发表于 2010-8-24 11:35:04
这是我自己编的,经过试验是好用的。功能为:温度表。你参考一下。
#include<iom128v.h>
#include"1602.h"
#define uint unsigned int
uchar tem[]={"tempreture:"};
#pragma data:code
const uchar table_ad[]={
/*0 ,1 ,2 ,3 ,4 ,5 ,6 ,7 ,8 ,9 ,10 ,11 ,12 ,13 ,14 ,15 ,16 ,17 ,18 ,19 */
//0 ,0 ,0 ,
0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,
/*20 ,21 ,22 ,23 ,24 ,25 ,26 ,27 ,28 ,29 ,30 ,31 ,32 ,33 ,34 ,35 ,36 ,37 ,38 ,39 */
0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,1 ,2 ,4 ,6 ,7 ,8 ,9 ,10 ,12 ,14 ,15 ,16 ,
/*40 ,41 ,42 ,43 ,44 ,45 ,46 ,47 ,48 ,49 ,50 ,51 ,52 ,53 ,54 ,55 ,56 ,57 ,58 ,59 */
17 ,18 ,20 ,21 ,22 ,24 ,25 ,26 ,27 ,28 ,29 ,30 ,31 ,32 ,33 ,34 ,35 ,36 ,37 ,38 ,
/*60 ,61 ,62 ,63 ,64 ,65 ,66 ,67 ,68 ,69 ,70 ,71 ,72 ,73 ,74 ,75 ,76 ,77 ,78 ,79 */
39 ,40 ,41 ,42 ,43 ,44 ,45 ,46 ,47 ,48 ,49 ,50 ,51 ,51 ,52 ,53 ,54 ,55 ,56 ,57 ,
/*80 ,81 ,82 ,83 ,84 ,85 ,86 ,87 ,88 ,89 ,90 ,91 ,92 ,93 ,94 ,95 ,96 ,97 ,98 ,99 */
58 ,59 ,59 ,60 ,61 ,62 ,63 ,63 ,64 ,65 ,66 ,67 ,68 ,69 ,69 ,70 ,71 ,72 ,73 ,73 ,
/*100,101,102,103,104,105,106,107,108,109,110,111,112,113,114,115,116,117,118,119*/
74 ,75 ,76 ,77 ,77 ,78 ,79 ,80 ,81 ,82 ,83 ,83 ,84 ,85 ,86 ,87 ,87 ,88 ,89 ,90 ,
/*120,121,122,123,124,125,126,127,128,129,130,131,132,133,134,135,136,137,138,139*/
91 ,91 ,92 ,93 ,94 ,95 ,95 ,96 ,97 ,98 ,99 ,100,101,101,102,103,104,105,106,107,
/*140,141,142,143,144,145,146,147,148,149,150,151,152,153,154,155,156,157,158,159*/
107,108,109,110,111,112,113,114,115,115,116,117,118,119,120,121,122,123,124,125,
/*160,161,162,163,164,165,166,167,168,169,170,171,172,173,174,175,176,177,178,179*/
126,127,128,129,130,131,132,133,134,135,136,137,138,139,140,141,142,143,144,145,
/*180,181,182,183,184,185,186,187,188,189,190,191,192,193,194,195,196,197,198,199*/
146,148,149,150,151,153,154,155,157,158,159,160,161,163,164,165,167,168,170,171,
/*200,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217,218,219*/
173,175,176,177,179,181,183,185,186,187,189,191,193,195,197,199,200,201,202,204
//ADC测试,使用1602显示ADC0和ADC1的值
//主函数
main()
uchar ten_1,ten_2,ten_3,ten_4,i,temp;
uint adc_data0,adc_l0,adc_h0,adc_data1,adc_l1,adc_h1;
//初始化端口
DDRA=0xff;
DDRC=0XFF;
PORTC=0XFF;
PORTA=0x00;
DDRB=0xff;
DDRD=0xff;
PORTD=0x00;
DDRF=0x00;
PORTF=0x00;
DDRG=0xff;
PORTG=0x00;
//1602初始化
LcdInit();
WriteChar(1,2,11,tem);
PORTC|=(1<<6);
//取ADC_0
ADCSRA=0x00;
ADMUX=0x40;
ADCSRA=(1<<ADEN)|(1<<ADSC)|(1<<ADFR)|0x07; //128分频,连续转换
s_ms(500); //延时很重要,给出转换的时间
adc_l0=ADCL;
adc_h0=ADCH;
adc_data0=adc_h0<<8|adc_l0;
adc_data0=adc_data0>>2; //放弃2位精度
//adc_data0=adc_h0;
temp=(table_ad[adc_data0]-40)/2;//温度计算
//显示ADC0
ten_3=(temp)/100;
ten_2=(temp-(ten_3*100))/10;
ten_1=temp-(ten_3*100)-ten_2*10;
ten_1+=0x30;//转换成ASCII
ten_2+=0x30;;//转换成ASCII
