发表于 2010-8-13 13:38:24
这是我的任务文件,仿照例子
* File : led.c
* This file is part of RT-Thread RTOS
* COPYRIGHT (C) 2009, RT-Thread Development Team
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rt-thread.org/license/LICENSE
* Change Logs:
* Date Author Notes
* 2009-01-05 Bernard the first version
#include <rtthread.h>
#include <stm32f10x.h>
#define led1_rcc RCC_APB2Periph_GPIOD
#define led1_gpio GPIOD
#define led1_pin (GPIO_Pin_2)
#define led2_rcc RCC_APB2Periph_GPIOD
#define led2_gpio GPIOD
#define led2_pin (GPIO_Pin_3)
void rt_hw_led_init(void)
RCC_APB2PeriphClockCmd(led1_rcc|led2_rcc,ENABLE);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Pin = led1_pin;
GPIO_Init(led1_gpio, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = led2_pin;
GPIO_Init(led2_gpio, &GPIO_InitStructure);
void rt_hw_led_on(rt_uint32_t n)
switch (n)
case 0:
GPIO_SetBits(led1_gpio, led1_pin);
case 1:
GPIO_SetBits(led2_gpio, led2_pin);
default:
void rt_hw_led_off(rt_uint32_t n)
switch (n)
case 0:
GPIO_ResetBits(led1_gpio, led1_pin);
case 1:
GPIO_ResetBits(led2_gpio, led2_pin);
default:
void led_toggle(rt_uint32_t n)
switch (n)
case 0:
GPIO_WriteBit(led1_gpio, led1_pin, (BitAction)((GPIO_ReadOutputDataBit(led1_gpio,led1_pin))^1) );
case 1:
GPIO_WriteBit(led2_gpio, led2_pin, (BitAction)((GPIO_ReadOutputDataBit(led2_gpio,led2_pin))^1) );
default:
void rt_led_disp_thread_entry(void* parameter)
rt_uint32_t i=0;
i=0x50000; //采用这种方式可运行
do{
i--;
}while(i>0);
led_toggle(0);
//rt_thread_delay(1); //采用延时函数 死机
i=0x50000;
do{
i--;
}while(i>0);
led_toggle(1);
void rt_led_disp_init(void)
rt_thread_t init_led_thread;
init_led_thread = rt_thread_create("led_disp", rt_led_disp_thread_entry, RT_NULL,
128, 28, 10);
if (init_led_thread != RT_NULL)
rt_thread_startup(init_led_thread);
static rt_uint8_t led_inited = 0;
void led(rt_uint32_t led, rt_uint32_t value)
/* init led configuration if it's not inited. */
if (!led_inited)
rt_hw_led_init();
led_inited = 1;
if ( led == 0 )
/* set led status */
switch (value)
case 0:
rt_hw_led_off(0);
case 1:
rt_hw_led_on(0);
default:
if ( led == 1 )
switch (value)
case 0:
rt_hw_led_off(1);
case 1:
rt_hw_led_on(1);
default:
#ifdef RT_USING_FINSH
#include <finsh.h>
FINSH_FUNCTION_EXPORT(led, set led[0 - 1] on[1] or off[0])
FINSH_FUNCTION_EXPORT(led_toggle, toggle the leds)
函数调用为
int rt_application_init()
rt_thread_t init_thread;
#if (RT_THREAD_PRIORITY_MAX == 32)
init_thread = rt_thread_create("init",
rt_init_thread_entry, RT_NULL,
2048, 8, 20);
#else
2048, 80, 20);
rt_led_disp_init(); //LED灯任务
if (init_thread != RT_NULL)
rt_thread_startup(init_thread);
return 0;
