发表于 2010-7-27 11:19:00
以下是原因和解决方法:
Recommendation
This violation typically arises when an alternate graphical mode is defined for a component and either:
• An extra pin has been added to the display that is not specified in the Normal display mode or
• A pin has been specified with a different Designator and/or Name to a pin specified in the Normal display mode.
Not only must there be an identical number of pins between graphical display modes, the pins must be identical in both Designator and Name.
In the source schematic library, display the offending display mode for the component and delete the extra pin. This can be performed directly on the schematic sheet for a part that has been placed already, but you would typically tackle the problem from within the library, then push the change across |
