我手头有个usb红外触摸屏, 在windows下插上就可以使用,但在linux下,插上后,加载了usbhid驱动,生了/dev/input/event4及 /dev/input/mouse0两个设备文件 但点击后在X window下鼠标没有任何反应。 cat /dev/input/mouse0后,点击也没有任何输出,我判断是驱动问题。但手头没有该设备的技术资料,只是通过 lsusb -v 得到了些该设备的信息。 下面是lsusb -v 的输出
Bus 005 Device 041: ID 03fc:0588 Elitegroup Computer Systems
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x03fc Elitegroup Computer Systems
idProduct 0x0588
bcdDevice 2.00
iManufacturer 1 Huitoo KIT
iProduct 2 HuiToo Computer INC.
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 98
bNumInterfaces 3
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 2 Mouse
iInterface 3 USB_IR_TouchScreen
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.00
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 683
Report Descriptor: (length is 683)
Item(Global): Usage Page, data= [ 0x01 ] 1
Generic Desktop Controls
Item(Local ): Usage, data= [ 0x02 ] 2
Mouse
Item(Main ): Collection, data= [ 0x01 ] 1
Application
Item(Global): Report ID, data= [ 0x01 ] 1
Item(Local ): Usage, data= [ 0x01 ] 1
Pointer
Item(Main ): Collection, data= [ 0x00 ] 0
Physical
Item(Global): Usage Page, data= [ 0x09 ] 9
Buttons
Item(Local ): Usage Minimum, data= [ 0x01 ] 1
Button 1 (Primary)
Item(Local ): Usage Maximum, data= [ 0x03 ] 3
Button 3 (Tertiary)
Item(Global): Logical Minimum, data= [ 0x00 ] 0
Item(Global): Logical Maximum, data= [ 0x01 ] 1
Item(Global): Report Count, data= [ 0x03 ] 3
Item(Global): Report Size, data= [ 0x01 ] 1
Item(Main ): Input, data= [ 0x02 ] 2
Data Variable Absolute No_Wrap Linear
Preferred_State No_Null_Position Non_Volatile Bitfield
Item(Global): Report Count, data= [ 0x01 ] 1
Item(Global): Report Size, data= [ 0x05 ] 5
Item(Main ): Input, data= [ 0x01 ] 1
Constant Array Absolute No_Wrap Linear
Item(Local ): Usage, data= [ 0x30 ] 48
Direction-X
Item(Local ): Usage, data= [ 0x31 ] 49
Direction-Y
Item(Global): Logical Maximum, data= [ 0xff 0x0f ] 4095
Item(Global): Physical Minimum, data= [ 0x00 ] 0
Item(Global): Physical Maximum, data= [ 0xff 0x0f ] 4095
Item(Global): Report Size, data= [ 0x10 ] 16
Item(Global): Report Count, data= [ 0x02 ] 2
Item(Main ): End Collection, data=none
Item(Global): Usage Page, data= [ 0x0d ] 13
Digitizer
Item(Local ): Usage, data= [ 0x04 ] 4
Touch Screen
Application
Item(Global): Report ID, data= [ 0x02 ] 2
Item(Local ): Usage, data= [ 0x22 ] 34
Finger
Item(Main ): Collection, data= [ 0x02 ] 2
Logical
Item(Local ): Usage, data= [ 0x42 ] 66
Tip Switch
Item(Local ): Usage, data= [ 0x32 ] 50
In Range
Item(Global): Report Count, data= [ 0x06 ] 6
Item(Main ): Input, data= [ 0x03 ] 3
Constant Variable Absolute No_Wrap Linear
Item(Global): Report Size, data= [ 0x08 ] 8
Item(Local ): Usage, data= [ 0x51 ] 81
Contact ID
Item(Global): Unit Exponent, data= [ 0x00 ] 0
Unit Exponent: 0
Item(Global): Unit, data= [ 0x00 ] 0
System: None, Unit: (None)
Direction-X
Item(Global): Physical Maximum, data= [ 0x00 0x00 ] 0
Direction-Y
Logical
Digitizer
Tip Switch
In Range
Contact ID
Unit Exponent: 0
Direction-X
Direction-Y
Logical
Digitizer
Tip Switch
In Range
Contact ID
