发表于 2010-6-12 12:38:59
voidx真是高手啊,学习了,谢谢
贴出问题的出处,给大家参考
eMBErrorCode
eMBRTUInit( UCHAR ucSlaveAddress, UCHAR ucPort, ULONG ulBaudRate, eMBParity eParity )
eMBErrorCode eStatus = MB_ENOERR;
ULONG usTimerT35_50us;
( void )ucSlaveAddress;
ENTER_CRITICAL_SECTION( );
/* Modbus RTU uses 8 Databits. */
if( xMBPortSerialInit( ucPort, ulBaudRate, 8, eParity ) != TRUE )
eStatus = MB_EPORTERR;
/* If baudrate > 19200 then we should use the fixed timer values
* t35 = 1750us. Otherwise t35 must be 3.5 times the character time.
if( ulBaudRate > 19200 )
usTimerT35_50us = 35; /* 1800us. */
/* The timer reload value for a character is given by:
* ChTimeValue = Ticks_per_1s / ( Baudrate / 11 )
* = 11 * Ticks_per_1s / Baudrate
* = 220000 / Baudrate
* The reload for t3.5 is 1.5 times this value and similary
* for t3.5.
usTimerT35_50us = ( 7UL * 220000UL ) / ( 2UL * ulBaudRate );
if( xMBPortTimersInit( ( USHORT ) usTimerT35_50us ) != TRUE )
EXIT_CRITICAL_SECTION( );
return eStatus;
ucSlaveAddress确实没有用到:) |
