s
#define GPIOx(x) ((NU_GPIO_T *) PORT0_BASE + (x * 0x0040))
#define PORTx(x) ((NU_GPIO_T *) PORT0_BASE + (x * 0x0040))
#define Px(x) ((NU_GPIO_T *) PORT0_BASE + (x * 0x0040))
NU_REG Regs;
UART_IER_T Bits;
}NU_UART_IER_T;
NU_REG Regs;
UART_FCR_T Bits;
}NU_UART_FCR_T;
NU_REG Regs;
UART_LCR_T Bits;
}NU_UART_LCR_T;
NU_REG Regs;
UART_MCR_T Bits;
}NU_UART_MCR_T;
NU_REG Regs;
UART_MSR_T Bits;
}NU_UART_MSR_T;
NU_REG Regs;
UART_FSR_T Bits;
}NU_UART_FSR_T;
NU_REG Regs;
UART_ISR_T Bits;
}NU_UART_ISR_T;
NU_REG Regs;
UART_TOR_T Bits;
}NU_UART_TOR_T;
NU_REG Regs;
UART_BAUD_T Bits;
}NU_UART_BAUD_T;
NU_REG Regs;
UART_IRCR_T Bits;
}NU_UART_IRCR_T;
NU_REG Regs;
UART_ALTCON_T Bits;
}NU_UART_ALTCON_T;
NU_REG Regs;
UART_FUNSEL_T Bits;
}NU_UART_FUNSEL_T;
typedef struct
union{
__IO NU_REG_BITs DATA;//接收发送数据
__I NU_REG_BITs RBR;//接收数据缓存寄存器
__O NU_REG_BITs THR;//发送保持寄存器
__IO NU_UART_IER_T IER;//中断使能寄存器
__IO NU_UART_FCR_T FCR;//FIFO控制寄存器
__IO NU_UART_LCR_T LCR;//Line控制寄存器
__IO NU_UART_MCR_T MCR;//Modem控制寄存器
__IO NU_UART_MSR_T MSR;//Modem状态寄存器
__IO NU_UART_FSR_T FSR;//FIFO状态寄存器
__IO NU_UART_ISR_T ISR;//中断状态寄存器
__IO NU_UART_TOR_T TOR;//定时溢出寄存器
__IO NU_UART_BAUD_T BAUD;//波特率分频寄存器
__IO NU_UART_IRCR_T IRCR;//IrDA控制寄存器
__IO NU_UART_ALTCON_T ALTCON;//LIN Break失败计数寄存器
__IO NU_UART_FUNSEL_T FUNSEL;//功能选择寄存器
}NU_UART_T;
#define UART0s (*((NU_UART_T *) UART0_BASE))//定位全局结构变量UART0s
#define UART1s (*((NU_UART_T *) UART1_BASE))//定位全局结构变量UART0s
#define UARTx(x) ((NU_UART_T *) UART0_BASE + ((x & 1) * 0x100000) + ((x >> 1) * 0x104000))
#define Ux(x) ((NU_UART_T *) UART0_BASE + ((x & 1) * 0x100000) + ((x >> 1) * 0x104000))
typedef enum
TIMER_TCSR_PRESCALE = 0,//预分频计数器
TIMER_TCSR_TDR_EN = 16,//数据锁存使能
TIMER_TCSR_COUNTER_EN = 24,//
TIMER_TCSR_CACT = 25,//定时器工作状态
TIMER_TCSR_CRST = 26,//计数器重置
TIMER_TCSR_MODE = 27,//定时器工作模式
TIMER_TCSR_TMR_IE = 29,//中断使能
TIMER_TCSR_CEN = 30,//计数器使能位
TIMER_TCSR_nDBGACK_EN = 31
}NU_TIMER_TCSR_ENUM;
NU_REG Regs;
TIMER_TCSR_T Bits;
}NU_TIMER_TCSR_T;
typedef enum
TIMER_TISR_TIF = 0//定时器中断标志
}NU_TIMER_TISR_T_ENUM;
NU_REG Regs;
TIMER_TISR_T Bits;
}NU_TIMER_TISR_T;
typedef struct
__IO NU_TIMER_TCSR_T TCSR;//控制与状态寄存器
__IO NU_REG_BITs TCMPR;//比较寄存器
__IO NU_TIMER_TISR_T TISR;//中断状态寄存器
__IO NU_REG_BITs TDR;//数据寄存器
}NU_TIMER_T;
#define TIMER0s (*((NU_TIMER_T *) TIMER0_BASE))//定位全局结构变量TIMER0s
#define TIMER1s (*((NU_TIMER_T *) TIMER1_BASE))//定位全局结构变量TIMER1s
#define TIMER2s (*((NU_TIMER_T *) TIMER2_BASE))//定位全局结构变量TIMER2s
#define TIMER3s (*((NU_TIMER_T *) TIMER3_BASE))//定位全局结构变量TIMER3s
#define TIMERx(x) ((NU_TIMER_T *)TIMER0_BASE + ((x & 1) * 0x0020) + ((x >> 1) * 0x100000))
