at91sam7x256的程序,uart0,接收和发送都能得到数据,
但是数据不正确,
发送出来的数据0XAA,但是串口调试助手受到的是0xfe
代码如下:
#include <AT91SAM7X256.H>
#include "UART0.H"
#define Fosc 18432000
AT91PS_PIO GPIO_A=AT91C_BASE_PIOA;
AT91PS_USART UART0 =AT91C_BASE_US0;
AT91S_AIC * pAIC=AT91C_BASE_AIC;
unsigned char DacContralBuff[16];
void SendChar(unsigned char CH)
while(!(UART0->US_CSR&0X02));
UART0->US_THR=CH;
unsigned char GetChar()
unsigned char ch;
return ch;
__irq void Usart0ISR(void)
*AT91C_AIC_ICCR|=(1 << AT91C_ID_US0);
if(UART0->US_CSR&0X01)
DacContralBuff[0]=UART0->US_RHR&0xff;
SendChar(DacContralBuff[0]);
*AT91C_AIC_EOICR = 0X00;
__inline unsigned int AT91F_US_Baudrate (
const unsigned int main_clock, // \arg peripheral clock
const unsigned int baud_rate) // \arg UART baudrate
unsigned int baud_value = ((main_clock*10)/(baud_rate * 16));
if ((baud_value % 10) >= 5)
baud_value = (baud_value / 10) + 1;
baud_value /= 10;
return baud_value;
//* \fn AT91F_US_SetBaudrate
//* \brief Set the baudrate according to the CPU clock
__inline void AT91F_US_SetBaudrate (
AT91PS_USART pUSART, // \arg pointer to a USART controller
unsigned int mainClock, // \arg peripheral clock
unsigned int speed) // \arg UART baudrate
//* Define the baud rate divisor register
pUSART->US_BRGR = AT91F_US_Baudrate(mainClock, speed);
//* \fn AT91F_US_SetTimeguard
//* \brief Set USART timeguard
__inline void AT91F_US_SetTimeguard (
unsigned int timeguard) // \arg timeguard value
//* Write the Timeguard Register
pUSART->US_TTGR = timeguard ;
void Init_UART0()
unsigned int temp=0;
GPIO_A->PIO_PER =0XfFFFFFFF;
GPIO_A->PIO_OER=0X03;//PA0,PA1设置为输出
GPIO_A->PIO_SODR =0X03; //设置为高
*AT91C_PMC_PCER = (unsigned int)1<<AT91C_ID_US0; //允许US0口的时钟
GPIO_A->PIO_PDR =0x03; //设为外设
GPIO_A->PIO_ASR =0X03; //设为外设A
UART0->US_CR|= AT91C_US_RSTRX | /* Reset Receiver */
AT91C_US_RSTTX | /* Reset Transmitter */
AT91C_US_RXDIS | /* Receiver Disable */
AT91C_US_TXDIS; /* Transmitter Disable */
// UART0->US_MR=0X108C0; //主时钟,8位数据,一位停止位,无校验 ,高位在前,异步模式
UART0->US_MR=AT91C_US_USMODE_NORMAL | /* Normal Mode */
AT91C_US_CLKS_CLOCK | /* Clock = MCK */
AT91C_US_CHRL_8_BITS | /* 8-bit Data */
AT91C_US_PAR_NONE | /* No Parity *///OVER=1 溢出错误
AT91C_US_NBSTOP_1_BIT |
AT91C_US_MSBF; /* 1 Stop Bit */ //SYNC=0异步 SYNC=1同步
//异步模式 波特率=MCK/16/BRD或MCK/8/BRD;同步为波特率=MCK/BRD
UART0->US_BRGR=Fosc/(9600*16); //AT91F_US_Baudrate(Fosc,9600);//
// UART0->US_BRGR|=Fosc/(9600*16)<<8;
UART0->US_CR=0X50;
UART0->US_CR |= AT91C_US_RXEN | /* Receiver Enable */
AT91C_US_TXEN; /* Transmitter Enable */
//UART0->US_IDR=0;
//UART0->US_CSR//通道状态寄存器 2-发送状态,1-接收状态
/* Setup Usart Interrupt Mode and Vector with Priority 7 and Enable it */
// pAIC->AIC_SMR[AT91C_ID_US1] = 5;//设置触发模式和优先级7等级最高
pAIC->AIC_SMR[AT91C_ID_US0] = 6; //双串口中断方式接收数据需设优先级
UART0->US_IER =AT91C_US_RXRDY; //接收中断使能
