![](http://cache.amobbs.com/bbs_upload782111/files_34/ourdev_595856ECTR5Y.jpg)
(原文件名:BXFHimem1.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_34/ourdev_595857XCLZY0.jpg)
(原文件名:BXFHimem2.jpg)
![](http://cache.amobbs.com/bbs_upload782111/files_34/ourdev_595858XEVV7C.jpg)
(原文件名:BXFHimem3.jpg)
这架四轴能完成简单自主飞行(没有遥控)
机架是用很细的的空心铝管
电机看样子用的是直流电机(作者说是从“draganfly”上拆下来的,迷惑)
只用了一个单片机BX24(没听过,说是这个比较快,而且支持浮点数和多任务)
传感器用了2个倾角传感器和一个电子罗盘,没说具体型号
演示效果:
Anyway, after the better part of two years - and after having solved most of the major control problems - I was ready for the BXFHimem's Maiden Flight. Remember, I didn't have an altitude sensor. So I did the best that I could under the circumstances - I had it fly straight up for 10 seconds, decelerate for 2 seconds and then turn-off to land / crash (hopefully gently) on the ground.
And it worked! In fact it survived!! I had matched the Wright brother's first flight time - I was off to celebrate!!!
以下为原文网址
http://www.seattlerobotics.org/encoder/200311/weimer/bxfHimem.html |
