Software Driver
SST25VF016B 16 Mbit(2M x 8) Serial Flash Memory
February 19th, 2009, Rev. 1.1
ABOUT THE SOFTWARE
This application note provides software driver examples for SST25VF016B,
Serial Flash. Extensive comments are included in each routine to describe
the function of each routine. The interface coding uses polling method
rather than the SPI protocol to interface with these serial devices. The
functions are differentiated below in terms of the communication protocols
(uses Mode 0) and specific device operation instructions. This code has been
designed to compile using the Keil compiler.
ABOUT THE SST25VF016B
Companion product datasheets for the SST25VF016B should be reviewed in
conjunction with this application note for a complete understanding
of the device.
Device Communication Protocol(pinout related) functions:
Functions Function
init Initializes clock to set up mode 0.
Send_Byte Sends one byte using SI pin to send and
shift out 1-bit per clock rising edge
Get_Byte Receives one byte using SO pin to receive and shift
in 1-bit per clock falling edge
Poll_SO Used in the polling for RY/BY# of SO during AAI programming
CE_High Sets Chip Enable pin of the serial flash to high
CE_Low Clears Chip Enable of the serial flash to low
Hold_Low Clears Hold pin to make serial flash hold
Unhold Unholds the serial flash
WP_Low Clears WP pin to make serial flash write protected
UnWP Disables write protection pin
Note: The pin names of the SST25VF016B are used in this application note. The associated test code
will not compile unless these pinouts (SCK, SI, SO, SO, CE, WP, Hold) are pre-defined on your
software which should reflect your hardware interfaced.
Device Operation Instruction functions:
Functions Function
Read_Status_Register Reads the status register of the serial flash
EWSR Enables the Write Status Register
WRSR Performs a write to the status register
WREN Write enables the serial flash
WRDI Write disables the serial flash
EBSY Enable SO to output RY/BY# status during AAI programming
DBSY Disable SO to output RY/BY# status during AAI programming
Read_ID Reads the manufacturer ID and device ID
Jedec_ID_Read Reads the Jedec ID
Read Reads one byte from the serial flash and returns byte(max of 25 MHz CLK frequency)
Read_Cont Reads multiple bytes(max of 25 MHz CLK frequency)
HighSpeed_Read Reads one byte from the serial flash and returns byte(max of 50 MHz CLK frequency)
HighSpeed_Read_Cont Reads multiple bytes(max of 50 MHz CLK frequency)
Byte_Program Program one byte to the serial flash
Auto_Add_IncA Initial Auto Address Increment process
Auto_Add_IncB Successive Auto_Address_Increment process after AAI initiation
Auto_Add_IncA_EBSY Initial Auto Address Increment process with EBSY
Auto_Add_IncB_EBSY Successive Auto_Address_Increment process after AAI initiation with EBSY
Chip_Erase Erases entire serial flash
Sector_Erase Erases one sector (4 KB) of the serial flash
Block_Erase_32K Erases 32 KByte block memory of the serial flash
Block_Erase_64K Erases 64 KByte block memory of the serial flash
Wait_Busy Polls status register until busy bit is low
Wait_Busy_AAI Polls status register until busy bit is low for AAI programming
WREN_Check Checks to see if WEL is set
WREN_AAI_Check Checks to see if WEL and AAI mode is set
"C" LANGUAGE DRIVERS
/* Copyright Silicon Storage Technology, Inc. (SST), 1994-2009 */
/* Example "C" language Driver of SST25VF016B Serial Flash */
/* Conrado Canio, Silicon Storage Technology, Inc. */
/* Revision 1.0, August 1st, 2005 */