ten_3+=0x30;;//转换成ASCII
WriteNum(1,13,(ten_3));
WriteNum(1,14,(ten_2));
WriteNum(1,15,(ten_1));
for(i=0;i<18;i++)
s_ms(60000);
#define RS 0
#define RW 1
#define EN 2
void s_ms(uint ms)
for(;ms>1;ms--);
//查忙
void busy(void)
uchar temp;
s_ms(500);
PORTC&=~(1<<RS); //RS=0
s_ms(500);
PORTC|=(1<<RW); //RW=1
s_ms(500);
while(temp)
PORTC|=(1<<EN); //EN=1
s_ms(500);
DDRA=0x00; //A口变输入
PORTA=0xff; //上拉使能
s_ms(500);
temp = PINA&0x80; //读取A口
s_ms(500);
DDRA=0xff;
PORTA=0xff; //A口变输出
s_ms(500);
PORTC&=~(1<<EN); //EN=0
s_ms(500);
//写指令
void writecom(uchar com)
busy();
s_ms(500);
s_ms(500);
PORTC&=~(1<<RW); //RW=0
s_ms(500);
s_ms(500);
PORTA = com; //输出指令
s_ms(500);
s_ms(500);
//1602初始化
void LcdInit(void)
writecom(0x38);
s_ms(1000);
writecom(0x01);
s_ms(10000);
s_ms(1000);
s_ms(1000);
s_ms(1000);
s_ms(1000);
s_ms(1000);
s_ms(1000);
writecom(0x02);
s_ms(1000);
writecom(0x06);
s_ms(1000);
writecom(0x0c);
s_ms(1000);
writecom(0x38);
s_ms(1000);
//写数据
void writedata(uchar data)
busy();
s_ms(500);
PORTC|=(1<<RS); //RS=1
s_ms(500);
s_ms(500);
s_ms(500);
PORTA = data; //输出数据
s_ms(500);
s_ms(500);
//读数据
uchar readdata(void)
uchar temp;
busy();
s_ms(500);
s_ms(500);
s_ms(500);
s_ms(500);
DDRA=0x00; //A端口变输入
s_ms(500);
temp = PINA; //读A端口
s_ms(500);
DDRA=0xff; //A端口变输出
s_ms(500);
s_ms(500);
return temp;
// 描述: 写LCD内部CGRAM函数
// 入口: ‘num’要写的数据个数
// ‘pbuffer’要写的数据的首地址
// 出口: 无
void WriteCGRAM(uint num, const uint *pBuffer)
uint i,t;
writecom(0x40);
PORTC|=(1<<RS);
PORTC&=~(1<<RW);
for(i=num;i!=0;i--)
t = *pBuffer;
PORTC|=(1<<EN);
PORTA = t;
PORTC&=~(1<<EN);
pBuffer++;
//描述:写菜单函数,本程序使用的LCD规格为 16 * 2
//入口:菜单数组首地址
//出口:无
void WriteMenu(const uchar *pBuffer)
uchar i,t;
writecom(0x80); //数据地址
PORTC|=(1<<RS);
PORTC&=~(1<<RW);
s_ms(50);
for(i=0;i<16;i++)
t = *pBuffer;
PORTA = t;
PORTC|=(1<<EN);
s_ms(50);
PORTC&=~(1<<EN);
pBuffer++;
writecom(0xC0);
PORTC|=(1<<RS);
PORTC&=~(1<<RW);
s_ms(50);
for(i=0;i<16;i++)
t = *pBuffer;
PORTA = t;
PORTC|=(1<<EN);
s_ms(50);
PORTC&=~(1<<EN);
pBuffer++;
// 描述:在任意位置写数字函数
// 入口:’row‘表示要写数字所在的行地址,只能为1或2
// ’col‘表示要写数字所在的列地址,只能为0--15
// ‘num’表示要写的数字,只能为0--9
// 出口:无
void WriteNum(uchar row,uchar col,uchar num)
if (row == 1) row = 0x80 + col;
else row = 0xC0 + col;
writecom(row);
PORTC|=(1<<RS);
s_ms(500);
PORTC&=~(1<<RW);
s_ms(500);
PORTA = num;
s_ms(500);
PORTC|=(1<<EN);
s_ms(500);
PORTC&=~(1<<EN);
s_ms(500);
// 描述:在任意位置写任意多个字符
// 入口:’row‘要写的字符所在的行,只能为1或2;
// ‘col’要写的字符所在的列,只能为0---15
// ‘num’要写字符的个数
// ‘pbuffer’要写字符的首地址
void WriteChar(uchar row,uchar col,uint num,uchar *pBuffer)
uchar i,t;
writecom(row);
PORTC|=(1<<RS);
s_ms(500);
PORTC&=~(1<<RW);
s_ms(500);
for(i=num;i!=0;i--)
t = *pBuffer;
s_ms(500);
PORTA = t;
s_ms(500);
PORTC|=(1<<EN);
s_ms(500);
PORTC&=~(1<<EN);
s_ms(500);
pBuffer++;