typedef enum
WDT_WTCR_WTR = 0,//看门狗定时器重置
WDT_WTCR_WTRE = 1,//看门狗定时器复位使能
WDT_WTCR_WTRF = 2,//看门狗定时器复位标志
WDT_WTCR_WTIF = 3,//看门狗定时器中断标志
WDT_WTCR_WTWKE = 4,//看门狗定时器唤醒功能使能位
WDT_WTCR_WTWKF = 5,//看门狗定时器唤醒标志
WDT_WTCR_WTIE = 6,//看门狗定时器中断使能
WDT_WTCR_WTE = 7,//看门狗定时器使能
WDT_WTCR_WTIS = 8,//看门狗定时器间隔选择
//000:69.33us 001:72.53us 010:85.33us 011:170.67us
//100:426.67us 101:1.45ms 110:5.55ms 111:21.93ms
}NU_WDT_WTCR_ENUM;
NU_REG Regs;
WDT_WTCR_T Bits;
}NU_WDT_WTCR_T;
typedef struct
__IO NU_WDT_WTCR_T WTCR;//看门狗定时器控制寄存器
}NU_WDT_T;
#define WDTs (*((NU_WDT_T *) WDT_BASE))//定位全局结构变量WDTs
#define WDTx ((NU_WDT_T *) WDT_BASE)
typedef enum
SPI_CNTRL_GO_BUSY = 0,//通讯或忙状态标志
SPI_CNTRL_RX_NEG = 1,//接收数据边沿反向位(0=SDI信号在SPICLK上升沿接收)
SPI_CNTRL_TX_NEG = 2,//发送数据边沿反向位(0=SDO信号在SPICLK的上升沿发送)
SPI_CNTRL_TX_BIT_LEN = 3,//传输位长度(32,1,...31)
SPI_CNTRL_TX_NUM = 8,//发送/接收数量(00=每次传输仅完成1次发送/接收,01=每次传输仅完成2次发送/接收)
SPI_CNTRL_LSB = 10,//优先传送LSB(0=优先发送/接收MSB,根据CNTRL寄存器的Tx_BIT_LEN 决定TxX/RxX)
SPI_CNTRL_CLKP = 11,//时钟极性(0=SCLK低电平闲置)
SPI_CNTRL_SP_CYCLE = 12,//暂缓间隙 (仅主机模式)
SPI_CNTRL_IF = 16,//中断标志(0=表示传输未结束, 该位写1清零)
SPI_CNTRL_IE = 17,//中断使能
SPI_CNTRL_SLAVE = 18,//SLAVE模式标志(0=MCU作为主机模式)
SPI_CNTRL_BYTE_REORDER = 19,
SPI_CNTRL_TWOB= 21,
SPI_CNTRL_VARCLK_EN = 22
}NU_SPI_CNTRL_ENUM;
typedef enum
SPI_SSR_SSR = 0,//从机选择寄存器(主机模式)
SPI_SSR_SS_LVL = 2,//从机选择触发电平选择
SPI_SSR_AUTOSS = 3,//自动从机选择(主机模式)
SPI_SSR_SS_LTRIG = 4,//从机电平触发选择(从机模式)
SPI_SSR_LTRIG_FLAG = 5//电平触发标志
}NU_SPI_SSR_ENUM;
NU_REG Regs;
SPI_CNTRL_T Bits;
}NU_SPI_CNTRL_T;
NU_REG Regs;
SPI_SSR_T Bits;
}NU_SPI_SSR_T;
NU_REG Regs;
SPI_DIVIDER_T Bits;
}NU_SPI_DIVIDER_T;
typedef struct
NU_SPI_CNTRL_T CNTRL;//控制及状态寄存器
NU_SPI_DIVIDER_T DIVIDER;//时钟除频寄存器
NU_SPI_SSR_T SSR;//从机选择寄存器
NU_REG RESERVE0;//保留
union{
NU_REG_BITs RX[2];//接收数据寄存器数组
struct{
NU_REG_BITs RX0;//接收数据寄存器低32位
NU_REG_BITs RX1;//接收数据寄存器高32位
NU_REG RESERVE1[2];//保留
union{
NU_REG_BITs TX[2];//数据发送寄存器数组
struct{
NU_REG_BITs TX0;//数据发送寄存器低32位
NU_REG_BITs TX1;//数据发送寄存器高32位
NU_REG RESERVE2[3];//保留
NU_REG_BITs VARCLK;
NU_REG RESERVE3;//保留
}NU_SPI_T;
#define SPI0s (*((NU_SPI_T *) SPI0_BASE))//定位全局结构变量SPI0s
#define SPI1s (*((NU_SPI_T *) SPI1_BASE))//定位全局结构变量SPI1s
#define SPIx(x) ((NU_SPI_T *) SPI0_BASE + ((x & 1) * 0x4000) + ((x >> 1) * 0x100000))
typedef enum
I2C_CON_AA = 2,//I2C接收应答标志位
I2C_CON_SI = 3,//I2C中断标志位
I2C_CON_STO = 4,//I2C停止标志
I2C_CON_STA = 5,//I2C起始标志
I2C_CON_ENSI = 6,//I2C控制使能/禁止
I2C_CON_EI = 7 //使能中断
}NU_I2C_CON_ENUM;
NU_REG Regs;
I2C_CON_T Bits;
}NU_I2C_CON_T;
typedef enum
I2C_ADDR_GC = 0,//全呼功能
I2C_ADDR_ADDR = 1 //I2C地址寄存器
}NU_I2C_ADDR_ENUM;
