#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd E:/psp/NIOSTEST/software/hello_world/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="E:/psp/NIOSTEST/NIOSTEST.sof" --
output="NIOSTEST.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=NIOST
EST.opt E:/psp/NIOSTEST/NIOSTEST.sof NIOSTEST.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 70 megabytes
Info: Processing ended: Fri Dec 03 16:15:21 2010
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:03
Info: Command: quartus_cpf --no_banner --convert NIOSTEST.pof NIOSTEST.rpd
Info: Peak virtual memory: 68 megabytes
Info: Processing ended: Fri Dec 03 16:15:25 2010
Info: Elapsed time: 00:00:04
Info: Total CPU time (on all processors): 00:00:04
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x01001800 --cable='B
yteBlasterII [LPT1]' "NIOSTEST.flash"
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: FAILED
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="NIOSTEST.flash" --input="hello_w
orld.elf" --output="epcs.flash"
# Programming flash with the project
yteBlasterII [LPT1]' "epcs.flash"
Leaving target processor paused |
