发表于 2010-7-31 17:44:42
OMAP3530 processor highlights:
* Over 1,200 Dhrystone MIPS using the superscalar ARM Cortex-A8 with highly accurate branch prediction and 256KB L2 cache running at up to 600MHz
* OpenGL© ES 2.0 capable 2D/3D graphics accelerator capable of rendering 10 million polygons per second
* HD video capable TMS320C64x+ DSP for versatile signal processing at up to 430MHz
* USB power via complete chip-set with minimal additional power-consuming logic
Expansion capability and power options to satisfy your imagination:
* DVI-D for connecting digital computer monitors
* Compatibility with a huge collection of USB peripherals including hubs, keyboards, mice, WiFi, Bluetooth, web cameras, and much more
* MMC+/SD/SDIO interface for memory or wireless connectivity
* S-Video out for connecting your NTSC or PAL television or wearable visor
* Stereo audio in and out for a microphone and headphones or speakers
* Power via typical USB chargers for cell phones from your laptop, from an automobile adapter, from batteries, or even from a solar backpack
这个板子好强呀。
找到了这个 评估价格 899 DevKit8000
·OMAP3530应用处理器(Pin to Pin兼容OMAP3503,OMAP3515,OMAP3525处理器)
-600-MHzARMCortex-A8 Core
-412-MHz TMS320C64x+DSPCore
-集成存储器用于ARMCPU (16kB I-Cache, 16kB D-Cache, 256kB L2) 和片上存储 (64kB SRAM, 112kB ROM)
·128MByte DDR SDRAM(芯片:MT29C1G24MADLAJA-6IT),32bit
·128MByte NAND Flash(芯片:MT29C1G24MADLAJA-6IT)
·一个S-VIDEO接口
·1个HDMI接口(芯片:TFP410),可输出分辨率1280x720,码率30fps的DVI-D高清信号
·24bit真彩色LCD接口(含4线触摸屏接口,分辨率可支持2048x2048)
·一个音频输入接口
·一个双声道音频输出接口
·一个10/100M以太网(芯片:DM9000,RJ45接口)
·1个高速USB2.0 OTG接口(芯片:TPS65930),速度达480Mbps
·2个串口(1个3线RS232电平串口,1个5线TTL电平串口)
·1个SD/MMC接口(支持3.3V及1.8V逻辑电压)
·1个6x6键盘接口
·1个14针标准JTAG接口
·1个CAMERA接口(可外接CCD和CMOS的摄像头)
·4个按键(1个启动引导按键,1个复位按键及2个用户按键)
·扩展接口(包含McSPI, McBSP, I2C, HDQ及SD/MMC接口)
·主板尺寸 : 110 mm x 95 mm
·输入电压 : +5V
·工作温度 : -40 to 85℃(芯片支持)
·操作湿度 : 20% ~ 90% |