NU_REG Regs;
I2C_ADDR_T Bits;
}NU_I2C_ADDR_T;
typedef enum
I2C_ADRM_ADM = 1 //I2C隐藏地址寄存器
}NU_I2C_ADRM_ENUM;
NU_REG Regs;
I2C_ADRM_T Bits;
}NU_I2C_ADRM_T;
typedef enum
I2C_TOC_TIF = 0,//超时标志
I2C_TOC_DIV4 = 1,//超时计数输入时钟除4
I2C_TOC_ENTI = 2 //超时计数使能/禁止
}NU_I2C_TOC_NUM;
NU_REG Regs;
I2C_TOC_T Bits;
}NU_I2C_TOC_T;
typedef struct
__IO NU_I2C_CON_T CON;//I2C控制寄存器
__IO NU_I2C_ADDR_T ADDR0;//I2C从机地址寄存器0
__IO NU_REG_BITs DATA;//I2C数据寄存器
__IO NU_REG_BITs STATUS;//I2C状态寄存器
__IO NU_REG_BITs CLK;//I2C时钟时钟分频寄存器
__IO NU_I2C_TOC_T TOC;//I2C超时控制寄存器
__IO NU_I2C_ADDR_T ADDR1;//从机地址寄存器1
__IO NU_I2C_ADDR_T ADDR2;//从机地址寄存器2
__IO NU_I2C_ADDR_T ADDR3;//从机地址寄存器3
__IO NU_I2C_ADRM_T ADRM0;//从机隐藏地址寄存器0
__IO NU_I2C_ADRM_T ADRM1;//从机隐藏地址寄存器1
__IO NU_I2C_ADRM_T ADRM2;//从机隐藏地址寄存器2
__IO NU_I2C_ADRM_T ADRM3;//从机隐藏地址寄存器3
}NU_I2C_T;
#define I2Cs (*((NU_I2C_T *) I2C_BASE))//定位全局结构变量I2Cs
#define I2Cx ((NU_I2C_T *) I2C_BASE)
typedef enum
ADC_ADDR_RSLT = 0,//A/D转换结果
ADC_ADDR_OVERRUN = 16,//结束运行标志位
ADC_ADDR_VALID = 17//有效标志位
}NU_ADC_ADDR_ENUM;
NU_REG Regs;
ADC_ADDR_T Bits;
}NU_ADC_ADDR_T;
typedef enum
ADC_ADCR_ADEN = 0,//A/D转换使能
ADC_ADCR_ADIE = 1,//A/D中断使能
ADC_ADCR_ADMD = 2,//A/D转换操作模式
ADC_ADCR_TRGS = 4,//硬件触发源
ADC_ADCR_TRGCOND = 6,//外部触发条件
ADC_ADCR_TRGEN = 8,//外部触发使能
ADC_ADCR_PTEN = 9,//PDMA 传送使能
ADC_ADCR_DIFFEN = 10,//A/D差分输入模式使能
ADC_ADCR_ADST = 11,//A/D转换开始
ADC_ADCR_DMOF = 31
}NU_ADC_ADCR_ENUM;
NU_REG Regs;
ADC_ADCR_T Bits;
}NU_ADC_ADCR_T;
typedef enum
ADC_ADCHER_CHEN0 = 0,//模拟输入通道0
ADC_ADCHER_CHEN1 = 1,//模拟输入通道1
ADC_ADCHER_CHEN2 = 2,//模拟输入通道2
ADC_ADCHER_CHEN3 = 3,//模拟输入通道3
ADC_ADCHER_CHEN4 = 4,//模拟输入通道4
ADC_ADCHER_CHEN5 = 5,//模拟输入通道5
ADC_ADCHER_CHEN6 = 6,//模拟输入通道6
ADC_ADCHER_CHEN7 = 7,//模拟输入通道7
ADC_ADCHER_PRESEL = 8 //模拟输入通道7选择位
//00:模拟输入通道7 01:Bandgap(VBG)模拟输入
//10:VTEMP模拟输入 11:模拟地
}NU_ADC_ADCHER_ENUM;
NU_REG Regs;
ADC_ADCHER_T Bits;
}NU_ADC_ADCHER_T;
typedef enum
ADC_ADCMPR_CMPEN = 0, //比较使能
ADC_ADCMPR_CMPIE = 1, //比较中断使能
ADC_ADCMPR_CMPCOND = 2, //比较条件
ADC_ADCMPR_CMPCH = 3, //Compare通道选择(000=选择通道0转换结果,111=选择通道7转换结果)
ADC_ADCMPR_CMPMATCNT = 8, //比较匹配值
ADC_ADCMPR_CMPD = 16 //比较数值
}NU_ADC_ADCMPR_ENUM;
NU_REG Regs;
ADC_ADCMPR_T Bits;
}NU_ADC_ADCMPR_T;
typedef enum
ADC_ADSR_ADF = 0,//A/D转换结束标志位
ADC_ADSR_CMPF0 = 1,//比较标志位
ADC_ADSR_CMPF1 = 2,//较标志位
ADC_ADSR_BUSY = 3,//BUSY/IDLE
ADC_ADSR_CHANNEL = 4,//当前转换通道
ADC_ADSR_VALID = 8,//数据有效标志位
ADC_ADSR_OVERRUN = 16//结束运行标志位
}NU_ADC_ADSR_ENUM;
NU_REG Regs;
ADC_ADSR_T Bits;
}NU_ADC_ADSR_T;
typedef enum
ADC_ADCALR_CALEN = 0,//自身校准功能使能
ADC_ADCALR_CALDONE = 1 //校准完成标志(只读)
}NU_ADC_ADCALR_ENUM;
NU_REG Regs;
ADC_ADCALR_T Bits;