/* Revision 1.1, February 19th, 2009 */
/* - Modified Wait_Busy() and Wait_Busy_AAI() procedures */
/* to Work for both protected and unprotected Flash */
#include <stdio.h>
#include <stdlib.h>
sbit SCK = P0^0;
sbit SI = P0^1;
sbit SO = P0^2;
sbit CE = P0^3;
sbit Hold = P0^4;
sbit WP = P0^5;
sbit SCLK =P1^4;
sbit MISO =P1^6;
sbit MISI =P1^5;
sbit CS =P1^3;
sbit CE = P1^3;
sbit SCK = P1^4;
sbit SI = P1^5;
sbit SO = P1^6;
//sbit Hold = P0^4;
//sbit WP = P0^5;
/* Function Prototypes */
void init();
void Send_Byte(unsigned char out);
unsigned char Get_Byte();
void Poll_SO();
void CE_High();
void CE_Low();
void Hold_Low();
void Unhold();
void WP_Low();
void UnWP();
unsigned char Read_Status_Register();
void EWSR();
void WRSR(byte);
void WREN();
void WRDI();
void EBSY();
void DBSY();
unsigned char Read_ID(ID_addr);
unsigned long Jedec_ID_Read();
unsigned char Read(unsigned long Dst);
void Read_Cont(unsigned long Dst, unsigned long no_bytes);
unsigned char HighSpeed_Read(unsigned long Dst);
void HighSpeed_Read_Cont(unsigned long Dst, unsigned long no_bytes);
void Byte_Program(unsigned long Dst, unsigned char byte);
void Auto_Add_IncA(unsigned long Dst, unsigned char byte1, unsigned char byte2);
void Auto_Add_IncB(unsigned char byte1, unsigned char byte2);
void Auto_Add_IncA_EBSY(unsigned long Dst, unsigned char byte1, unsigned char byte2);
void Auto_Add_IncB_EBSY(unsigned char byte1, unsigned char byte2);
void Chip_Erase();
void Sector_Erase(unsigned long Dst);
void Block_Erase_32K(unsigned long Dst);
void Block_Erase_64K(unsigned long Dst);
void Wait_Busy();
void Wait_Busy_AAI();
void WREN_Check();
void WREN_AAI_Check();
void Verify(unsigned char byte, unsigned char cor_byte);
//unsigned char idata upper_128[128]; /* global array to store read data */
unsigned char xdata upper_128[128]; /* global array to store read data */
/* to upper RAM area from 80H - FFH */
/* PROCEDURE: init */
/* This procedure initializes the SCK to low. Must be called prior to */
/* setting up mode 0. */
/* Input: */
/* None */
/* Output: */
/* SCK */
void init()
SCK = 0; /* set clock to low initial state */
/* PROCEDURE: Send_Byte */
/* This procedure outputs a byte shifting out 1-bit per clock rising */
/* edge on the the SI pin(LSB 1st). */
/* Input: */
/* out */
/* Output: */
/* SI */
unsigned char i = 0;
for (i = 0; i < 8; i++)
if ((out & 0x80) == 0x80) /* check if MSB is high */
SI = 1;
SI = 0; /* if not, set to low */
SCK = 1; /* toggle clock high */
out = (out << 1); /* shift 1 place for next bit */
SCK = 0; /* toggle clock low */
/* PROCEDURE: Get_Byte */
/* This procedure inputs a byte shifting in 1-bit per clock falling */
/* edge on the SO pin(LSB 1st). */
/* Input: */
/* SO */
/* Output: */
/* None */
unsigned char i = 0, in = 0, temp = 0;
in = (in << 1); /* shift 1 place to the left or shift in 0 */
temp = SO; /* save input */
if (temp == 1) /* check to see if bit is high */
in = in | 0x01; /* if high, make bit high */
return in;
/* PROCEDURE: Poll_SO */
/* This procedure polls for the SO line during AAI programming */
/* waiting for SO to transition to 1 which will indicate AAI programming*/
/* is completed */
/* Input: */
/* SO */
/* Output: */
/* None */
void Poll_SO()
unsigned char temp = 0;
CE_Low();
while (temp == 0x00) /* waste time until not busy */
temp = SO;
CE_High();
/* PROCEDURE: CE_High */
/* This procedure set CE = High. */
/* Input: */
/* None */
/* Output: */
/* CE */
void CE_High()
CE = 1; /* set CE high */
/* PROCEDURE: CE_Low */
