各位:
在μCOS官网提供的xmega128A1移植代码上修改为xmega256A3,再加我的APP程序,出现如下error:
Error[e16]: Segment INTVEC (size: 0x1e4 align: 0x1) is too long for segment definition. At least 0x1e0 more bytes needed. The problem occurred while processing the segment placement command "-Z(CODE)INTVEC=0-(_..X_INTVEC_SIZE-1)", where at the moment of placement the available memory ranges were "CODE:0-3"
Reserved ranges relevant to this placement:
CODE:0-3 ?FILL1
CODE:4-1ef INTVEC
请问怎么修改INTVEC 中断向量区大小?
有人说是XCL与cpu型号不匹配:
我把Linker里 ATxmega128A1.xcl修改为cfgxm256a3.xcl,就会出现FARCODE 未定义的的error:
Fatal Error[e72]: Segment FARCODE must be defined in a segment definition option (-Z, -b or -P) |