}NU_ADC_ADCALR_T;
typedef struct
union{
__I NU_ADC_ADDR_T ADDR[8];//A/D数据寄存器0~7
struct{
__I NU_ADC_ADDR_T ADDR0;//A/D数据寄存器0
__I NU_ADC_ADDR_T ADDR1;//A/D数据寄存器1
__I NU_ADC_ADDR_T ADDR2;//A/D数据寄存器2
__I NU_ADC_ADDR_T ADDR3;//A/D数据寄存器3
__I NU_ADC_ADDR_T ADDR4;//A/D数据寄存器4
__I NU_ADC_ADDR_T ADDR5;//A/D数据寄存器5
__I NU_ADC_ADDR_T ADDR6;//A/D数据寄存器6
__I NU_ADC_ADDR_T ADDR7;//A/D数据寄存器7
__IO NU_ADC_ADCR_T ADCR;//ADC控制寄存器
__IO NU_ADC_ADCHER_T ADCHER;//A/D 通道使能
union{
__IO NU_ADC_ADCMPR_T ADCMPR[2];//A/D比较寄存器0,1
struct{
__IO NU_ADC_ADCMPR_T ADCMPR0;//A/D比较寄存器0
__IO NU_ADC_ADCMPR_T ADCMPR1;//A/D比较寄存器1
__IO NU_ADC_ADSR_T ADSR;//ADC状态寄存器
__IO NU_ADC_ADCALR_T ADCALR;//A/D校准寄存器
__I NU_REG RESERVE0;
__I NU_REG RESERVE1;
__I NU_REG RESERVE2;
}NU_ADC_T;
#define ADCs (*((NU_ADC_T *) ADC_BASE))//定位全局结构变量ADCs
#define ADCx ((NU_ADC_T *) ADC_BASE)
NU_REG Regs;
PWM_PPR_T Bits;
}NU_PWM_PPR_T;
NU_REG Regs;
PWM_CSR_T Bits;
}NU_PWM_CSR_T;
NU_REG Regs;
PWM_PCR_T Bits;
}NU_PWM_PCR_T;
NU_REG Regs;
PWM_PIER_T Bits;
}NU_PWM_PIER_T;
NU_REG Regs;
PWM_PIIR_T Bits;
}NU_PWM_PIIR_T;
NU_REG Regs;
PWM_CCR0_T Bits;
}NU_PWM_CCR0_T;
NU_REG Regs;
PWM_CCR2_T Bits;
}NU_PWM_CCR2_T;
NU_REG Regs;
PWM_POE_T Bits;
}NU_PWM_POE_T;
typedef struct
__IO NU_PWM_PPR_T PPR;//PWM0~3或PWM4~7预分频寄存器
__IO NU_PWM_CSR_T CSR;//PWM0~3或PWM4~7时钟选择寄存器
__IO NU_PWM_PCR_T PCR;//PWM0~3或PWM4~7控制寄存器
__IO NU_REG_BITs CNR0;//PWM0或PWM4计数器寄存器
__IO NU_REG_BITs CMR0;//PWM0或PWM4比较寄存器
__IO NU_REG_BITs PDR0;//PWM0或PWM4数据寄存器
__IO NU_REG_BITs CNR1;//PWM1或PWM5计数器寄存器
__IO NU_REG_BITs CMR1;//PWM1或PWM5比较寄存器
__IO NU_REG_BITs PDR1;//PWM1或PWM5数据寄存器
__IO NU_REG_BITs CNR2;//PWM2或PWM6计数器寄存器
__IO NU_REG_BITs CMR2;//PWM2或PWM6比较寄存器
__IO NU_REG_BITs PDR2;//PWM2或PWM6数据寄存器
__IO NU_REG_BITs CNR3;//PWM3或PWM7计数器寄存器
__IO NU_REG_BITs CMR3;//PWM3或PWM7比较寄存器
__IO NU_REG_BITs PDR3;//PWM3或PWM7数据寄存器
__IO NU_PWM_PIER_T PIER;//PWM0~3或PWM4~7中断使能寄存器
__IO NU_PWM_PIIR_T PIIR;
__I NU_REG RESERVE1[2];
__IO NU_PWM_CCR0_T CCR0;
__IO NU_PWM_CCR2_T CCR2;
__IO NU_REG_BITs CRLR0;
__IO NU_REG_BITs CFLR0;
__IO NU_REG_BITs CRLR1;
__IO NU_REG_BITs CFLR1;
__IO NU_REG_BITs CRLR2;
__IO NU_REG_BITs CFLR2;
__IO NU_REG_BITs CRLR3;
__IO NU_REG_BITs CFLR3;
__IO NU_REG_BITs CAPENR;
__IO NU_PWM_POE_T POE;
}NU_PWM_T;
#define PWM03s (*((NU_PWM_T *) PWMA_BASE))//定位全局结构变量PWM03s
#define PWM47s (*((NU_PWM_T *) PWMB_BASE))//定位全局结构变量PWM47s
#define PWMx(x) ((NU_PWM_T *) PWMA_BASE + (x * 0x100000))
typedef enum
SYSCLK_PWRCON_XTL12M_EN = 0,//外部12MHz晶振控制
SYSCLK_PWRCON_XTL32K_EN = 1,//外部32.768KHz晶振控制
SYSCLK_PWRCON_OSC22M_EN = 2,//内部22MHz振荡器控制
SYSCLK_PWRCON_OSC10K_EN = 3,//内部10KHz振荡器控制