/* This procedure drives the CE of the device to low. */
/* Input: */
/* None */
/* Output: */
/* CE */
void CE_Low()
CE = 0; /* clear CE low */
/* PROCEDURE: Hold() */
/* This procedure clears the Hold pin to low. */
/* Input: */
/* None */
/* Output: */
/* Hold */
void Hold_Low()
// Hold = 0; /* clear Hold pin */
/* PROCEDURE: Unhold() */
/* This procedure sets the Hold pin to high. */
/* Input: */
/* None */
/* Output: */
/* Hold */
void Unhold()
// Hold = 1; /* set Hold pin */
/* PROCEDURE: WP() */
/* This procedure clears the WP pin to low. */
/* Input: */
/* None */
/* Output: */
/* WP */
void WP_Low()
//WP = 0; /* clear WP pin */
/* PROCEDURE: UnWP() */
/* This procedure sets the WP pin to high. */
/* Input: */
/* None */
/* Output: */
/* WP */
void UnWP()
//WP = 1; /* set WP pin */
/* PROCEDURE: Read_Status_Register */
/* This procedure read the status register and returns the byte. */
/* Input: */
/* None */
/* Returns: */
/* byte */
unsigned char byte = 0;
CE_Low(); /* enable device */
Send_Byte(0x05); /* send RDSR command */
byte = Get_Byte(); /* receive byte */
CE_High(); /* disable device */
return byte;
/* PROCEDURE: EWSR */
/* This procedure Enables Write Status Register. */
/* Input: */
/* None */
/* Returns: */
/* Nothing */
void EWSR()
Send_Byte(0x50); /* enable writing to the status register */
/* PROCEDURE: WRSR */
/* This procedure writes a byte to the Status Register. */
/* Input: */
/* byte */
/* Returns: */
/* Nothing */
void WRSR(byte)
Send_Byte(0x01); /* select write to status register */
Send_Byte(byte); /* data that will change the status of BPx
or BPL (only bits 2,3,4,5,7 can be written) */
CE_High(); /* disable the device */
/* PROCEDURE: WREN */
/* This procedure enables the Write Enable Latch. It can also be used */
/* to Enables Write Status Register. */
/* Input: */
/* None */
/* Returns: */
/* Nothing */
void WREN()
Send_Byte(0x06); /* send WREN command */
/* PROCEDURE: WRDI */
/* This procedure disables the Write Enable Latch. */
/* Input: */
/* None */
/* Returns: */
/* Nothing */
void WRDI()
Send_Byte(0x04); /* send WRDI command */
/* PROCEDURE: EBSY */
/* This procedure enable SO to output RY/BY# status during AAI */
/* programming. */
/* Input: */
/* None */
/* Returns: */
/* Nothing */
void EBSY()
Send_Byte(0x70); /* send EBSY command */
/* PROCEDURE: DBSY */
/* This procedure disable SO as output RY/BY# status signal during AAI */
/* programming. */
/* Input: */
/* None */
/* Returns: */
/* Nothing */
void DBSY()
Send_Byte(0x80); /* send DBSY command */
/* PROCEDURE: Read_ID */
/* This procedure Reads the manufacturer's ID and device ID. It will */
/* use 90h or ABh as the command to read the ID (90h in this sample). */
/* It is up to the user to give the last byte ID_addr to determine */
/* whether the device outputs manufacturer's ID first, or device ID */
/* first. Please see the product datasheet for details. Returns ID in */
/* variable byte. */
/* Input: */
/* ID_addr */
/* Returns: */
/* byte: ID1(Manufacture's ID = BFh or Device ID = 80h) */
unsigned char byte;
Send_Byte(0x90); /* send read ID command (90h or ABh) */
Send_Byte(0x00); /* send address */
Send_Byte(ID_addr); /* send address - either 00H or 01H */
return byte;
/* PROCEDURE: Jedec_ID_Read */
/* This procedure Reads the manufacturer's ID (BFh), memory type (25h) */
/* and device ID (41h). It will use 9Fh as the JEDEC ID command. */
/* Please see the product datasheet for details. */
/* Input: */
/* None */
/* Returns: */
