我也DIY了一个XILINX USB下载线,按照论坛上提供的原理图。 按照论坛的顺序 先下载 eeprom的 XILINX_EEPROM.IIC 到24C02 , 然后连接下载线,并自动按照好了下载线,在设备管理器上显示的也和论坛上一样。
开始-运行-cmd 回车
输入 SET XIL_IMPACT_ENV_USB2_FORCE_CPLD_UPDATE=TRUE 回车
再输入 impact 回车
Welcome to iMPACT
iMPACT Version: 10.1
// *** BATCH CMD : setMode -bs
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
AutoDetecting cable. Please wait.
PROGRESS_START - Starting Operation.
Connecting to cable (Parallel Port - LPT1).
Checking cable driver.
Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811.
Cable connection failed.
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
Connecting to cable (Usb Port - USB21).
Driver file xusbdfwu.sys found.
Driver version: src=1027, dest=1027.
Cable PID = 0008.
Max current requested during enumeration is 74 mA.
Type = 0x0004.
Cable Type = 3, Revision = 0.
Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 1029.
File version of d:/Xilinx/10.1/ISE/data/xusb_xlp.hex = 1302.
Firmware hex file version = 1302.
Downloading d:/Xilinx/10.1/ISE/data/xusb_xlp.hex.
write cmdbuffer failed 20000015.
Error reading firmware version.
ESN option: 6C007000700061.
Error reading cpld version.
PROGRESS_END - End Operation.
Elapsed time = 14 sec.
Attempting to identify devices in the boundary-scan chain configuration...// *** BATCH CMD : Identify
// *** BATCH CMD : identifyMPM
无法更新 CPLD程序。 那位高人指点一下,(xc2c256的CPLD程序是这么下载的吗?) 用的芯片是 cy7c68013-ac100 xc2c256vqg100-7i 之间的连接核对无误。
怎么会出现错误? 不得解。。。。 |