SYSCLK_PWRCON_PD_WU_DLY = 4,//使能唤醒延时计数器
SYSCLK_PWRCON_PD_WU_INT_EN = 5,//掉电模式唤醒的中断使能
SYSCLK_PWRCON_PD_WU_STS = 6,//芯片掉电唤醒状态标志
SYSCLK_PWRCON_PWR_DOWN = 7,//激活或使能系统掉电模式
SYSCLK_PWRCON_PD_WAIT_CPU = 8 //控制进入掉电模式的条件
}NU_SYSCLK_PWRCON_ENUM;
NU_REG Regs;
SYSCLK_PWRCON_T Bits;
}NU_SYSCLK_PWRCON_T;
typedef enum
SYSCLK_AHBCLK_PDMA_EN = 1,//PDMA控制器时钟使能控制
SYSCLK_AHBCLK_ISP_EN = 2,//Flash ISP控制器时钟使能控制
SYSCLK_AHBCLK_EBI_EN = 3 //
}NU_SYSCLK_AHBCLK_ENUM;
NU_REG Regs;
SYSCLK_AHBCLK_T Bits;
}NU_SYSCLK_AHBCLK_T;
typedef enum
SYSCLK_APBCLK_WDT_EN = 0,//Watch Dog时钟使能
SYSCLK_APBCLK_RTC_EN = 1,//Real-Time-Clock APB接口时钟控制
SYSCLK_APBCLK_TMR0_EN = 2,//Timer0时钟使能控制
SYSCLK_APBCLK_TMR1_EN = 3,//Timer1时钟使能控制
SYSCLK_APBCLK_TMR2_EN = 4,//Timer2时钟使能控制
SYSCLK_APBCLK_TMR3_EN = 5,//Timer3时钟使能控制
SYSCLK_APBCLK_FDIV_EN = 6,//分频器输出时钟使能控制
SYSCLK_APBCLK_I2C0_EN = 8,//I2C0时钟使能控制
SYSCLK_APBCLK_I2C1_EN = 9,//I2C1时钟使能控制
SYSCLK_APBCLK_SPI0_EN = 12,//SPI0时钟使能控制
SYSCLK_APBCLK_SPI1_EN = 13,//SPI1时钟使能控制
SYSCLK_APBCLK_SPI2_EN = 14,//SPI2时钟使能控制
SYSCLK_APBCLK_SPI3_EN = 15,//SPI3时钟使能控制
SYSCLK_APBCLK_UART0_EN = 16,//UART0时钟使能控制
SYSCLK_APBCLK_UART1_EN = 17,//UART1时钟使能控制
SYSCLK_APBCLK_UART2_EN = 18,//UART2时钟使能控制
SYSCLK_APBCLK_PWM01_EN = 20,//PWM_01时钟使能控制
SYSCLK_APBCLK_PWM23_EN = 21,//PWM_23时钟使能控制
SYSCLK_APBCLK_PWM45_EN = 22,//PWM_45时钟使能控制
SYSCLK_APBCLK_PWM67_EN = 23,//PWM_67时钟使能控制
SYSCLK_APBCLK_CAN0_EN = 24,//使能CAN线控制器0时钟控制
SYSCLK_APBCLK_USBD_EN = 27,//USB FS设备控制器时钟使能控制
SYSCLK_APBCLK_ADC_EN = 28,//使能ADC时钟控制
SYSCLK_APBCLK_I2S_EN = 29,//I2S时钟使能控制
SYSCLK_APBCLK_ACMP_EN = 30,//模拟比较器时钟使能控制
SYSCLK_APBCLK_PS2_EN = 31//PS2时钟使能控制
}NU_SYSCLK_APBCLK_ENUM;
NU_REG Regs;
SYSCLK_APBCLK_T Bits;
}NU_SYSCLK_APBCLK_T;
typedef enum
SYSCLK_CLKSTATUS_XTL12M_STB = 0,
SYSCLK_CLKSTATUS_XTL32K_STB = 1,
SYSCLK_CLKSTATUS_PLL_STB = 2,
SYSCLK_CLKSTATUS_OSC10K_STB = 3,
SYSCLK_CLKSTATUS_OSC22M_STB = 4,
SYSCLK_CLKSTATUS_RESERVE0 = 5,
SYSCLK_CLKSTATUS_CLK_SW_FAIL = 7
}NU_SYSCLK_CLKSTATUS_ENUM;
NU_REG Regs;
SYSCLK_CLKSTATUS_T Bits;
}NU_SYSCLK_CLKSTATUS_T;
typedef enum
SYSCLK_CLKSEL0_HCLK_S = 0,
SYSCLK_CLKSEL0_STCLK_S = 3
}NU_SYSCLK_CLKSEL0_ENUM;
NU_REG Regs;
SYSCLK_CLKSEL0_T Bits;
}NU_SYSCLK_CLKSEL0_T;
typedef enum
SYSCLK_CLKSEL1_WDT_S = 0,//WDGCLK时钟源选择
SYSCLK_CLKSEL1_ADC_S = 1,//ADC时钟源选择
SYSCLK_CLKSEL1_TMR0_S = 8,//TIMER0时钟源选择
SYSCLK_CLKSEL1_TMR1_S = 12,//TIMER1时钟源选择
SYSCLK_CLKSEL1_TMR2_S = 16,//TIMER2时钟源选择
SYSCLK_CLKSEL1_TMR3_S = 20,//TIMER3时钟源选择
SYSCLK_CLKSEL1_UART_S = 24,//UART时钟源选择
SYSCLK_CLKSEL1_CAN_S = 26,//CAN时钟源选择
SYSCLK_CLKSEL1_PWM01_S = 28,//PWM1与PWM0的时钟源选择
SYSCLK_CLKSEL1_PWM23_S = 30 //PWM3与PWM2的时钟源选择.
