今天想用STM32做个红外发射接收实验(38KHZ),发射模拟载波,38KHZ的频率用示波器测试后为38KHZ,试验方法:连续发射的载波(才开始玩红外),然后网上找资料说不能这样发,然后我发射一会,停止一会,一体化接收头开始的时候有一个明显的跳变后就一直高电平,档一下后又是有一个明显的跳变后就一直高电平,再挡又是有一个明显的跳变后就一直高电平。程序如下 :(QQ513246017,请高手给看下)
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
u16 CCR1_Val = 500;
u16 CCR2_Val = 375;
u16 CCR3_Val = 250;
u16 CCR4_Val = 125;
u16 CCR5_Val = 625;
ErrorStatus HSEStartUpStatus;
u32 tick;
u8 mode;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void EXTI_init(void);
/* Private functions ---------------------------------------------------------*/
void delay(unsigned int count)
int i,j;
for(i=0;i<count;i++)
for(j=0;j<400;j++) ;
int main(void)
#ifdef DEBUG
debug();
/* System Clocks Configuration */
RCC_Configuration();
/* NVIC Configuration */
NVIC_Configuration();
/* GPIO Configuration */
GPIO_Configuration();
TIM3 Configuration: generate 4 PWM signals with 4 different duty cycles:
TIM3CLK = 36 MHz, Prescaler = 0x0, TIM3 counter clock = 36 MHz
TIM3 ARR Register = 946 => TIM3 Frequency = TIM3 counter clock/(ARR + 1)
TIM3 Frequency = 38 KHz.
TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR)* 100 = 50%
TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR)* 100 = 37.5%
TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR)* 100 = 25%
TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR)* 100 = 12.5%
TIM3 Channel4 duty cycle = (TIM3_CCR5/ TIM3_ARR)* 100 = 62.5%
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 946;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
/* PWM1 Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
/* PWM1 Mode configuration: Channel3 */
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = CCR5_Val; // 62.5%
TIM_OC3Init(TIM3, &TIM_OCInitStructure);
TIM_ARRPreloadConfig(TIM3, ENABLE);
TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);//载入值
/* TIM3 enable counter */
GPIO_ResetBits(GPIOA,GPIO_Pin_8);//蜂鸣器置0
GPIO_SetBits(GPIOA,GPIO_Pin_3); //接收位置1
while (1)
mode = GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_3);
tick++;
if(tick < 1000000)
TIM_Cmd(TIM3, ENABLE);
if(tick >= 1000000 && tick < 2000000)
tick = 0;
TIM_Cmd(TIM3, DISABLE);
if(mode == 0)
delay(100);
if(mode == 0)GPIO_SetBits(GPIOA,GPIO_Pin_8);
delay(100);
if(mode == 1)GPIO_ResetBits(GPIOA,GPIO_Pin_8);
RCC_DeInit();
RCC_HSEConfig(RCC_HSE_ON);
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if (HSEStartUpStatus == SUCCESS)
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
FLASH_SetLatency(FLASH_Latency_2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div4);
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
RCC_PLLCmd(ENABLE);
while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while (RCC_GetSYSCLKSource() != 0x08)
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB2PeriphClockCmd( RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;//接收口
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //蜂鸣器
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
/*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
/*GPIOB Configuration: TIM3 channel 3 and 4 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
GPIO_Init(GPIOB, &GPIO_InitStructure);
// NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#ifdef DEBUG
* Function Name : assert_failed
* Description : Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* Input : - file: pointer to the source file name
* - line: assert_param error line source number
* Output : None
* Return : None
void assert_failed(u8* file, u32 line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
while (1)
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/ |
