小弟的程序,基于状态机的4*4键盘,最简单的想按键弹起时返回键值,但是看了老久了,就是找不出毛病,麻烦给看看吧,快疯了!!!
#define uint unsigned int
#define NO_KEY 0x00
#define key_k1 '1'
#define key_k2 '2'
#define key_k3 '3'
#define key_k4 '4'
#define key_k5 '5'
#define key_k6 '6'
#define key_k7 '7'
#define key_k8 '8'
#define key_k9 '9'
#define key_k0 '0'
#define key_k10 'A'
#define key_k11 'B'
#define key_k12 'C'
#define key_k13 'D'
#define key_k14 'E'
#define key_k15 'F'
char Key_time_ok;
void initialize_timer(void)
TCNT0=0x00; // {(0xff-0x70)+1}*1024*(1/14.7456MHz)=10ms
TCCR0=0x06; // 定时器0 prescaler=1024
TIMSK=0x01; // OCIE0=1,定时器0溢出标志
SREG = 0x80; //使能全局中断
#pragma interrupt_handler timer0:17
void timer0(void)
TCNT0=0x00;
Key_time_ok=1;
uchar GetKeyCode(void)
uchar i;
DDRC=0xf0; //高4位输出,低4位输入
PORTC=0x0f;//高4位输出0,低4位带上拉输入
//delay_nms(1);
waitsomeNOP(); //等待8个时钟周期(NOP)
i=PINC&0x0f;
/*获取行地址*/
DDRC=0x0f;//高4位输入,低4位输出
PORTC=0xf0;//低4位输出0,高4位带上拉输入
//delay_nms(1);
waitsomeNOP();
i|=PINC&0xf0;
return i;
uchar get_key(void)
static char KeyState = 0; //按键状态
static char KeyPrev1 = 0; //上一次按键
static char KeyPrev = 0; //新一次按键
char KeyPress = NO_KEY; //按键值
char KeyReturn = NO_KEY; //按键返回值
KeyPress = GetKeyCode();
switch(KeyState)
//按键初始态00
case 0:
if( KeyPress !=NO_KEY )
KeyState = 1;
KeyPrev1 = KeyPress;
//按键确认态01
case 1:
//与上次按键不同,是乱码
if(KeyPrev1 != KeyPress)
KeyState = 0;
KeyState = 2;
switch (KeyPress) // 与状态1的相同,确认按键
{ // 键盘编码,返回编码值
case 0Xdb: KeyPrev = key_k0; break;
case 0X77: KeyPrev = key_k1; break;
case 0X7b: KeyPrev = key_k2; break;
case 0X7d: KeyPrev = key_k3; break;
case 0X7e: KeyPrev = key_k4; break;
case 0Xb7: KeyPrev = key_k5; break;
case 0Xbb: KeyPrev = key_k6; break;
case 0Xbd: KeyPrev = key_k7; break;
case 0Xbe: KeyPrev = key_k8; break;
case 0Xd7: KeyPrev = key_k9; break;
case 0Xdd: KeyPrev = key_k10;break;
case 0Xde: KeyPrev = key_k11;break;
case 0Xe7: KeyPrev = key_k12;break;
case 0Xeb: KeyPrev = key_k13;break;
case 0Xed: KeyPrev = key_k14;break;
case 0Xee: KeyPrev = key_k15;break;
default :break;
{//按键抬起,是抖动,不响应按键
KeyState = 0;
//按键释放态10
case 2:
if(KeyPress == NO_KEY )
KeyState = 0;
KeyReturn = KeyPrev; //返回按键抬起值
default :break;
return KeyReturn;
void main()
initialize_timer();
Uchar MMtemp;
if(Key_time_ok==1)
Key_time_ok=0;
MMtemp=get_key(); //有按键按下时
if(MMtemp=='1')
sendbyte(0xff);
