At Local date and time: Sun Aug 15 14:31:41 2010
make -f system.make init_bram started...
Running Xilinx Implementation tools..
xilperl F:/Xilinx/10.1/EDK/data/fpga_impl/manage_fastruntime_opt.pl -reduce_fanout no
xflow -wd implementation -p xc3s500epq208-4 -implement xflow.opt system.ngc
Release 10.1 - Xflow K.31 (nt)
Copyright (c) 1995-2008 Xilinx, Inc. All rights reserved.
xflow.exe -wd implementation -p xc3s500epq208-4 -implement xflow.opt system.ngc
PMSPEC -- Overriding Xilinx file <F:/Xilinx/10.1/EDK/spartan3/data/spartan3.acd>
with local file <f:/Xilinx/10.1/ISE/spartan3/data/spartan3.acd>
Using Flow File: E:/EDK_MAKE/df/implementation/fpga.flw
Using Option File(s):
E:/EDK_MAKE/df/implementation/xflow.opt
Creating Script File ...
# Starting program ngdbuild
# ngdbuild -p xc3s500epq208-4 -nt timestamp -bm system.bmm
"E:/EDK_MAKE/df/implementation/system.ngc" -uc system.ucf system.ngd
Release 10.1 - ngdbuild K.31 (nt)
Command Line: ngdbuild -p xc3s500epq208-4 -nt timestamp -bm system.bmm
E:/EDK_MAKE/df/implementation/system.ngc -uc system.ucf system.ngd
Reading NGO file "E:/EDK_MAKE/df/implementation/system.ngc" ...
Loading design module
"E:/EDK_MAKE/df/implementation/microblaze_0_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/mb_plb_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/ilmb_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/dlmb_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/dlmb_cntlr_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/ilmb_cntlr_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/lmb_bram_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/leds_8bit_wrapper.ngc"...
"E:/EDK_MAKE/df/implementation/push_buttons_4bit_wrapper.ngc"...
"E:/EDK_MAKE/df/implementation/switches_8bit_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/rs232_port_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/micron_ram_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/xps_timer_1_wrapper.ngc"...
"E:/EDK_MAKE/df/implementation/micron_ram_util_bus_split_0_wrapper.ngc"...
"E:/EDK_MAKE/df/implementation/clock_generator_0_wrapper.ngc"...
"E:/EDK_MAKE/df/implementation/debug_module_wrapper.ngc"...
"E:/EDK_MAKE/df/implementation/proc_sys_reset_0_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/xps_intc_0_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/duan_wrapper.ngc"...
Loading design module "E:/EDK_MAKE/df/implementation/wei_wrapper.ngc"...
Gathering constraint information from source properties...
Done.
Applying constraints in "system.ucf" to the design...
Resolving constraint associations...
Checking Constraint Associations...
ERROR:ConstraintSystem:59 - Constraint <Net wei_GPIO_d_out_pin<6> LOC= P47;>
[system.ucf(40)]: NET "wei_GPIO_d_out_pin<6>" not found. Please verify that:
1. The specified design element actually exists in the original design.
2. The specified object is spelled correctly in the constraint source file.
ERROR:ConstraintSystem:59 - Constraint <Net wei_GPIO_d_out_pin<6> IOSTANDARD =
LVCMOS33;> [system.ucf(41)]: NET "wei_GPIO_d_out_pin<6>" not found. Please
verify that:
ERROR:ConstraintSystem:59 - Constraint <Net wei_GPIO_d_out_pin<5> LOC= P50;>
[system.ucf(42)]: NET "wei_GPIO_d_out_pin<5>" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <Net wei_GPIO_d_out_pin<5> IOSTANDARD =
LVCMOS33;> [system.ucf(43)]: NET "wei_GPIO_d_out_pin<5>" not found. Please
verify that:
ERROR:ConstraintSystem:59 - Constraint <Net wei_GPIO_d_out_pin<4> LOC= P48;>
[system.ucf(44)]: NET "wei_GPIO_d_out_pin<4>" not found. Please verify that:
ERROR:ConstraintSystem:59 - Constraint <Net wei_GPIO_d_out_pin<4> IOSTANDARD =
LVCMOS33;> [system.ucf(45)]: NET "wei_GPIO_d_out_pin<4>" not found. Please
verify that:
Done...
