我用的软件版本都是9.0,成功破解
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd E:/heijinnios/xiaobo_project/software/signal_p/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="E:/heijinnios/xiaobo_project/hel
lo.sof" --output="hello.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=hello
.opt E:/heijinnios/xiaobo_project/hello.sof hello.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 72 megabytes
Info: Processing ended: Mon Aug 16 21:44:47 2010
Info: Elapsed time: 00:00:04
Info: Total CPU time (on all processors): 00:00:04
Info: Command: quartus_cpf --no_banner --convert hello.pof hello.rpd
Info: Peak virtual memory: 71 megabytes
Info: Processing ended: Mon Aug 16 21:44:53 2010
Info: Elapsed time: 00:00:05
Info: Total CPU time (on all processors): 00:00:05
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00000000 --sidp=0x0
00018e0 --id=157948480 --timestamp=1281920168 --instance=0 "hello.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: FAILED
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="hello.flash" --input="signal_p.e
lf" --output="EPCS.flash"
# Programming flash with the project
00018e0 --id=157948480 --timestamp=1281920168 --instance=0 "EPCS.flash"
Leaving target processor paused |
