自己用的是网上一个开源的SD IP核 :neek_alternate_sd_card_controller
我先跑自己的程序发现这个错误 我以为是我自己的程序过大
后来 我就跑一个最简单的HELLO WORLD 也出现同样的错误
自己IP加入的 应该没有什么问题 求助
/cygdrive/c/altera/90/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: region sd_controller_inst is full (hello_sd.elf section .text). Region needs to be 44536 bytes larger.
/cygdrive/c/altera/90/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: region sd_controller_inst is full (hello_sd.elf section .rodata). Region needs to be 248 bytes larger.
/cygdrive/c/altera/90/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: region sd_controller_inst is full (hello_sd.elf section .rwdata). Region needs to be 5720 bytes larger.
/cygdrive/c/altera/90/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rodata [01001400 -> 010018f7] overlaps section .text [01001400 -> 0100c5f7]
/cygdrive/c/altera/90/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rwdata [01001400 -> 01002e57] overlaps section .text [01001400 -> 0100c5f7]
/cygdrive/c/altera/90/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .bss [01001400 -> 01001613] overlaps section .text [01001400 -> 0100c5f7]
/cygdrive/c/altera/90/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/lib/mno-hw-mul/libc.a(sbrkr.o)(.text+0x14): In function `_sbrk_r':
/build/nios2eds-gnutools-win32-9.0/bin/nios2-gnutools/src/newlib/newlib/libc/reent/sbrkr.c:59: Unable to reach errno (at 0x01001400) from the global pointer (at 0x0100adec) because the offset (-39404) is out of the allowed range, -32678 to 32767. |
