大家好,我前两天在ebay买的电机, 控制板和电源(买的时候他说是nema23, 但电机上面标的是57BYGH408-06, 控制板是基于TB6560的3轴控制板, 电源他说是24v 6.3A 结果给我邮来了个36v 9.6A的), 经过测试最多只能驱动一个电机, 偶尔可以驱动两个但是力量小到用手都能让他停止!
请大家看看这样的配置可以吗, 为什么只能驱动一个电机呢, 是电流不够吗, 还是什么情况? 我是新手啊,请大家多多帮忙!谢谢了!
下面是参数和图片!
Stepper Motor , 21kg.cm ( 290 oz-in)
Step Agle-----------------------------1.8°±5%
Insultion Resistant--------500V DC 100MΩ Min
Insultion Strength--------50Hz 1Minute 500V Min
Ambient Temperature ----------—20℃~+50℃
Temperature Rise--------------------------80℃ Max.
Radial Play-------------------------------0.02mm Max.
End Play---------------------------------------0.1-0.3m
57BYGH408
o Step Agle :1.8°±5%
o 2 Phase 4 Wires
o Current :3.0A
o Voltage :3.6V
o Max.Static torque :21kg.cm
o resistance 1.2 Ω mH 4
o Weight :1.5KG
Specifications
Electrical properties (ambient temperature Tj = 25 pm)
Input Power
12 - 36V DC power supply
Stepper motor drive current
3A (peak value 3.5A)/axis
Drive type
Double-pole constant flow PWM actuation output
Compatible Stepper motors
2/4 Phase, 4/6/8 leads stepper motors within 3.5A
Features:
* Toshiba TB6560AHQ chip - maximum 3.5A drive current, more powerful
* 1 - 1/16 microstep setting - higher accuracy, smoother operation !
* Overload & over-current & over-temperature protection, full protection of your computer and peripheral equipment
* 4 files current settings can be set according to the user the actual current requirement
* Full closed-type optical isolation to protect the user's computer and equipment
* Professional design, two-stage signal processing, super anti-jamming
* Bipolar constant current chopper drive motor low-speed non-creeping phenomenon, noise, non-resonant region
* Four input control, you can set limit, emergency stop, which is divided into pairs of knives
Attention:
* Please connect the power supply to the power switch of 12-36 V, 8A
* The power output of 12V shall be applied to the radiator fan of 12V
* The interface of driver shall be connected with 2/4 phase, 4/6/8 leads stepper motor within 3A current
* This board can work with both unipolar and bipolar stepper motors
* The spindle motor is controlled by Parallel Interface. The voltage of the spindle motor must comply with the scope of the supply voltage.
(原文件名:3p stepper.gif)
(原文件名:1p stepper.gif)
(原文件名:control.gif)
(原文件名:power.gif) |
