发表于 2010-10-16 11:09:15
我也贴一下代码:
void main()
WDTCTL = WDTHOLD + WDTPW;
// 初始化SPI接口
SPISetup();
_NOP();
PowerupResetCCxxxx();
// 测试SPI
SPIWriteReg(TI_CCxxx0_IOCFG0, 0x09);
testValue = SPIReadReg(TI_CCxxx0_IOCFG0);
_NOP();
_NOP();
void SPISetup(void)
TI_CC_CSn_PxDIR |= TI_CC_CSn_PIN; // /CS disable
TI_CC_CSn_PxOUT |= TI_CC_CSn_PIN;
UCB0CTL0 |= UCMST+UCCKPL+UCMSB+UCSYNC; // 3-pin, 8-bit SPI master
UCB0CTL1 |= UCSSEL_2; // SMCLK
UCB0BR0 |= 0x02; // UCLK/2
UCB0BR1 = 0;
//UCB0MCTL = 0;
TI_CC_SPI_USCIB0_PxSEL |= TI_CC_SPI_USCIB0_SIMO | TI_CC_SPI_USCIB0_SOMI | TI_CC_SPI_USCIB0_UCLK;
// SPI option select
TI_CC_SPI_USCIB0_PxDIR |= TI_CC_SPI_USCIB0_SIMO | TI_CC_SPI_USCIB0_UCLK;
// SPI TXD out direction
UCB0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
// Delay function. # of CPU cycles delayed is similar to "cycles". Specifically,
// it's ((cycles-15) % 6) + 15. Not exact, but gives a sense of the real-time
// delay. Also, if MCLK ~1MHz, "cycles" is similar to # of useconds delayed.
void Wait(unsigned int cycles)
while(cycles>15) // 15 cycles consumed by overhead
cycles = cycles - 6; // 6 cycles consumed each iteration
void SPIWriteReg(char addr, char value)
TI_CC_CSn_PxOUT &= ~TI_CC_CSn_PIN; // /CS enable
while (TI_CC_SPI_USCIB0_PxIN&TI_CC_SPI_USCIB0_SOMI); // Wait for CCxxxx ready
IFG2 &= ~UCB0RXIFG; // Clear flag
UCB0TXBUF = (addr | TI_CCxxx0_READ_SINGLE); // Send address ( addr | 0x80)
while (!(IFG2&UCB0RXIFG)); // Wait for TX to finish
UCB0TXBUF = value; // Send data
TI_CC_CSn_PxOUT |= TI_CC_CSn_PIN; // /CS disable
char SPIReadReg(char addr)
char tmp;
TI_CC_CSn_PxOUT &= ~TI_CC_CSn_PIN; // Enable CSn
while (!(IFG2&UCB0TXIFG)); // Wait for TX to finish
UCB0TXBUF = addr; // Send address
UCB0TXBUF = 0; // Dummy write so we can read data
// Address is now being TX'ed, with dummy byte waiting in TXBUF...
while (!(IFG2&UCB0RXIFG)); // Wait for RX to finish
// Dummy byte RX'ed during addr TX now in RXBUF
IFG2 &= ~UCB0RXIFG; // Clear flag set during addr write
while (!(IFG2&UCB0RXIFG)); // Wait for end of dummy byte TX
// Data byte RX'ed during dummy byte write is now in RXBUF
tmp = UCB0RXBUF; // Read data
return tmp;
void PowerupResetCCxxxx(void)
Wait(30);
Wait(30);
Wait(45);
UCB0TXBUF = TI_CCxxx0_SRES; // Send strobe(RST)
// Strobe addr is now being TX'ed
while (!(IFG2&UCB0RXIFG)); // Wait for end of addr TX
头文件关于SPI的定义如下:
// use the USCI_B0 SPI@MSP430F2274
#define TI_CC_SPI_USCIB0_PxSEL P3SEL // MSP430F2274
#define TI_CC_SPI_USCIB0_PxDIR P3DIR
#define TI_CC_SPI_USCIB0_PxIN P3IN
#define TI_CC_SPI_USCIB0_SIMO BIT1
#define TI_CC_SPI_USCIB0_SOMI BIT2
#define TI_CC_SPI_USCIB0_UCLK BIT3
#define TI_CC_CSn_PxOUT P3OUT
#define TI_CC_CSn_PxDIR P3DIR
#define TI_CC_CSn_PIN BIT0 //P3.0 --> CSn @msp430f2274 |
