ARM的启动代码里,进入ResetHandler,然后进行一系统的初始化:看门狗,中断屏蔽,系统时钟初始化后,如果是掉电模式唤醒则进入掉电唤醒检测,是则进行掉电唤醒处理,处理完后又怎样回到进入掉电模式的呢,就是这几句:ldr r1 ,=GSTATUS3 ldr r0,[r1] mov pc,r0 ,执行完后程序会到哪里去呢?。。
ResetHandler
ldr r0,=WTCON ;watch dog disable
ldr r1,=0x0
str r1,[r0]
ldr r0,=INTMSK
ldr r1,=0xffffffff ;all interrupt disable
str r1,[r0]
ldr r0,=INTSUBMSK
ldr r1,=0x7ff ;all sub interrupt disable, 2002/04/10
str r1,[r0]
[ {FALSE}
; rGPFDAT = (rGPFDAT & ~(0xf<<4)) | ((~data & 0xf)<<4);
; Led_Display
ldr r0,=GPFCON
ldr r1,=0x5500
str r1,[r0]
ldr r0,=GPFDAT
ldr r1,=0x10
str r1,[r0]
;To reduce PLL lock time, adjust the LOCKTIME register.
ldr r0,=LOCKTIME
ldr r1,=0xffffff
str r1,[r0]
[ PLL_ON_START
;Configure MPLL
ldr r0,=MPLLCON
ldr r1,=((M_MDIV<<12)+(M_PDIV<<4)+M_SDIV) ;Fin=12MHz,Fout=50MHz
str r1,[r0]
;Check if the boot is caused by the wake-up from POWER_OFF mode.
ldr r1,=GSTATUS2
ldr r0,[r1]
tst r0,#0x2
;In case of the wake-up from POWER_OFF mode, go to POWER_OFF_WAKEUP handler.
bne WAKEUP_POWER_OFF 如果是则进入WAKEUP_POWER_OFF
EXPORT StartPointAfterPowerOffWakeUp
WAKEUP_POWER_OFF
;Release SCLKn after wake-up from the POWER_OFF mode.
ldr r1,=MISCCR
ldr r0,[r1]
bic r0,r0,#(7<<17) ;SCLK0:0->SCLK, SCLK1:0->SCLK, SCKE:L->H
str r0,[r1]
;Set memory control registers
ldr r0,=SMRDATA
ldr r1,=BWSCON ;BWSCON Address
add r2, r0, #52 ;End address of SMRDATA
0
ldr r3, [r0], #4
str r3, [r1], #4
cmp r2, r0
bne %B0
mov r1,#256
0 subs r1,r1,#1 ;1) wait until the SelfRefresh is released.
bne %B0
ldr r1,=GSTATUS3 ;GSTATUS3 has the start address just after POWER_OFF wake-up
ldr r0,[r1]
mov pc,r0 程序到了这里,然后程序会到哪里去呢?????? |