/* IDs_Read:ID1(Manufacture's ID = BFh, Memory Type (25h), */
/* and Device ID (80h) */
unsigned long temp;
temp = 0;
Send_Byte(0x9F); /* send JEDEC ID command (9Fh) */
temp = (temp | Get_Byte()) << 8; /* receive byte */
temp = (temp | Get_Byte()); /* temp value = 0xBF2541 */
return temp;
/* PROCEDURE: Read */
/* This procedure reads one address of the device. It will return the */
/* byte read in variable byte. */
/* Input: */
/* Dst: Destination Address 000000H - 1FFFFFH */
/* Returns: */
/* byte */
Send_Byte(0x03); /* read command */
Send_Byte(((Dst & 0xFFFFFF) >> 16)); /* send 3 address bytes */
Send_Byte(((Dst & 0xFFFF) >> 8));
Send_Byte(Dst & 0xFF);
byte = Get_Byte();
return byte; /* return one byte read */
/* PROCEDURE: Read_Cont */
/* This procedure reads multiple addresses of the device and stores */
/* data into 128 byte buffer. Maximum byte that can be read is 128 bytes*/
/* Input: */
/* no_bytes Number of bytes to read (max = 128) */
/* Returns: */
/* Nothing */
unsigned long i = 0;
for (i = 0; i < no_bytes; i++) /* read until no_bytes is reached */
upper_128 = Get_Byte(); /* receive byte and store at address 80H - FFH */
/* PROCEDURE: HighSpeed_Read */
/* Input: */
/* Returns: */
/* byte */
Send_Byte(0x0B); /* read command */
Send_Byte(0xFF); /*dummy byte*/
byte = Get_Byte();
/* PROCEDURE: HighSpeed_Read_Cont */
/* Input: */
/* Returns: */
/* Nothing */
/* PROCEDURE: Byte_Program */
/* This procedure programs one address of the device. */
/* Assumption: Address being programmed is already erased and is NOT */
/* block protected. */
/* Input: */
/* byte: byte to be programmed */
/* Returns: */
/* Nothing */
Send_Byte(0x02); /* send Byte Program command */
Send_Byte(byte); /* send byte to be programmed */
/* PROCEDURE: Auto_Add_IncA */
/* This procedure programs consecutive addresses of 2 bytes of data into*/
/* the device: 1st data byte will be programmed into the initial */
/* address [A23-A1] and with A0 = 0. The 2nd data byte will be be */
/* programmed into initial address [A23-A1] and with A0 = 1. This */
/* is used to to start the AAI process. It should be followed by */
/* Auto_Add_IncB. */
/* Note: Only RDSR command can be executed once in AAI mode with SO */
/* disable to output RY/BY# status. Use WRDI to exit AAI mode */
/* unless AAI is programming the last address or last address of */
/* unprotected block, which automatically exits AAI mode. */
/* Input: */
/* byte1: 1st byte to be programmed */
/* byte1: 2nd byte to be programmed */
/* Returns: */
/* Nothing */
Send_Byte(0xAD); /* send AAI command */
Send_Byte(byte1); /* send 1st byte to be programmed */
Send_Byte(byte2); /* send 2nd byte to be programmed */
/* PROCEDURE: Auto_Add_IncB */
/* is used after Auto_Address_IncA. */
/* Note: Only WRDI and AAI command can be executed once in AAI mode */
/* with SO enabled as RY/BY# status. When the device is busy */
/* asserting CE# will output the status of RY/BY# on SO. Use WRDI*/
/* to exit AAI mode unless AAI is programming the last address or */
/* last address of unprotected block, which automatically exits */
/* AAI mode. */
/* Input: */
/* byte2: 2nd byte to be programmed */
/* Returns: */
/* Nothing */
/* PROCEDURE: Auto_Add_IncA_EBSY */
/* This procedure is the same as procedure Auto_Add_IncA except that it */
/* uses EBSY and Poll_SO functions to check for RY/BY. It programs */
/* consecutive addresses of the device. The 1st data byte will be */
/* programmed into the initial address [A23-A1] and with A0 = 0. The */