Checking Partitions ...
Processing BMM file ...
Checking expanded design ...
WARNING:NgdBuild:443 - SFF primitive
'Micron_RAM/Micron_RAM/EMC_CTRL_I/MEM_STATE_MACHINE_I/READ_COMPLETE_PIPE_GEN[
6].READ_COMPLETE_PIPE' has unconnected output pin
'Micron_RAM/Micron_RAM/EMC_CTRL_I/ADDR_COUNTER_MUX_I/ADDRESS_STORE_GEN[31].AD
DRESS_REG' has unconnected output pin
'Micron_RAM/Micron_RAM/EMC_CTRL_I/ADDR_COUNTER_MUX_I/ADDRESS_STORE_GEN[30].AD
'Micron_RAM/Micron_RAM/MCH_PLB_IPIF_I/INCLUDE_PLB_IPIF_GEN.PLBV46_SLAVE_BURST
_I/I_SLAVE_ATTACHMENT/I_STEER_ADDRESS_COUNTER/GEN_FOR_SHARED.GEN_S_H_SIZE_REG
[0].I_SIZE_S_H_REG' has unconnected output pin
_I/I_SLAVE_ATTACHMENT/I_BUS_ADDRESS_COUNTER/GEN_FOR_SHARED.GEN_S_H_SIZE_REG[0
_I/I_SLAVE_ATTACHMENT/I_BUS_ADDRESS_COUNTER/I_FLEX_ADDR_CNTR/LDMUX_FDRSE_0to3
[3].I_FDRSE_BE0to3' has unconnected output pin
[2].I_FDRSE_BE0to3' has unconnected output pin
[1].I_FDRSE_BE0to3' has unconnected output pin
[0].I_FDRSE_BE0to3' has unconnected output pin
_I/I_SLAVE_ATTACHMENT/I_BURST_SUPPORT/CONTROL_DBEAT_CNTR_I/STRUCTURAL_A_GEN.I
_ADDSUB_GEN[5].FDRE_I' has unconnected output pin
_I/I_SLAVE_ATTACHMENT/I_BURST_SUPPORT/RESPONSE_DBEAT_CNTR_I/STRUCTURAL_A_GEN.
I_ADDSUB_GEN[5].FDRE_I' has unconnected output pin
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[20].TCSR1_F
F_I' has unconnected output pin
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[19].TCSR1_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[18].TCSR1_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[17].TCSR1_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[16].TCSR1_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[15].TCSR1_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[14].TCSR1_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[13].TCSR1_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[12].TCSR1_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[11].TCSR1_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[10].TCSR1_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[9].TCSR1_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[8].TCSR1_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[7].TCSR1_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[6].TCSR1_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[5].TCSR1_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[4].TCSR1_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[3].TCSR1_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[2].TCSR1_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[1].TCSR1_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR1_GENERATE[0].TCSR1_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[20].TCSR0_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[19].TCSR0_F
ONTROL_I/TCSR0_GENERATE[18].TCSR0_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[17].TCSR0_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[16].TCSR0_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[15].TCSR0_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[14].TCSR0_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[13].TCSR0_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[12].TCSR0_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[11].TCSR0_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[10].TCSR0_F
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[9].TCSR0_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[8].TCSR0_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[7].TCSR0_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[6].TCSR0_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[5].TCSR0_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[4].TCSR0_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[3].TCSR0_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[2].TCSR0_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[1].TCSR0_FF
'xps_timer_1/xps_timer_1/TC_CORE_I/TIMER_CONTROL_I/TCSR0_GENERATE[0].TCSR0_FF
WARNING:NgdBuild:478 - clock net debug_module/bscan_drck1 with clock driver
debug_module/debug_module/BUFG_DRCK1 drives no clock pins
Partition Implementation Status
No Partitions were found in this design.
NGDBUILD Design Results Summary:
Number of errors: 6
Number of warnings: 54
One or more errors were found during NGDBUILD. No NGD file will be written.
Writing NGDBUILD log file "system.bld"...
ERROR:Xflow - Program ngdbuild returned error code 2. Aborting flow execution...
make: *** [__xps/system_routed] Error 1
Done! |
