发表于 2010-8-10 09:48:12
static void GPIO_Configuration()
EXTI_InitTypeDef EXTI_InitStructure;
/* configure PE5 as eth RST */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOE,&GPIO_InitStructure);
GPIO_SetBits(GPIOE,GPIO_Pin_5);
//RST_1();
/* configure PE4 as external interrupt */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
GPIO_Init(GPIOE, &GPIO_InitStructure);
不知道这个地方你是不是只把PE4改成了PA1, 估计因为GPIO_Mode 为下拉输入的原因,所以一直为低电平
/* Connect DM9000 EXTI Line to GPIOE Pin 4 */
GPIO_EXTILineConfig(GPIO_PortSourceGPIOE, GPIO_PinSource4);
/* Configure DM9000 EXTI Line to generate an interrupt on falling edge */
EXTI_InitStructure.EXTI_Line = EXTI_Line4;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure); |