}NU_SYSCLK_CLKSEL1_ENUM;
NU_REG Regs;
SYSCLK_CLKSEL1_T Bits;
}NU_SYSCLK_CLKSEL1_T;
typedef enum
SYSCLK_CLKDIV_HCLK_N = 0,//HCLK时钟频率=(HCLK时钟源频率)/(HCLK_N+1)
SYSCLK_CLKDIV_USB_N = 4,//USB时钟频率=(PLL频率)/(USB_N+1)
SYSCLK_CLKDIV_UART_N = 8,//UART时钟频率=(UART时钟源频率)/(UART_N+1)
SYSCLK_CLKDIV_CAN_N = 12,//APU时钟频率=(CAN时钟源频率)/(CAN_N+1)
SYSCLK_CLKDIV_ADC_N = 16,//ADC时钟频率=ADC时钟源频率/(ADC_N+1)
SYSCLK_CLKDIV_CAN_N_EXT = 24//
}NU_SYSCLK_CLKDIV_ENUM;
NU_REG Regs;
SYSCLK_CLKDIV_T Bits;
}NU_SYSCLK_CLKDIV_T;
typedef enum
SYSCLK_CLKSEL2_I2S_S = 0,//I2S时钟源选择
SYSCLK_CLKSEL2_FRQDIV_S = 2,//时钟分频器时钟源选择
SYSCLK_CLKSEL2_PWM45_S = 4,//PWM4与PWM5的时钟源选择
SYSCLK_CLKSEL2_PWM67_S = 6 //PWM6与PWM7的时钟源选择
}NU_SYSCLK_CLKSEL2_ENUM;
NU_REG Regs;
SYSCLK_CLKSEL2_T Bits;
}NU_SYSCLK_CLKSEL2_T;
typedef enum
SYSCLK_PLLCON_FB_DV = 0,//PLL反馈分频控制引脚
SYSCLK_PLLCON_IN_DV = 9,//PLL输入分频控制引脚
SYSCLK_PLLCON_OUT_DV = 14,//PLL输出分频控制引脚
SYSCLK_PLLCON_PD = 16,//掉电模式
SYSCLK_PLLCON_BP = 17,//PLL旁路控制
SYSCLK_PLLCON_OE = 18,//PLL OE(FOUT enable)引脚控制
SYSCLK_PLLCON_PLL_SRC = 19 //PLL时钟源选择
}NU_SYSCLK_PLLCON_ENUM;
NU_REG Regs;
SYSCLK_PLLCON_T Bits;
}NU_SYSCLK_PLLCON_T;
typedef enum
SYSCLK_FRQDIV_FSEL = 0,//分频器输出频率选择位
SYSCLK_FRQDIV_FDIV_EN = 4 //频率分频器使能位
}NU_SYSCLK_FRQDIV_ENUM;
NU_REG Regs;
SYSCLK_FRQDIV_T Bits;
}NU_SYSCLK_FRQDIV_T;
typedef struct
__IO NU_SYSCLK_PWRCON_T PWRCON;//系统掉电控制寄存器
__IO NU_SYSCLK_AHBCLK_T AHBCLK;//AHB设备时钟使能控制寄存器
__IO NU_SYSCLK_APBCLK_T APBCLK;//APB设备时钟使能控制寄存器
__IO NU_SYSCLK_CLKSTATUS_T CLKSTATUS;
__IO NU_SYSCLK_CLKSEL0_T CLKSEL0;//时钟源选择控制寄存器0
__IO NU_SYSCLK_CLKSEL1_T CLKSEL1;//时钟源选择控制寄存器1
__IO NU_SYSCLK_CLKDIV_T CLKDIV;//时钟分频寄存器
__IO NU_SYSCLK_CLKSEL2_T CLKSEL2;//时钟源选择控制寄存器2
__IO NU_SYSCLK_PLLCON_T PLLCON;//PLL 控制寄存器
__IO NU_SYSCLK_FRQDIV_T FRQDIV;//频率分频器控制寄存器
}NU_SYSCLK_T;
#define SYSCLKs (*((NU_SYSCLK_T *) SYSCLK_BASE))//定位全局结构变量SYSCLKs
#define SYSCLKx ((NU_SYSCLK_T *) SYSCLK_BASE)
typedef struct
__I NU_REG_BITs ISER;//IRQ0~IRQ31设置使能控制寄存器
__I NU_REG RESERVED0[31];
__I NU_REG_BITs ICER;//IRQ0~IRQ31清使能控制寄存器
__I NU_REG RSERVED1[31];
__I NU_REG_BITs ISPR;//IRQ0~IRQ31设置挂起控制寄存器
__I NU_REG RESERVED2[31];
__I NU_REG_BITs ICPR;//IRQ0~IRQ31清挂起控制寄存器
__I NU_REG RESERVED3[31];
__I NU_REG RESERVED4[64];
union{
__I NU_REG_BITs IPR[8];//IRQ0~IRQ31优先级控制寄存器
struct{
__I NU_REG_BITs IPR0;//IRQ0~IRQ3优先级控制寄存器
__I NU_REG_BITs IPR1;//IRQ4~IRQ7优先级控制寄存器
__I NU_REG_BITs IPR2;//IRQ8~IRQ11优先级控制寄存器
__I NU_REG_BITs IPR3;//IRQ12~IRQ15优先级控制寄存器
__I NU_REG_BITs IPR4;//IRQ16~IRQ19优先级控制寄存器
__I NU_REG_BITs IPR5;//IRQ20~IRQ23优先级控制寄存器
__I NU_REG_BITs IPR6;//IRQ24~IRQ27优先级控制寄存器
__I NU_REG_BITs IPR7;//IRQ28~IRQ31优先级控制寄存器
}NU_NVIC_Type;
