发表于 2010-8-10 15:55:23
而且我往FLASH里下载时出现了这样的错误:
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd F:/EDA/qq/demo6/software/flash/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --offset=0x0 --input="F:/EDA/qq/demo6/flash.sof"
--output="flash.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert F:/EDA/qq/demo6/flash.sof flash
.rbf
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 57 megabytes
Info: Processing ended: Tue Aug 10 15:42:04 2010
Info: Elapsed time: 00:00:01
Info: Total CPU time (on all processors): 00:00:01
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x01400000 "flash.flash"
There are no Nios II processors available which match the values specified.
Please check that your PLD is correctly configured, downloading a new SOF
file if necessary.
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x01400000 --end=0x17fffff --reset=0x1400
000 --input="flash.elf" --output="cfi_flash.flash" --boot="D:/altera/91/ip/alter
a/nios2_ip/altera_nios2/boot_loader_cfi.srec"
# Programming flash with the project
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x01400000 "cfi_flash.flash
file if necessary.
郁闷啊!希望高手可以指点迷经! |
