以前使用EP2C8建立NIOS II软核,epcs-flash引脚不需要设置。
![](http://cache.amobbs.com/bbs_upload782111/files_31/ourdev_569943.JPG)
(原文件名:1.JPG)
Error: Can't place multiple pins assigned to pin location Pin_12 (IOPAD_X0_Y25_N7)
Info: Pin sdo_from_the_epcs_flash is assigned to pin location Pin_12 (IOPAD_X0_Y25_N7)
Info: Pin ~ALTERA_ASDO_DATA1~ is assigned to pin location Pin_12 (IOPAD_X0_Y25_N7)
Error: Can't place multiple pins assigned to pin location Pin_14 (IOPAD_X0_Y24_N7)
Info: Pin sce_from_the_epcs_flash is assigned to pin location Pin_14 (IOPAD_X0_Y24_N7)
Info: Pin ~ALTERA_FLASH_nCE_nCSO~ is assigned to pin location Pin_14 (IOPAD_X0_Y24_N7)
Error: Can't place multiple pins assigned to pin location Pin_23 (IOPAD_X0_Y20_N14)
Info: Pin dclk_from_the_epcs_flash is assigned to pin location Pin_23 (IOPAD_X0_Y20_N14)
Info: Pin ~ALTERA_DCLK~ is assigned to pin location Pin_23 (IOPAD_X0_Y20_N14)
Error: Can't place multiple pins assigned to pin location Pin_24 (IOPAD_X0_Y20_N21)
Info: Pin data0_to_the_epcs_flash is assigned to pin location Pin_24 (IOPAD_X0_Y20_N21)
Info: Pin ~ALTERA_DATA0~ is assigned to pin location Pin_24 (IOPAD_X0_Y20_N21)
Info: Fitter preparation operations ending: elapsed time is 00:00:01
Error: Can't fit design in device
Error: Quartus II Fitter was unsuccessful. 5 errors, 0 warnings
Error: Peak virtual memory: 203 megabytes
Error: Processing ended: Thu Jul 22 14:36:32 2010
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:02
Error: Quartus II Full Compilation was unsuccessful. 7 errors, 50 warnings |