// pUSART1->US_IER =AT91C_US_RXRDY;
pAIC->AIC_SVR[AT91C_ID_US0] = (unsigned long) Usart0ISR;//串口0中断地址放入向量表
// pAIC->AIC_SVR[AT91C_ID_US1] = (unsigned long) Usart1ISR;//串口1中断地址放入向量表
pAIC->AIC_IECR |=(1 << AT91C_ID_US0)|(1 << AT91C_ID_US1);//串口中断使能
UART0->US_IER=0X01; //接受中断使能
int main()
unsigned int i=0;
AT91F_LowLevelInit();
Init_GPIO();
Init_UART0();
//US0_init();
delay(0xffff);
i=~GPIO_B->PIO_PDSR;
if((i&Key1)==Key1)
GPIO_B->PIO_CODR|=LED1;
GPIO_B->PIO_SODR|=LED1;
if((i&Key2)==Key2)
GPIO_B->PIO_CODR|=LED2;
GPIO_B->PIO_SODR|=LED2;
if((i&Key3)==Key3)
GPIO_B->PIO_CODR|=LED3;
GPIO_B->PIO_SODR|=LED3;
if((i&Key4)==Key4)
GPIO_B->PIO_CODR|=LED4;
GPIO_B->PIO_SODR|=LED4;
// i=GPIO_B->PIO_ODSR;
SendChar(0X55);
// LED_Display();
// while(!(*AT91C_US0_CSR&0x02));
// *AT91C_US0_THR=0xaa;
delay(0xffffF);
return 0;
void AT91F_LowLevelInit(void)
unsigned char i;
// 1 Wait State necessary to work at 48MHz
AT91C_BASE_MC->MC_FMR = AT91C_MC_FWS_1FWS;
// Init PMC Step 1. Enable Main Oscillator 使能主振荡时钟
// Main Oscillator startup time is board specific:
// Main Oscillator Startup Time worst case (3MHz) corresponds to 15ms (0x40 for AT91C_CKGR_OSCOUNT field)
AT91C_BASE_PMC->PMC_MOR = (( AT91C_CKGR_OSCOUNT & (0x40 <<8) | AT91C_CKGR_MOSCEN ));
// Wait Main Oscillator stabilization
while(!(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_MOSCS));
// Init PMC Step 2. 配置PLL输出时钟和USB时钟 18.432 * (72+1)/14 = 96,109MHz
// Set PLL to 96MHz (96,109MHz) and UDP Clock to 48MHz
// PLL Startup time depends on PLL RC filter: worst case is choosen
// UDP Clock (48,058MHz) is compliant with the Universal Serial Bus Specification (+/- 0.25% for full speed)
AT91C_BASE_PMC->PMC_PLLR = AT91C_CKGR_USBDIV_1 | AT91C_CKGR_OUT_0 | AT91C_CKGR_PLLCOUNT |
(AT91C_CKGR_MUL & (72 << 16)) | (AT91C_CKGR_DIV & 14);
// Wait for PLL stabilization
while( !(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_LOCK) );
// Wait until the master clock is established for the case we already turn on the PLL
while( !(AT91C_BASE_PMC->PMC_SR & AT91C_PMC_MCKRDY) );
// Init PMC Step 3. 配置MCK为PLL输出分频2,处理器时钟PCK等于MCK
// Selection of Master Clock MCK (equal to Processor Clock PCK) equal to PLL/2 = 48MHz
// The PMC_MCKR register must not be programmed in a single write operation (see. Product Errata Sheet)
AT91C_BASE_PMC->PMC_MCKR = AT91C_PMC_PRES_CLK_2; // 分频2
AT91C_BASE_PMC->PMC_MCKR |= AT91C_PMC_CSS_PLL_CLK;//选PLL为时钟
// Disable Watchdog (write once register)
AT91C_BASE_WDTC->WDTC_WDMR = AT91C_WDTC_WDDIS;
// Init AIC: assign corresponding handler for each interrupt source
AT91C_BASE_AIC->AIC_SVR[0] = (int) AT91F_Default_FIQ_handler ;
for (i = 1; i < 31; i++)
AT91C_BASE_AIC->AIC_SVR = (int) AT91F_Default_IRQ_handler ;
AT91C_BASE_AIC->AIC_SPU = (unsigned int) AT91F_Spurious_handler;
各位用这个片子的朋友帮我看一下,问题出哪儿了 |
