#define BEEP GPIO_PIN_7
int main(void)
GPIOPinWrite(GPIO_PORTA_BASE,BEEP,~BEEP); //ln89
GPIOPinWrite(GPIO_PORTA_BASE,BEEP,~BEEP); //ln97
编译后出现如下warning:
Messages File Line
Warning[Pe069]: integer conversion resulted in truncation E:\开发板\LM3S8962开发\EasyArm8962(原厂光盘刻录)\DEMO\IAR实验例程\chapter4\4.2_SetPLL\SetPLL.c 89
Warning[Pe069]: integer conversion resulted in truncation E:\开发板\LM3S8962开发\EasyArm8962(原厂光盘刻录)\DEMO\IAR实验例程\chapter4\4.2_SetPLL\SetPLL.c 97
个人判断:
“integer conversion resulted in truncation” 直译为“整数转换导致切断”,
做如下任意修改就不再出现上述警告了,真是怪异
1、将“~BEEP”改为“BEEP”后就没有上述警告了;
这个警告真的没道理呀
环境:keil rvmdk
EasyArm8962 开发板 |