/* 2nd data byte will be programmed into initial address [A23-A1] and */
/* with A0 = 1. This is used to to start the AAI process. It should */
/* be followed by Auto_Add_IncB_EBSY. */
/* AAI mode. */
/* Input: */
/* Returns: */
/* Nothing */
EBSY(); /* enable RY/BY# status for SO in AAI */
Poll_SO(); /* polls RY/BY# using SO line */
/* PROCEDURE: Auto_Add_IncB_EBSY */
/* This procedure is the same as Auto_Add_IncB excpet that it uses */
/* Poll_SO to poll for RY/BY#. It demonstrate on how to use DBSY after */
/* AAI programmming is completed. It programs consecutive addresses of */
/* the device. The 1st data byte will be programmed into the initial */
/* address [A23-A1] and with A0 = 0. The 2nd data byte will be */
/* programmed into initial address [A23-A1] and with A0 = 1. This is */
/* used after Auto_Address_IncA. */
/* AAI mode. */
/* Input: */
/* Returns: */
/* Nothing */
WRDI(); /* Exit AAI before executing DBSY */
DBSY(); /* disable SO as RY/BY# output if in AAI */
/* PROCEDURE: Chip_Erase */
/* This procedure erases the entire Chip. */
/* Input: */
/* None */
/* Returns: */
/* Nothing */
void Chip_Erase()
Send_Byte(0x60); /* send Chip Erase command (60h or C7h) */
/* PROCEDURE: Sector_Erase */
/* This procedure Sector Erases the Chip. */
/* Input: */
/* Returns: */
/* Nothing */
Send_Byte(0x20); /* send Sector Erase command */
/* PROCEDURE: Block_Erase_32K */
/* This procedure Block Erases 32 KByte of the Chip. */
/* Input: */
/* Returns: */
/* Nothing */
Send_Byte(0x52); /* send 32 KByte Block Erase command */
/* PROCEDURE: Block_Erase_64K */
/* This procedure Block Erases 64 KByte of the Chip. */
/* Input: */
/* Returns: */
/* Nothing */
Send_Byte(0xD8); /* send 64KByte Block Erase command */
/* PROCEDURE: Wait_Busy */
/* This procedure waits until device is no longer busy (can be used by */
/* Byte-Program, Sector-Erase, Block-Erase, Chip-Erase). */
/* Input: */
/* None */
/* Returns: */
/* Nothing */
void Wait_Busy()
while ((Read_Status_Register() & 0x03) == 0x03) /* waste time until not busy */
/* PROCEDURE: Wait_Busy_AAI */
/* This procedure waits until device is no longer busy for AAI mode. */
/* Input: */
/* None */
/* Returns: */
/* Nothing */
while ((Read_Status_Register() & 0x43) == 0x43) /* waste time until not busy */
/* PROCEDURE: WREN_Check */
/* This procedure checks to see if WEL bit set before program/erase. */
/* Input: */
/* None */
/* Returns: */
/* Nothing */
void WREN_Check()
unsigned char byte;
byte = Read_Status_Register(); /* read the status register */
if (byte != 0x02) /* verify that WEL bit is set */
while(1);
/* add source code or statements for this file */
/* to compile */
/* i.e. option: insert a display to view error on LED? */
/* option: insert a display to view error on LED? */
/* PROCEDURE: WREN_AAI_Check */
/* This procedure checks for AAI and WEL bit once in AAI mode. */
/* Input: */
/* None */
/* Returns: */
/* Nothing */
unsigned char byte;
if (byte != 0x42) /* verify that AAI and WEL bit is set */
while(1);
/* to compile */
/* PROCEDURE: Verify */
/* This procedure checks to see if the correct byte has be read. */
/* Input: */
/* byte: byte read */
/* cor_byte: correct_byte that should be read */
/* Returns: */
/* Nothing */
if (byte != cor_byte)
while(1);
/* add source code or statement for this file */
/* to compile */
int main()
return 0;
void main()
Read_ID
return 0;
单片机用的是89C52,晶振22.1184,单片机用的5V供电,SST25VF016B 用3.3V单独供电,89C52和SST25VF016的IO串接1K电阻,
现在,无法读写,哪位有使用过的程序,我验证下电路部分,非常感谢 |