Unit Exponent: 0
Direction-X
Direction-Y
Logical
Digitizer
Tip Switch
In Range
Contact ID
Unit Exponent: 0
Direction-X
Direction-Y
Logical
Digitizer
Tip Switch
In Range
Contact ID
Unit Exponent: 0
Direction-X
Direction-Y
Logical
Digitizer
Tip Switch
In Range
Contact ID
Unit Exponent: 0
Direction-X
Direction-Y
Logical
Digitizer
Tip Switch
In Range
Contact ID
Unit Exponent: 0
Direction-X
Direction-Y
Logical
Digitizer
Tip Switch
In Range
Contact ID
Unit Exponent: 0
Direction-X
Direction-Y
Logical
Digitizer
Tip Switch
In Range
Contact ID
Unit Exponent: 0
Direction-X
Direction-Y
Logical
Digitizer
Tip Switch
In Range
Contact ID
Unit Exponent: 0
Direction-X
Direction-Y
Digitizer
Item(Local ): Usage, data= [ 0x54 ] 84
Contact Count
Item(Global): Logical Maximum, data= [ 0x0a ] 10
Item(Global): Report ID, data= [ 0x03 ] 3
Item(Local ): Usage, data= [ 0x55 ] 85
Maximum Contact Number
Item(Main ): Feature, data= [ 0x02 ] 2
Item(Local ): Usage, data= [ 0x0e ] 14
(null)
Application
Item(Global): Report ID, data= [ 0x04 ] 4
Item(Local ): Usage, data= [ 0x23 ] 35
(null)
Logical
Item(Local ): Usage, data= [ 0x52 ] 82
Input Mode
Item(Local ): Usage, data= [ 0x53 ] 83
Device Index
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceProtocol 1 Keyboard
iInterface 4 USB_TouchKeyboard
bLength 9
bDescriptorType 33
bcdHID 1.00
bNumDescriptors 1
wDescriptorLength 65
Report Descriptor: (length is 65)
Item(Local ): Usage, data= [ 0x06 ] 6
Keyboard
Application
Item(Global): Usage Page, data= [ 0x07 ] 7
Keyboard
Item(Local ): Usage Minimum, data= [ 0xe0 ] 224
Control Left
Item(Local ): Usage Maximum, data= [ 0xe7 ] 231
GUI Right
Item(Global): Report Count, data= [ 0x08 ] 8
Item(Global): Report Count, data= [ 0x05 ] 5
Item(Global): Usage Page, data= [ 0x08 ] 8
LEDs
NumLock
Item(Local ): Usage Maximum, data= [ 0x05 ] 5
Kana
Item(Main ): Output, data= [ 0x02 ] 2
Item(Main ): Output, data= [ 0x01 ] 1
Item(Global): Logical Maximum, data= [ 0xff 0x00 ] 255
Keyboard
Item(Local ): Usage Minimum, data= [ 0x00 ] 0
No Event
Item(Local ): Usage Maximum, data= [ 0xff 0x00 ] 255
(null)
Item(Main ): Input, data= [ 0x00 ] 0
Data Array Absolute No_Wrap Linear
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 10
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 2
bInterfaceProtocol 0 None
iInterface 5 USB_Touch_Service
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 52
Report Descriptor: (length is 52)
Item(Global): Usage Page, data= [ 0xa0 0xff ] 65440
(null)
(null)
Application
(null)
Physical
Item(Global): Usage Page, data= [ 0xa1 0xff ] 65441
(null)
Item(Local ): Usage, data= [ 0x03 ] 3
(null)
(null)
Item(Global): Logical Minimum, data= [ 0x80 ] 128
Item(Global): Logical Maximum, data= [ 0x7f ] 127
Item(Global): Physical Maximum, data= [ 0xff ] 255
Item(Global): Report Count, data= [ 0x40 ] 64
Item(Local ): Usage, data= [ 0x05 ] 5
(null)
(null)
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
Device Status: 0x0000
(Bus Powered)
通过这些信息, 判断得到第一个设备的hid report size是5. 就是一个普通的鼠标设备。然后我修改了drivers/input/touchscreen/usbtouchscreen.c。
但是结果还是没有反应 |
