开发板自带的是verilog程序,我学的是VHDL,写流水灯的程序,遇到问题,
程序和报错信息如下
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity led is
Port ( mclk : in STD_LOGIC;
led : out STD_LOGIC_VECTOR (7 downto 0));
end led;
architecture Behavioral of led is
signal count:std_logic_vector(24 downto 0);
signal clock:std_logic;
signal state:std_logic_vector(3 downto 0);
begin
--分频
process(mclk)
begin
if mclk'event and mclk='1' then
count<=count+1;
end if;
end process;
--divclk<=count(24);
clock<=count(24);
--流水灯
process(clock)
begin
if clock'event and clock='1' then
-- with state select
-- led<=0000_0001 when 0000
-- 0000_0010 when 0001
-- 0000_0010 when 0010
-- 0000_0100 when 0100
-- 0000_1000 when 0101
-- 0000_1010 when 0110
-- 0000_0010 when 0111
-- 0000_0010 when 1000
case state is
when "0000" =>led<="00000001";
when "0001" =>led<="00000010";
when "0010" =>led<="00000100";
when "0011" =>led<="00001000";
when "0100" =>led<="00010000";
when "0101" =>led<="00100000";
when "0110" =>led<="10000000";
when "0111" =>led<="10000000";
when "1000" =>led<="01000000";
when "1001" =>led<="00100000";
when "1010" =>led<="00010000";
when "1011" =>led<="00001000";
when "1100" =>led<="00000100";
when "1101" =>led<="00000010";
when "1110" =>led<="00000001";
when "1111" =>led<="11111111";
when others=> led<="00000000";
end case;
end if;
state<=state+1;
end process;
end Behavioral;
ERROR:Pack:198 - NCD was not produced. All logic was removed from design. This
is usually due to having no input or output PAD connections in the design and
no nets or symbols marked as 'SAVE'. You can either add PADs or 'SAVE'
attributes to the design, or run 'map -u' to disable logic trimming in the
mapper. |
