发表于 2010-8-31 09:57:38
现在我程序修改了!但是open的时候感觉没有和驱动的open联系上!
#include <linux/types.h>
#include <linux/cdev.h>
#include <linux/fs.h>
#include <linux/device.h>
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/init.h>
#include <linux/string.h>
#include <linux/platform_device.h>
#include <linux/errno.h>
#include <asm/uaccess.h>
#include <asm/arch/io.h>
#include <asm/arch/gpio.h>
#include <linux/delay.h>
#include <asm/arch/at91sam9260.h>
#include <asm/arch/at91_pio.h>
#include <linux/miscdevice.h>
#define DEV_NAME "led_screen"
#define PORTB_BASE 0xfffff600 // PORTB
ssize_t screen_read(struct file *filp,char __user *buffer,size_t size,loff_t *offset);
ssize_t screen_write(struct file *filp,const char __user *buffer,size_t size,loff_t *offset);
int screen_open(struct inode *inode,struct file *filp);
int screen_release(struct inode *inode,struct file *filp);
int screen_ioctl(struct inode *inode,struct file *filp,unsigned int cmd,unsigned long arg);
static int led_screen_probe ( struct platform_device *dev );
void led_screen_release(struct device * dev);
// 这个是GPIO的物理地址的基址
static void __iomem *led_screen_base;
static struct resource *led_screen_mem;
// 控制LED屏的GPIO口
static unsigned long led_screen_table [] =
//AT91_PIN_PA6,
AT91_PIN_PB0,
struct resource led_screen_resource[] = {
[0]={
.start = PORTB_BASE,
.end = PORTB_BASE + 512,
.flags = IORESOURCE_MEM,
struct platform_device led_screen_device= {
.name = DEV_NAME,
.id = -1,
.num_resources = ARRAY_SIZE(led_screen_resource),
.resource = led_screen_resource,
.dev = {
.release = led_screen_release,
printk(KERN_ALERT "%s:%s,%s\r\n", __FUNCTION__,__DATE__,__TIME__);
writel( 0x0000000f, led_screen_base + PIO_SODR );
return 0;
return 0;
return 0;
return 0;
return 0;
struct file_operations led_screen_opt ={
.owner = THIS_MODULE,
.ioctl = screen_ioctl,
.open = screen_open,
.read = screen_read,
.write = screen_write,
.release = screen_release,
static struct miscdevice led_screen_misc ={
.minor = MISC_DYNAMIC_MINOR,
//.name = "screen",
.name = DEV_NAME,
.fops = &led_screen_opt,
struct resource *res;
int ret = 0;
int size;
res = platform_get_resource( dev, IORESOURCE_MEM, 0 );
if (res == NULL)
printk("no memory resource specified\n");
return -ENOENT;
size = (res->end-res->start)+1;
led_screen_mem = request_mem_region(res->start, size, dev->name);
if (NULL == led_screen_mem)
printk("failed to get memory region\n");
ret = -ENOENT;
goto err_req;
led_screen_base = ioremap(res->start, size);
if (led_screen_base == 0)
printk("failed to ioremap() region\n");
ret = -EINVAL;
goto err_req;
printk("resource is ok!\n");
/*ret=misc_register(&led_screen_misc);
if(ret)
printk("cannot register led_screen_misc miscdev!\n");
iounmap(led_screen_base);
return ret;
writel( 0x0000000f, led_screen_base + PIO_PER );
writel( 0x0000000f, led_screen_base + PIO_PUER );
writel( 0x0000000f, led_screen_base + PIO_ODSR );
writel( 0x0000000f, led_screen_base + PIO_OER );
writel( 0x0000000f, led_screen_base + PIO_CODR );
//at91_set_gpio_output(led_screen_table[0],1);
//at91_set_gpio_value(led_screen_table[0],0);
return ret;
err_req:
release_resource(led_screen_mem);
kfree(led_screen_mem);
printk("resource is fail!\n");
return ret;
static int led_screen_remove ( struct platform_device *dev )
return 0;
static struct platform_driver led_screen_driver = {
.probe = led_screen_probe,
.remove = led_screen_remove,
.driver = {
.name = DEV_NAME,
static int __init led_screen_init ( void )
int ret = 0;
ret = platform_device_register ( &led_screen_device );
if ( ret )
platform_device_unregister ( &led_screen_device );
printk ( "platform_device_register is fail!\n" );
return ret;
if(ret)
return ret;
printk ( "platform_device_register is ok!\n" );
ret = platform_driver_register ( &led_screen_driver );
if ( ret )
printk ( "platform_driver_register is fail!\n" );
platform_driver_unregister ( &led_screen_driver );
return ret;
printk ( "platform_driver_register is ok!\n" );
return ret;
static void __exit led_screen_exit ( void )
//at91_set_gpio_value(led_screen_table[0],1);
misc_deregister(&led_screen_misc);
module_init ( led_screen_init );
module_exit ( led_screen_exit );
MODULE_AUTHOR("m");
MODULE_DESCRIPTION("this is led_screen driver modules");
MODULE_LICENSE("Dual BSD/GPL");
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/ioctl.h>
int main(void)
int fd;
printf("%s:%s,%s\r\n", __FUNCTION__,__DATE__,__TIME__);
fd=open("/sys/class/misc/led_screen",0);
if(fd<0)
printf("can not open /sys/class/misc/led_screen\n");
goto end1;
//while(1)
//ioctl(fd,0,0);
//sleep(1);
//ioctl(fd,1,0);
printf ( "*********\n" );
//sleep(1);
close(fd);
end1:
return 0;
希望大侠能帮我看看是!问题出在哪里?
[root@microcreat test]$insmod led_screen.ko
led_screen_init:Aug 31 2010,09:55:58
led_screen_probe:Aug 31 2010,09:55:58
resource is ok!
resource is ok!
[root@microcreat test]$./ledtest
main:Aug 31 2010,09:41:28
[root@microcreat test]$rmmod led_screen.ko
led_screen_exit:Aug 31 2010,09:55:58
led_screen_remove:Aug 31 2010,09:55:58
led_screen_release:Aug 31 2010,09:55:58
[root@microcreat test]$dmesg
resource is ok!
resource is ok!
resource is ok!
resource is ok!
[root@microcreat test]$ls /sys/bus/platform/devices/
at91_nand at91_udc atmel_usart.1 led_screen
at91_ohci at91_wdt atmel_usart.2 macb
at91_rtt.0 atmel_usart.0 i2c-gpio ssc.0
[root@microcreat test]$ls /sys/bus/platform/drivers
at91_nand at91_wdt i2c-gpio rtc-at91sam9
at91_ohci atmel_usart led_screen ssc
at91_udc gen_nand macb
[root@microcreat test]$ls /sys/devices/
platform system
[root@microcreat test]$ls /sys/devices/platform/
at91_nand at91_udc atmel_usart.1 led_screen uevent
[root@microcreat test]$ls /sys/class/misc/
fuse led_screen watchdog
以上可以看到都添加到系统里面去了啊! |
