STM32F做的PMSM电机控制程序
signed char SectorTable[] = {-1,4,2,3,0,5,1,-1};//hc hb ha
// These are the definitions for various angles used in the SVM
// routine. A 16-bit unsigned value is used as the angle variable.
// The SVM algorithm determines the 60 degree sector
#define VECTOR1 0 // 0 degrees
#define VECTOR2 0x2aaa // 60 degrees
#define VECTOR3 0x5555 // 120 degrees
#define VECTOR4 0x8000 // 180 degrees
#define VECTOR5 0xaaaa // 240 degrees
#define VECTOR6 0xd555 // 300 degrees
#define SIXTY_DEG 0x2aaa
#define PHASE_ZERO 57344
#define PHASE_ONE (unsigned int) ((PHASE_ZERO + 65536/6) % 65536)//2730
#define PHASE_TWO (unsigned int) ((PHASE_ONE + 65536/6) % 65536)//13652
#define PHASE_THREE (unsigned int )((PHASE_TWO + 65536/6) % 65536)//24574
#define PHASE_FOUR (unsigned int )((PHASE_THREE + 65536/6) % 65536)//35496
#define PHASE_FIVE (unsigned int) ((PHASE_FOUR + 65536/6) % 65536//46418
int PTPER = (CKTIM/(PWM_FREQ*2) -1)>>1;
const int sinetable[] =
{0,201,401,602,803,1003,1204,1404,1605,1805,
2005,2206,2406,2606,2806,3006,3205,3405,3605,3804,4003,4202,4401,4600,
4799,4997,5195,5393,5591,5789,5986,6183,6380,6577,6773,6970,7166,7361,
7557,7752,7947,8141,8335,8529,8723,8916,9109,9302,9494,9686,9877,10068,
10259,10449,10639,10829,11018,11207,11395,11583,11771,11958,12144,
12331,12516,12701,12886,13070,13254,13437,13620,13802,13984,14165,
14346,14526,14706,14885,15063,15241,15419,15595,15772,15947,16122,
16297,16470,16643,16816,16988,17159,17330,17500,17669,17838,18006,
18173,18340,18506,18671,18835,18999,19162,19325,19487,19647,19808,
19967,20126,20284,20441,20598,20753,20908,21062,21216,21368,21520,
21671,21821,21970,22119,22266,22413,22559,22704,22848,22992,23134,
23276,23417,23557,23696,23834,23971,24107,24243,24377,24511,24644,
24776,24906,25036,25165,25293,25420,25547,25672,25796,25919,26042,
26163,26283,26403,26521,26638,26755,26870,26984,27098,27210,27321,
27431,27541,27649,27756,27862,27967,28071,28174,28276,28377};
void SVM2(int volts, unsigned int angle)
// These variables hold the normalized sector angles used to find
// t1, t2.
unsigned int angle1, angle2;
// These variables hold the space vector times.
unsigned int half_t0,t1,t2;//tpwm;
// Calculate the total PWM count period, which is twice the value
// in the PTPER register.
//tpwm = PTPER << 1;//PTPER = (FCY/FPWM - 1) >> 1;
// Limit volts input to avoid overmodulation.
//if(volts > VOLTS_LIMIT) volts = VOLTS_LIMIT;
if(angle < VECTOR2)
angle2 = angle - VECTOR1; // Reference SVM angle to the current
// sector
angle1 = SIXTY_DEG - angle2; // Calculate second angle referenced to
// sector
t1 = sinetable[(unsigned char)(angle1 >> 6)]; // Look up values from
// table.
t2 = sinetable[(unsigned char)(angle2 >> 6)];
// Scale t1 to by the volts variable.
t1 = ((long)t1*(long)volts) >> 15;
// Scale t1 for the duty cycle range.
t1 = ((long)t1*(long)T_SQRT3) >> 15;
// Scale t2 time
t2 = ((long)t2*(long)volts) >> 15;
t2 = ((long)t2*(long)T) >> 15;
half_t0 = (T - t1 - t2) >> 1; // Calculate half_t0 null time from
// period and t1,t2
// Calculate duty cycles for Sector 1 (0 - 59 degrees)
PhaseADuty = t1 + t2 + half_t0;
PhaseBDuty = t2 + half_t0;
PhaseCDuty = half_t0;
else if(angle < VECTOR3)
angle2 = angle - VECTOR2; // Reference SVM angle to the current
// sector
// sector
// table.
// Scale t2 time
// period and t1,t2
// Calculate duty cycles for Sector 2 (60 - 119 degrees)
PhaseADuty = t1 + half_t0;
PhaseBDuty = t1 + t2 + half_t0;
else if(angle < VECTOR4)
angle2 = angle - VECTOR3; // Reference SVM angle to the current
// sector
// sector
// table.
