首先感谢greatsnows,看了greatsnows将时间调度器内核移植到AVR,而我一直使用的是PIC系列单片机,因此也把greatsnows作者的代码给移植到PIC16F877A上,但是不知到哪儿出问题,时间调度器死活不进行任务调度,只有一个LED灯可以闪烁,望高手给指点下,呵呵,先说声谢谢了
开发环境MPLAB8.53 + (HT)PICC 9.71a
/*-----------------------------SCH.c--------------------------*-
#include "MySch.h"
//SCH 调度器内核函数
// 任务调度器数组
sTask SCH_tasks_G[SCH_MAX_TASKS];
* void SCH_Init_T0(void)
void SCH_Init_T1(void)
uint8_t i;
for (i = 0; i < SCH_MAX_TASKS; i++)
SCH_Delete_Task(i);
T1CON = 0x08;//Set the internal OSC as the timer1 source
TMR1H = 0xD8;//Load the timer1's high and low register
TMR1L = 0xF0;
TMR1IF = 0; //Clear the Timer1 flag
TMR1IE = 1; //Enable the Timer1
TMR1ON = 1; //Start the Timer1
* void SCH_Start(void)
PEIE = 1; //开启外设中断
GIE = 1; //开启全局中断
* void SCH_Update(void) interrupt INTERRUPT_Timer_0_Overflow
static void interrupt ISR(void)
{ if(TMR1IF == 1)
uint8_t Index;
TMR1IF = 0; // Have to manually clear this.
TMR1ON = 0;
// PIC16F877A, 4 MHz
TMR1H = 0xD8;
TMR1L = 0xF0;
// Start Timer 0
TMR1ON = 1;
// NOTE: calculations are in *TICKS* (not milliseconds)
for (Index = 0; Index < SCH_MAX_TASKS; Index++)
// Check if there is a task at this location
if (SCH_tasks_G[Index].pTask)
if (SCH_tasks_G[Index].Delay == 0)
// 给可以被调度的任务设置标志位
// 说明:任务运行标志位不具有存储功能,也就是说,如果在规定的
// 间隔内没有被运行,则机会丧失
SCH_tasks_G[Index].RunMe += 1; // Inc. the 'Run Me' flag
if (SCH_tasks_G[Index].Period)//将任务需要的延时装入
SCH_tasks_G[Index].Delay = SCH_tasks_G[Index].Period;
SCH_tasks_G[Index].Delay -= 1;//延时-1
* 任务调度器内核
* void SCH_RUN_Tasks(void)
uint8_t Index;
// 调度器调度任务
if (SCH_tasks_G[Index].RunMe > 0)
(*SCH_tasks_G[Index].pTask)(); // 运行任务
SCH_tasks_G[Index].RunMe -= 1; // 清除任务标志位
// 如果任务只要求运行一次,则删除任务
if (SCH_tasks_G[Index].Period == 0)
SCH_Delete_Task(Index);
* uchar SCH_Add_Task
uint8_t SCH_Add_Task( void (*pFunction)(void),
uint16_t DELAY,
uint16_t PERIOD)
uint8_t Index = 0;
while ((SCH_tasks_G[Index].pTask != 0) && (Index < SCH_MAX_TASKS))
Index++;
// Have we reached the end of the list?
