发表于 2010-8-2 16:26:42
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd E:/modulesim_exe/nios/sdram/software/hello_world_0/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="E:/modulesim_exe/nios/sdram/sdra
m_ctrl.sof" --output="sdram_ctrl.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=sdram
_ctrl.opt E:/modulesim_exe/nios/sdram/sdram_ctrl.sof sdram_ctrl.pof
Info: The Active Serial/Parallel mode CONF_DONE pin error check is disabled
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 73 megabytes
Info: Processing ended: Mon Aug 02 16:11:02 2010
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:03
Info: Command: quartus_cpf --no_banner --convert sdram_ctrl.pof sdram_ctrl.rpd
Info: Peak virtual memory: 71 megabytes
Info: Processing ended: Mon Aug 02 16:11:07 2010
Info: Elapsed time: 00:00:04
Info: Total CPU time (on all processors): 00:00:04
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x01003800 --instance
=0 "sdram_ctrl.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
: Checksumming existing contents
00000000 : Verifying existing contents
00010000 : Verifying existing contents
00000000 : Reading existing contents
00010000 : Reading existing contents
Checksummed/read 22kB in 0.7s
00000000 ( 0%): Erasing
00010000 (50%): Erasing
Erased 128kB in 1.6s (80.0kB/s)
00000000 ( 0%): Programming
00010000 (50%): Programming
Programmed 107KB +21KB in 3.1s (41.2KB/s)
Did not attempt to verify device contents
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="sdram_ctrl.flash" --input="hello
_world_0.elf" --output="EPCS_flash.flash"
# Programming flash with the project
=0 "EPCS_flash.flash"
Checksummed/read 64kB in 1.6s
00010000 ( 0%): Erasing
Erased 64kB in 0.7s (91.4kB/s)
00010000 ( 0%): Programming
Programmed 1KB +63KB in 1.5s (42.6KB/s)
Leaving target processor paused |
