点击此处下载 ourdev_588089X4HA3T.TXT(文件大小:9K) (原文件名:fuzzyc.TXT)
#include<iostream.h>
#include<iomanip.h>
#include<fstream.h>
#include<stdlib.h>
struct Fzb
int yyz; //语言之
int ly; //论域
float lsd; //隶属值
struct Fzb *next;
class Fuzzy
private:
int g[49][3]; //定义了规则库,用于函数间调用
float R[169][13]; //定义了关系矩阵,用于函数间调用
float H[13][13]; //定义了查询表矩阵,用于函数间的调用
public:
struct Fzb * Creatfzb(); //建立赋值表函数
void Printfzb(struct Fzb *head1); //输出赋值表
void Inputgzk(); //导入规则库
void jlgx(struct Fzb*E,struct Fzb*EC,struct Fzb*U); //建立关系矩阵
void jlcxb(struct Fzb*E,struct Fzb*EC,struct Fzb*U); //建立查询表
struct Fzb *Fuzzy::Creatfzb()
float f[8][14]={
{0,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6},
{-3,1,0.5,0,0,0,0,0,0,0,0,0,0,0},
{-2,0,0.5,1,0.5,0,0,0,0,0,0,0,0,0},
{-1,0,0,0,0.5,1,0.5,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0.5,1,0.5,0,0,0,0,0},
{1,0,0,0,0,0,0,0,0.5,1,0.5,0,0,0},
{2,0,0,0,0,0,0,0,0,0,0.5,1,0.5,0},
{3,0,0,0,0,0,0,0,0,0,0,0,0.5,1}}; //默认输入赋值表
int i,k,j;
fstream in,out;
struct Fzb *head,*p1,*p2;
int n=0;
head=NULL;
p1=new(Fzb);
for(k=1;k<8;k++)
for(j=1;j<14;j++)
n++;
p1->lsd=f[k][j];
p1->yyz=(int)f[k][0];
p1->ly=(int)f[0][j];
if(1==n) head=p1;
p2=p1;
p1=new(Fzb);
p2->next=p1;
p2->next=NULL;
int m=0;
return (head);
void Fuzzy::Inputgzk()
int G[49][3]={
{-3,-3,-3},{-3,-2,-3},{-3,-1,-3},{-3,0,-3},
{-3,1,-2},{-3,2,0},{-3,3,0},{-2,-3,-3},
{-2,-2,-3},{-2,-1,-3},{-2,0,-3},{-2,1,-2},
{-2,2,0},{-2,3,0},{-1,-3,-2},{-1,-2,-2},
{-1,-1,-2},{-1,0,-2},{-1,1,0},{-1,2,1},
{-1,3,1},{0,-3,-2},{0,-2,-2},{0,-1,-1},
{0,0,0},{0,1,1},{0,2,2},{0,3,2},{1,-3,-1},
{1,-2,-1},{1,-1,0},{1,0,2},{1,1,2},{1,2,2},
{1,3,2},{2,-3,0},{2,-2,0},{2,-1,2},{2,0,3},
{2,1,3},{2,2,3},{2,3,3},{3,-3,0},{3,-2,0},
{3,-1,2},{3,0,3},{3,1,3},{3,2,3},{3,3,3}}; //默认输入规则库
int i,j;
int n=0;
for(i=0;i<49;i++)
for(j=0;j<3;j++)
n++;
g[j]=G[j];
cout<<setw(5)<<g[j]; //显示规则库
if(3==n) {cout<<endl;n=0;}
void Fuzzy::Printfzb(struct Fzb *head1)
struct Fzb *p;
p=head1;
int n,i,j;
float a[8][14];
while(NULL!=p)
a[p->yyz+4][p->ly+7]=p->lsd;
p=p->next;
p=head1;
while (NULL!=p)
a[0][p->ly+7]=p->ly;
p=p->next;
p=head1;
while (NULL!=p)
a[p->yyz+4][0]=p->yyz;
p=p->next;
a[0][0]=0;
int k;
for(i=0;i<8;i++) //用于输出标准形式的赋值表
n=0;
for(j=0;j<14;j++)
n++;
if(0==j&&0!=i)
switch((int)a[j]) {
case -3:
cout<<setw(5)<<"NB";
case -2:
cout<<setw(5)<<"NM";
case -1:
cout<<setw(5)<<"NS";
case 0:
cout<<setw(5)<<"Z";
case 1:
cout<<setw(5)<<"PS";
case 2:
cout<<setw(5)<<"PM";
case 3:
cout<<setw(5)<<"PB";
cout<<setw(5)<<a[j];
if(14==n) cout<<endl;
void Fuzzy::jlgx(struct Fzb*E,struct Fzb*EC,struct Fzb*U)
int i,j,k,m,n,l,z;
struct Fzb*p1,*p2,*p3;
p1=E; p2=EC; p3=U;
float a[13],b[13],c[13];
float R1[169],R2[169][13]; //前者用于存储转置后的一维向量,后者用于暂时存储每条规则生成的关系矩阵
for(i=0;i<49;i++)
p1=E; p2=EC; p3=U;
