用的是LPC2220,Jlink+IAR,之前在内部RAM中运行程序完全没问题。但换到外部RAM(IS16LV25616AL),就无法进入mian,老是堆栈溢出。
Thu Oct 28 16:00:05 2010: The stack 'CSTACK' is filled to 100% (1280 bytes used out of 1280). The warning threshold is set to 90.%
Thu Oct 28 16:00:05 2010: The stack 'IRQ_STACK' is filled to 100% (256 bytes used out of 256). The warning threshold is set to 90.%
在启动程序部分,每单步一次就会出来这样的警告,想进入main更是不可能。警告上说的什么堆栈已满,其实根本不是这样,我把 'CSTACK' 'IRQ_STACK' 的分配空间调大了也还是如此。但是我用软仿又不会出现这样的错误,能进入main。不知道是什么原因,真神奇。XCL文件不知道会不会出错(我认为没错),外部RAM接的是,BANK0。望高手给予指点。下面是它的XCL,修改于EWARM安装目录下的例程 phytec_pcm023_xram.xcl
// XLINK command file template for EWARM/ICCARM
// Usage: xlink -f lnkarm <your_object_file(s)>
// -s <program start label> <C/C++ runtime library>
// $Revision: 1.1 $
// Code segments - may be placed anywhere in memory.
// INTVEC -- Exception vector table.
// SWITAB -- Software interrupt vector table.
// ICODE -- Startup (cstartup) and exception code.
// DIFUNCT -- Dynamic initialization vectors used by C++.
// CODE -- Compiler generated code.
// CODE_I -- Compiler generated code declared __ramfunc (executes in
RAM)
// CODE_ID -- Initializer for CODE_I (ROM).
// Data segments - may be placed anywhere in memory.
// CSTACK -- The stack used by C/C++ programs (system and user
mode).
// IRQ_STACK -- The stack used by IRQ service routines.
// SVC_STACK -- The stack used in supervisor mode
// (Define other exception stacks as needed for
// FIQ, ABT, UND).
// HEAP -- The heap used by malloc and free in C and new and
// delete in C++.
// INITTAB -- Table containing addresses and sizes of segments that
// need to be initialized at startup (by cstartup).
// CHECKSUM -- The linker places checksum byte(s) in this segment,
// when the -J linker command line option is used.
// DATA_y -- Data objects.
// Where _y can be one of:
// _AN -- Holds uninitialized located objects, i.e. objects with
// an absolute location given by the @ operator or the
// #pragma location directive. Since these segments
// contain objects which already have a fixed address,
// they should not be mentioned in this linker command
// file.
// _C -- Constants (ROM).
// _I -- Initialized data (RAM).
// _ID -- The original content of _I (copied to _I by cstartup)
(ROM).
// _N -- Uninitialized data (RAM).
// _Z -- Zero initialized data (RAM).
// Note: Be sure to use end values for the defined address ranges.
// Otherwise, the linker may allocate space outside the
// intended memory range.
// Inform the linker about the CPU family used.
-carm
// Segment placement - General information
// All numbers in the segment placement command lines below are
interpreted
// as hexadecimal unless they are immediately preceded by a '.', which
// denotes decimal notation.
// When specifying the segment placement using the -P instead of the -Z
// option, the linker is free to split each segment into its segment parts
// and randomly place these parts within the given ranges in order to
// achieve a more efficient memory usage. One disadvantage, however, is
// that it is not possible to find the start or end address (using
// the assembler operators .sfb./.sfe.) of a segment which has been split
// and reformed.
// When generating an output file which is to be used for programming
// external ROM/Flash devices, the -M linker option is very useful
// (see xlink.pdf for details).
// Read-only segments mapped to ROM.
-DROMSTART=80000040
-DROMEND=8007FFFF
// Address range for reset and exception
// vectors (INTVEC).
// The vector area is 32 bytes,
// an additional 32 bytes is allocated for the
// constant table used by ldr PC in cstartup.s79.
-Z(CODE)INTVEC=40000000-4000003F
// Startup code and exception routines (ICODE).
-Z(CODE)ICODE,DIFUNCT=ROMSTART-ROMEND
-Z(CODE)SWITAB=ROMSTART-ROMEND
// Code segments may be placed anywhere.
-Z(CODE)CODE=ROMSTART-ROMEND
// Original ROM location for __ramfunc code copied
// to and executed from RAM.
-Z(CONST)CODE_ID=ROMSTART-ROMEND
// Various constants and initializers.
-Z(CONST)INITTAB,DATA_ID,DATA_C=ROMSTART-ROMEND
-Z(CONST)CHECKSUM=ROMSTART-ROMEND
// Read/write segments mapped to RAM.
-DRAMSTART=81000000
-DRAMEND=8107FFFF
// Data segments.
-Z(DATA)DATA_I,DATA_Z,DATA_N=RAMSTART-RAMEND
// __ramfunc code copied to and executed from RAM.
-Z(DATA)CODE_I=RAMSTART-RAMEND
// ICCARM produces code for __ramfunc functions in
// CODE_I segments. The -Q XLINK command line
// option redirects XLINK to emit the code in the
// CODE_ID segment instead, but to keep symbol and
// debug information associated with the CODE_I
// segment, where the code will execute.
-QCODE_I=CODE_ID
// Stack and heap segments.
-D_CSTACK_SIZE=1000
// -D_SVC_STACK_SIZE=10
-D_IRQ_STACK_SIZE=100
-D_HEAP_SIZE=100
-Z(DATA)CSTACK+_CSTACK_SIZE=RAMSTART-RAMEND
// -Z(DATA)SVC_STACK+_SVC_STACK_SIZE=RAMSTART-RAMEND
-Z(DATA)IRQ_STACK+_IRQ_STACK_SIZE,HEAP+_HEAP_SIZE=RAMSTART-RAMEND
// ELF/DWARF support.
// Uncomment the line "-Felf" below to generate ELF/DWARF output.
// Available format specifiers are:
// "-yn": Suppress DWARF debug output
// "-yp": Multiple ELF program sections
// "-yas": Format suitable for debuggers from ARM Ltd (also sets -p
flag)
// "-Felf" and the format specifiers can also be supplied directly as
// command line options, or selected from the Xlink Output tab in the
// IAR Embedded Workbench.
// -Felf |