#define NVICs (*((NU_NVIC_Type *) NVIC_BASE))//定位全局结构变量NVICs
#define NVICx ((NU_NVIC_Type *) NVIC_BASE)
typedef enum
SCB_CPUID_REVISION = 0,//值为0x0
SCB_CPUID_PARTNO = 4,//值为0xC20
SCB_CPUID_PART = 16,//ARMv6-M值为0xC
SCB_CPUID_IMPLEMENTER = 24,//由ARM分配执行码(ARM=0x41)
}NU_SCB_CPUID_ENUM;
typedef struct
__I NU_REG REVISION:4;
__I NU_REG PARTNO:12;
__I NU_REG PART:4;
__I NU_REG RESERVE:4;
__I NU_REG IMPLEMENTER:8;
}SCB_CPUID_T;
NU_REG Regs;
SCB_CPUID_T Bits;
}NU_SCB_CPUID_T;
typedef enum
SCB_ICSR_VECTACTIVE = 0,//0:线程模式 value > 1: 当前执行异常处理的数目
SCB_ICSR_VECTPENDING = 12,//表示最高优先级挂起异常的数目
SCB_ICSR_ISRPENDING = 22,//表示外部配置中断是否挂起
SCB_ICSR_ISRPREEMPT = 23,//如果置位,挂起异常生效,由调试停止状态退出
SCB_ICSR_PENDSTCLR = 25,//写1清除挂起SysTick
SCB_ICSR_PENDSTSET = 26,//设置挂起SysTick.由当前状态读回(1 if Pending,0 if not)
SCB_ICSR_PENDSVCLR = 27,//写1清PendSV中断
SCB_ICSR_PENDSVSET = 28,//设置PendSV 中断.通常用于请求内容切换.由当前状态读回(1 if Pending, 0 if not)
SCB_ICSR_NMIPENDSET = 31//
}NU_SCB_ICSR_ENUM;
typedef struct
__I NU_REG VECTACTIVE:9;
__I NU_REG VECTPENDING:9;
__I NU_REG ISRPENDING:1;
__I NU_REG ISRPREEMPT:1;
__I NU_REG RESERVE1:1;
__O NU_REG PENDSTCLR:1;
__IO NU_REG PENDSTSET:1;
__I NU_REG PENDSVCLR:1;
__IO NU_REG PENDSVSET:1;
__I NU_REG RESERVE2:2;
__IO NU_REG NMIPENDSET:1;
}SCB_ICSR_T;
NU_REG Regs;
SCB_ICSR_T Bits;
}NU_SCB_ICSR_T;
typedef enum
SCB_SCR_SLEEPONEXIT = 1,//设置为1,在异常返回到线程模式时,内核进入休眠状态
SCB_SCR_SLEEPDEEP = 2,//提示从休眠中唤醒需要较长时间
SCB_SCR_SEVONPEND = 4 //当使能时,中断由不活动到挂起,包括了唤醒事件(WFE指令)
}NU_SCB_SCR_ENUM;
typedef struct
__I NU_REG RESERVE0:1;
__I NU_REG SLEEPONEXIT:1;
__I NU_REG SLEEPDEEP:1;
__O NU_REG SEVONPEND:1;
__I NU_REG RESERVE2:27;
}SCB_SCR_T;
NU_REG Regs;
SCB_ICSR_T Bits;
}NU_SCB_SCR_T;
typedef struct
__I NU_SCB_CPUID_T CPUID;//CPUID Base 寄存器
__IO NU_SCB_ICSR_T ICSR;//中断控制状态寄存器
__I NU_REG RESERVED0;
__IO NU_REG_BITs AIRCR;
__IO NU_SCB_SCR_T SCR;//系统控制寄存器
__IO NU_REG_BITs CCR;
__I NU_REG RESERVED1;
union{
__IO NU_REG_BITs SHP[2];//系统处理器优先级寄存器2和3
struct{
__IO NU_REG_BITs SHP2;//系统处理器优先级寄存器2
__IO NU_REG_BITs SHP3;//系统处理器优先级寄存器3
__IO NU_REG_BITs SHCSR;
__I NU_REG RESERVED2[2];
__IO NU_REG_BITs DFSR;
}NU_SCB_Type;
#define SCBs (*((NU_SCB_Type *) SCB_BASE))//定位全局结构变量SCBs
#define SCBx ((NU_SCB_Type *) SCB_BASE)
typedef enum
SysTick_CTRL_TICKENABLE = 0,//
SysTick_CTRL_TICKINT = 1,//
SysTick_CTRL_CLKSRC = 2,//
SysTick_CTRL_COUNTFLAG = 16//
}NU_SysTick_CTRL_ENUM;
typedef struct
__IO NU_REG TICKENABLE:1;
__IO NU_REG TICKINT:1;
__IO NU_REG CLKSRC:1;
__IO NU_REG RESERVE0:13;
__IO NU_REG COUNTFLAG:1;
__IO NU_REG RESERVE1:15;
}SysTick_CTRL_T;