if (Index == SCH_MAX_TASKS)
// Task list is full
return SCH_MAX_TASKS;
// If we're here, there is a space in the task array
SCH_tasks_G[Index].pTask = pFunction;
SCH_tasks_G[Index].Delay = DELAY;
SCH_tasks_G[Index].Period = PERIOD;
SCH_tasks_G[Index].RunMe = 0;
return Index; // return position of task (to allow later deletion)
* uint8_t SCH_Delete_Task(const uchar TASK_INDEX)
uint8_t SCH_Delete_Task( uint8_t TASK_INDEX)
SCH_tasks_G[TASK_INDEX].pTask = 0x0000;
SCH_tasks_G[TASK_INDEX].Delay = 0;
SCH_tasks_G[TASK_INDEX].Period = 0;
SCH_tasks_G[TASK_INDEX].RunMe = 0;
return 0; // return status
/*------------------------MySch.h-----------------------------------/
//MySch.h : header file for the MySch project
#ifndef _MySch_
#define _MySch_
//#define __MCU_CLOCK_FREQUENCY__ _8.0000_MHz
#include <htc.h>
typedef unsigned char uint8_t;
typedef unsigned int uint16_t;
#ifndef TRUE
#define FALSE 0
#define TRUE (!FALSE)
#define RETURN_NORMAL 0
#define RETURN_ERROR 1
//函数声明和任务结构体定义
// 定义调度器数据结构
// 每一个任务消耗 7 bytes RAM
typedef struct data
//定义函数类型指针,const关键字意思是这是一个指向flash的指针
void (*pTask)(void);
volatile uint16_t Delay; // 任务第一次被执行前的延迟时间,如果为0则立即执行
volatile uint16_t Period; // 任务的执行间隔时间,如果为0,则只执行一次
volatile uint8_t RunMe; // 任务执行标志为,1 等待执行,0 不需要执行
} sTask; //sTask是结构体变量
// 调度器内核
// 本文件所有函数
void SCH_Init_T1(void);
void SCH_Start(void);
// 调度器对外部接口
void SCH_RUN_Tasks(void);
uint8_t SCH_Add_Task(void (*pFunction)(void),
uint16_t DELAY,
uint16_t PERIOD);
uint8_t SCH_Delete_Task(uint8_t TASK_INDEX);
// 调度器支持的任务个数,用户在调用调度器的时候必须设置
#define SCH_MAX_TASKS 2
/*--------------------------------PIC_PIC16F877A-----------------
#ifndef _PIC_PIC16F877A_
#define _PIC_PIC16F877A_
#include<htc.h>
// Misc #defines
//#define LED_ON sbi(PORTB,0)
//#define LED_OFF cbi(PORTB,0)
//#define LED_ON1 sbi(PORTB,1)
//#define LED_OFF1 cbi(PORTB,1)
#define LED_ON PORTD |= (1 << RD7)
#define LED_OFF PORTD &= ~(1 << RD7)
#define LED_ON1 PORTD |= (1 << RD6)
#define LED_OFF1 PORTD &= ~(1 << RD6)
/*------------------------------LED_FLASH.c-------------------------
#include "PIC_PIC16F877A.h"
#include "MySch.h"
// ------ Private variable definitions -----------------------------
static uint8_t LED_state_G;
static uint8_t LED_state_G1;
LED_Flash_Init()
void LED_Flash_Init(void)
LED_state_G = 0;
LED_state_G1 = 0;
void LED_Flash_Update(void)
// Change the LED from OFF to ON (or vice versa)
if (LED_state_G == 1)
LED_state_G = 0;
LED_OFF;
LED_state_G = 1;
LED_ON;
void LED_Flash_Update1(void)
if (LED_state_G1 == 1)
LED_state_G1 = 0;
LED_ON1;
LED_state_G1 = 1;
LED_OFF1;
/*----------------------------MySch.c---------------------------
#include "MySch.h"
//MySch 主程序
extern void LED_Flash_Update(void);
extern void LED_Flash_Update1(void);
extern void LED_Flash_Init(void);
static void io_init(void)
// PortC
PORTC = 0x00;
TRISC = 0x00;
// PortD
PORTD = 0x00;//初始时灯灭
TRISD = 0x00;//端口设置成输出
int main(void)
io_init();
SCH_Init_T1();
LED_Flash_Init(); //用于闪灯,实际中可代替
SCH_Add_Task(LED_Flash_Update, 0, 500); //用于闪灯,实际中可代替LED_Flash_Update
SCH_Add_Task(LED_Flash_Update1, 10, 500);
SCH_Start();
SCH_RUN_Tasks();
以上是我移植修改后的源程序! |