k=0;m=0;n=0;z=0;
while(NULL!=p1)
if(p1->yyz==g[0])
a[k++]=p1->lsd;
p1=p1->next;
while(NULL!=p2)
if(p2->yyz==g[1])
b[m++]=p2->lsd;
p2=p2->next;
while(NULL!=p3)
if(p3->yyz==g[2])
c[n++]=p3->lsd;
p3=p3->next;
for(j=0;j<13;j++)
for(l=0;l<13;l++)
if(a[j]>b[l])
R1[z++]=b[l];
R1[z++]=a[j];
for(j=0;j<169;j++)
for(l=0;l<13;l++)
if(R1[j]>c[l])
R2[j][l]=c[l];
R2[j][l]=R1[j];
if(0==i)
for(j=0;j<169;j++) //以下于对所有规则对应的关系矩阵作加法
for(l=0;l<13;l++)
R[j][l]=R2[j][l];
for(j=0;j<169;j++)
for(l=0;l<13;l++)
if(R2[j][l]>R[j][l])
R[j][l]=R2[j][l];
i=0;
for(j=0;j<169;j++)
for(l=0;l<13;l++)
i++;
cout<<setw(5)<<R[j][l]; //输出总的关系矩
if(13==i)
{cout<<endl;i=0;}
return;
void Fuzzy::jlcxb(struct Fzb*E,struct Fzb*EC,struct Fzb*U)
int e,ec,u;
int i,j,k,n=0,l=0,x=0;
float m=0;
p1=E;p2=EC;p3=U;
float a[13],b[13];
float gg[169];
float max=0,min;
float t[13]; //用于存储每次生成的U的隶属函数,从而求得每组e,ec对应的u
for(i=0;i<13;i++)
for(j=0;j<13;j++)
m=0;
p1=E;p2=EC;p3=U;
l=0;
e=i-6;
ec=j-6;
while (NULL!=p1)
if(e<0)
if(e==p1->ly&&m<p1->lsd)
n=p1->yyz;
m=p1->lsd;
if(e==p1->ly&&m<=p1->lsd)
n=p1->yyz;
m=p1->lsd;
p1=p1->next;
p1=E;
while (NULL!=p1)
if(n==p1->yyz) a[l++]=p1->lsd;
p1=p1->next;
m=0;
while (NULL!=p2)
if(ec<0)
if(ec==p2->ly&&m<p2->lsd)
n=p2->yyz;
m=p2->lsd;
if(ec==p2->ly&&m<=p2->lsd)
n=p2->yyz;
m=p2->lsd;
p2=p2->next;
p2=EC;
l=0;
while (NULL!=p2)
if(n==p2->yyz) b[l++]=p2->lsd;
p2=p2->next;
cout<<e<<" "<<ec<<endl;
for(x=0;x<13;x++)
cout<<a[x]<<" ";
cout<<endl;
for(x=0;x<13;x++)
cout<<b[x]<<" ";
cout<<endl;*/
n=0;
for(x=0;x<13;x++)
for(l=0;l<13;l++)
if(a[x]<b[l]) gg[n++]=a[x];
else gg[n++]=b[l];
for(x=0;x<13;x++) //进行推理合成规则计算
max=0;
for(l=0;l<169;l++)
if(gg[l]<R[l][x]) min=gg[l];
else min=R[l][x];
if(max<min) max=min;
t[x]=max;
p3=U;
float sum=0;
float s=0;
float u=0;
for(x=0;x<13;x++)
if(0!=t[x])
s=x-6;
sum+=t[x]*s;
u+=t[x];
H[j]=sum/u;
for(i=0;i<13;i++)
for(j=0;j<13;j++)
if(H[j]<0)
cout<<setw(4)<<(int)(H[j]-0.5);
cout<<setw(4)<<(int)(H[j]+0.5);
cout<<endl;
void main()
struct Fzb *E,*EC,*U;
E=EC=U=NULL;
Fuzzy p;
int jg;
int n=1;
E=p.Creatfzb(); //默认建立E的赋值表
EC=p.Creatfzb(); //默认建立EC的赋值表
U=p.Creatfzb(); //默认建立U的赋值表
int t=1;
while (1==1) {
cout<<endl<<"想做什么:"<<endl<<"1、输出E的赋值表"<<endl<<"2、输出EC的赋值表"<<endl<<"3、输出U的赋值表"<<endl<<"4、显示规则库"<<endl<<"5、求解关系函数"<<endl<<"6、输出查询表"<<endl<<"6、退出"<<endl;
cout<<"----> ";
cin>>jg;
switch(jg) {
case 1:
cout<<"*************************************************************"<<endl;
cout<<"E的赋值表如下:"<<endl;
p.Printfzb(E);
case 2:
cout<<"EC的赋值表如下:"<<endl;
p.Printfzb(EC);
case 3:
cout<<"U的赋值表如下:"<<endl;
p.Printfzb(U);
case 4:
p.Inputgzk();
n=0;
case 5:
if(n)
cout<<" 未调入规则库,请先运行步骤4"<<'\a'<<endl;
p.jlgx(E,EC,U);
t=0;
case 6:
if(t)
cout<<" 未创建关系矩阵,请先运行步骤5"<<'\a'<<endl;
cout<<"查询表如下:"<<endl;
p.jlcxb(E,EC,U);
default:
return;