// Scale t2 time
// period and t1,t2
// Calculate duty cycles for Sector 3 (120 - 179 degrees)
PhaseADuty = half_t0;
PhaseCDuty = t2 + half_t0;
else if(angle < VECTOR5)
angle2 = angle - VECTOR4; // Reference SVM angle to the current
// sector
// sector
// table.
// Scale t2 time
// period and t1,t2
// Calculate duty cycles for Sector 4 (180 - 239 degrees)
PhaseBDuty = t1 + half_t0;
PhaseCDuty = t1 + t2 + half_t0;
else if(angle < VECTOR6)
angle2 = angle - VECTOR5; // Reference SVM angle to the current
// sector
// sector
// table.
// Scale t2 time
// period and t1,t2
// Calculate duty cycles for Sector 5 (240 - 299 degrees)
PhaseADuty = t2 + half_t0;
PhaseBDuty = half_t0;
angle2 = angle - VECTOR6; // Reference SVM angle to the current
// sector
// sector
// table.
// Scale t2 time
// period and t1,t2
// Calculate duty cycles for Sector 6 ( 300 - 359 degrees )
PhaseCDuty = t1 + half_t0;
TIM1->CCR1 = PhaseADuty;
TIM1->CCR2 = PhaseBDuty;
TIM1->CCR3 = PhaseCDuty;
} // end SVM()
void ForceCommutation(void)
HALL.HB = GPIO_ReadInputDataBit(HAPORT,HAPIN);
HALL.HA = GPIO_ReadInputDataBit(HBPORT,HBPIN);
HALL.HC = GPIO_ReadInputDataBit(HCPORT,HCPIN);
//添加中断处理程序
PingPang = 1;
// EXTI_ClearITPendingBit(EXTI_Line6);
HALL.HallValue = HALL.HA|HALL.HB<<1|HALL.HC<<2;
HALL.Sector = SectorTable[HALL.HallValue]; // Get Sector from table
if (HALL.Sector != -1) // If the sector is invalid don't do anything
// Depending on the required direction, a new phase is fetched
if (Required_Direction == CW)
// Motor is required to run forward, so read directly the table
Phase = PhaseValues[HALL.Sector];
// Motor is required to run reverse, so calculate new phase and
// add offset to compensate asymmetries
Phase = PhaseValues[(HALL.Sector + 3) % 6] + PhaseOffset;
return;
void TIM1_UP_IRQHandler(void)
TIM1->SR = (u16)~TIM_FLAG_Update;//clear flag
if(MotorStat == MotorRun)
if (Current_Direction == CW)
Phase += PhaseInc;
// if(Phase>120) Phase = 0;
// if(Phase<=0) Phase = 0;
// Increment Phase if CW to generate the
// sinewave only if both directions are equal
// If Required_Direction is CW (forward) POSITIVE voltage is applied
#ifdef PHASE_ADVANCE
SVM(ControlOutput, Phase + PhaseAdvance); // PhaseAdvance addition
// produces the sinewave
// phase shift
#else
// SVM( ControlOutput, 50,HALL.Sector);
SVM2(8000, Phase);
if (Current_Direction == CCW)
Phase -= PhaseInc; // Decrement Phase if CCW to generate
// if(Phase>=120) Phase = 120; // the sinewave only if both
// directions are equal
// If Required_Direction is CCW (reverse) NEGATIVE voltage is applied
SVM(-(ControlOutput+1), Phase + PhaseAdvance);// PhaseAdvance addition
// phase shift
#else
// SVM( ControlOutput, Phase,HALL.Sector);
SVM2(-ControlOutput, Phase);
Tim3+=1;
if(Tim3>14)
PositionCal();
Tim3 = 0;
//编码器是360线,四倍后是1440线。
void PositionCal(void)
static int PrePos; //上一次的位置
int TempPos;//差值 = POSCNT - PREPOS
TempPos = TIM2->CNT - PrePos;
PrePos = TIM2->CNT;
if(TempPos>719) { TempPos -= 1440 ; }//如果大于719则为负数
if(TempPos<(-719)) { TempPos += 1440 ; }//小于-719则为正数
/*if((TempPos<-50)||(TempPos>50))//
{ TempPos = 0;
PhaseInc = 0;
if(TempPos == 0)
PhaseInc = 0;
else if(TempPos<0)
PhaseInc = (-TempPos)*5;//为正X3
Ptpos += (-TempPos*2);//累加位置
// PhaseInc = 0;
PhaseInc = TempPos*5;//为正X3
Ptpos += (TempPos*2);//累加位置
// PhaseInc = 8;//为正X3
// PhaseInc = 0;
电机输出有波形,不知道算法对不对。请高手指点一下,区间的时间计算是否正确 |
