芯片是EP2C5Q208,我现在的板子上PIN-108是按照通用IO设计的,没接任何上下拉电阻,直接连接VGA接口的vsync,今天我弄了一个简单的测试程序,在fitter那一步出现一个错误:
Info: Fitter converted 3 user pins into dedicated programming pins
Info: Pin ~ASDO~ is reserved at location 1
Info: Pin ~nCSO~ is reserved at location 2
Info: Pin ~LVDS41p/nCEO~ is reserved at location 108
Warning: Reserve pin assignment ignored because of existing pin with name "vsync"
Error: Can't place node ~LVDS41p/nCEO~ in location 108 because location already occupied by node vsync
Error: Live I/O check failed
我看了一下EP2C5的DATASHEET,nCEO--“Output that drives low when device configuration is complete. During multi-device configuration, this pin feeds a subsequent device’s nCE pin and must be pulled high to Vccio by an external 10kΩ pull-up resistor. During single device configuration and for the last device in multi-device configuration, this pin can be used as an user I/O after configuration.”
这里有几个问题想问问大家
multi-device configuration和single device configuration指的是什么意思?
这里说配置之后可以作为用户IO使用,如何配置(quartus Ⅱ8.0),也就是说如何配置管脚的general function和special function?
谢谢大家啦! |