NU_REG Regs;
SysTick_CTRL_T Bits;
}NU_SysTick_CTRL_T;
typedef enum
SysTick_LOAD_RELOAD = 0,//当计数器达到0时,值加载到当前值寄存器
}NU_SysTick_LOAD_ENUM;
typedef struct
__IO NU_REG RELOAD:24;
__IO NU_REG RESERVE:8;
}SysTick_LOAD_T;
NU_REG Regs;
SysTick_LOAD_T Bits;
}NU_SysTick_LOAD_T;
typedef enum
SysTick_VAL_CURRENT = 0,//当前计数值,为采样时刻的计数器的值
}NU_SysTick_VAL_ENUM;
typedef struct
__IO NU_REG CURRENT:24;
}SysTick_VAL_T;
NU_REG Regs;
SysTick_VAL_T Bits;
}NU_SysTick_VAL_T;
typedef struct
__IO NU_SysTick_CTRL_T CTRL;//SysTick控制与状态
__IO NU_SysTick_LOAD_T LOAD;//SysTick重新加载值
__IO NU_SysTick_VAL_T VAL;//SysTick当前值
__I NU_REG_BITs CALIB;
}NU_SysTick_Type;
#define SysTicks (*((NU_SysTick_Type *) SysTick_BASE))//定位全局结构变量SysTicks
#define SysTickx ((NU_SysTick_Type *) SysTick_BASE)
typedef struct
__IO NU_REG_BITs DHCSR;
__O NU_REG_BITs DCRSR;
__IO NU_REG_BITs DCRDR;
__IO NU_REG_BITs DEMCR;
}NU_CoreDebug_Type;
#define CoreDebugs (*((NU_CoreDebug_Type *) CoreDebug_BASE))//定位全局结构变量CoreDebugs
#define CoreDebugx ((NU_CoreDebug_Type *) CoreDebug_BASE)
#ifdef __cplusplus
#endif /* __M051Seriescfg_H__ */
Smpl_LED.c
/* Copyright(c) 2009 Nuvoton Technology Corp. All rights reserved. */
#include <stdio.h>
//#include "M051Seriescfg.h"
#include "M051Seriescfg.h"//加入菜农头文件
#include "Driver\DrvGPIO.h"
#include "Driver\DrvSYS.h"
void delay_loop(void)
uint32_t j;
for(j=0;j<60000;j++);
/* MAIN function */
int main (void)
// E_DRVGPIO_PIN sPinNumber;
/* SYSCLK =>12Mhz*/
UNLOCKREG();
// SYSCLK->PWRCON.XTL12M_EN = 1;
SYSCLKs.PWRCON.Bits.XTL12M_EN = 1;
LOCKREG();
/*set GP0 outpui*/
for(sPinNumber=E_PIN0;sPinNumber<=E_PIN7;sPinNumber++)
DrvGPIO_Open(E_PORT0,sPinNumber, E_IO_OUTPUT);
DrvGPIO_Open(E_PORT1,sPinNumber, E_IO_OUTPUT);
DrvGPIO_Open(E_PORT2,sPinNumber, E_IO_OUTPUT);
DrvGPIO_Open(E_PORT3,sPinNumber, E_IO_OUTPUT);
DrvGPIO_Open(E_PORT4,sPinNumber, E_IO_OUTPUT);
// DrvGPIO_Open(E_PORT3,E_PIN6, E_IO_OUTPUT);
PORT3s.PMD.Bits.PMD6 = E_IO_OUTPUT;
PORT3s.DOUT.Bits.Pin6 ^= 1;
delay_loop();
DrvGPIO_ClrBit(E_PORT0,sPinNumber);
DrvGPIO_ClrBit(E_PORT1,sPinNumber);
DrvGPIO_ClrBit(E_PORT2,sPinNumber);
DrvGPIO_ClrBit(E_PORT3,sPinNumber);
DrvGPIO_ClrBit(E_PORT4,sPinNumber);
// DrvGPIO_ClrBit(E_PORT3,E_PIN6);
// P3s.DOUT.Bits.Pin6 = 0;
// delay_loop();
DrvGPIO_SetBit(E_PORT0,sPinNumber);
DrvGPIO_SetBit(E_PORT1,sPinNumber);
DrvGPIO_SetBit(E_PORT2,sPinNumber);
DrvGPIO_SetBit(E_PORT3,sPinNumber);
DrvGPIO_SetBit(E_PORT4,sPinNumber);
// DrvGPIO_SetBit(E_PORT3,E_PIN6);
// P3s.DOUT.Bits.Pin6 = 1;
// delay_loop();
