orz
原来MAX II也是Stratix class architecture:
General Options:
Target device is a Stratix class architecture.
Target device is a MAX II.
Design name: 'none'
Maximum Slack Ratio Allowed for Clock-Path Edges: 0.1
Maximum Slack Ratio Allowed for Synchronization Edges: 0.1
Minimum delay chain settings will be assumed for all unknown delay chains
The circuit will be packed into logic blocks first, then
The circuit will be placed and routed.
Maximum placement attempts: 1
Maximum routing (with placement perturbed) attempts: 3
VPR will skip this many fit attempts: 0
SSN Optimization is disabled
Power-driven compile effort is normal
Initial random seed: 1
The pack file will be generated
Graphics will not be displayed.
Memory allocator activity will be not be logged.
VPR memory allocator will not write garbage to allocated buffers.
Clustering Options:
CBE chain breaking limit (desirable): 21
CBE chain breaking limit (max): 25
CBE input limit for Qor (low): 20
CBE input limit for Qor (mid): 21
CBE input limit for Qor (high): 25
Clustering timing gain factor: 1
Clustering timing exponent: 10
Clustering gain adjustment for size: -0.005
Clustering path based edge weight gain factor: 10000
Intercluster delay (in seconds): 1.25e-009
Delay assumed for unclustered BLEs (in seconds): 9.375e-010
Clustering pin sharing gain factor: 1000
Clustering power criticality factor: 1
Clustering clock power gain: 0
Clustering RAM conversion permitted LAB usage fraction: 0.95
Timing analyze during clustering: Once only
Constrain critical I/O connections: No
Try to pack LEs into LABs aggressively: No
Allow packing of LEs that will require shared ALE inputs: Yes
Allow experimental sibling gain: Yes
Allow packing of LEs that will require SLM: Yes
Allow packing of 6-input LEs with non 6-input LEs that will require SLM: No
Allow packing using soft logic registers: No
Pick non-gained blocks by using bucket sorting in greedy clustering: No
Enforce proximity clustering partitions in clustering: Yes
Perform power optimizations: No
Perform clock power optimizations: No
Anneal clustering: Yes |
