CMSIS 标准的模板上写着
/* Configure the NVIC Preemption Priority Bits:
* two (2) bits of preemption priority, six (6) bits of sub-priority.
* Since the Number of Bits used for Priority Levels is five (5), so the
* actual bit number of sub-priority is three (3)
NVIC_SetPriorityGrouping(0x05);
没有找到是5位的直接证据。不过datasheet(不是user manual)上写到
The vector table may be located anywhere within the bottom 1 GB of Cortex-M3 address
space. The vector table must be located on a 128 word (512 byte) boundary because the
NVIC on the LPC17xx is configured for 128 total interrupts.
是不是由128可以推断知道?128是7位啊?请bluelucky等高手解答 |
