发表于 2010-6-4 14:36:57
/* Copyright (c) 2002 - 2007 Marek Michalkiewicz
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in
the documentation and/or other materials provided with the
distribution.
* Neither the name of the copyright holders nor the names of
contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE. */
/* $Id: pgmspace.h,v 1.40 2007/03/30 04:37:14 arcanum Exp $ */
pgmspace.h
Contributors:
Created by Marek Michalkiewicz <marekm@linux.org.pl>
Eric B. Weddington <eric@ecentral.com>
Wolfgang Haidinger <wh@vmars.tuwien.ac.at> (pgm_read_dword())
/** \file */
/** \defgroup avr_pgmspace <avr/pgmspace.h>: Program Space Utilities
\code
#include <avr/io.h>
#include <avr/pgmspace.h>
\endcode
The functions in this module provide interfaces for a program to access
data stored in program space (flash memory) of the device. In order to
use these functions, the target device must support either the \c LPM or
\c ELPM instructions.
\note These functions are an attempt to provide some compatibility with
header files that come with IAR C, to make porting applications between
different compilers easier. This is not 100% compatibility though (GCC
does not have full support for multiple address spaces yet).
\note If you are working with strings which are completely based in ram,
use the standard string functions described in \ref avr_string.
\note If possible, put your constant tables in the lower 64 KB and use
pgm_read_byte_near() or pgm_read_word_near() instead of
pgm_read_byte_far() or pgm_read_word_far() since it is more efficient that
way, and you can still use the upper 64K for executable code.
All functions that are suffixed with a \c _P \e require their
arguments to be in the lower 64 KB of the flash ROM, as they do
not use ELPM instructions. This is normally not a big concern as
the linker setup arranges any program space constants declared
using the macros from this header file so they are placed right after
the interrupt vectors, and in front of any executable code. However,
it can become a problem if there are too many of these constants, or
for bootloaders on devices with more than 64 KB of ROM.
<em>All these functions will not work in that situation.</em>
#ifndef __PGMSPACE_H_
#define __PGMSPACE_H_ 1
#define __need_size_t
#include <inttypes.h>
#include <stddef.h>
#include <avr/io.h>
#ifndef __ATTR_CONST__
#define __ATTR_CONST__ __attribute__((__const__))
#ifndef __ATTR_PROGMEM__
#define __ATTR_PROGMEM__ __attribute__((__progmem__))
#ifndef __ATTR_PURE__
#define __ATTR_PURE__ __attribute__((__pure__))
\ingroup avr_pgmspace
\def PROGMEM
Attribute to use in order to declare an object being located in
flash ROM.
#define PROGMEM __ATTR_PROGMEM__
#ifdef __cplusplus
extern "C" {
#if defined(__DOXYGEN__)
* Doxygen doesn't grok the appended attribute syntax of
* GCC, and confuses the typedefs with function decls, so
* supply a doxygen-friendly view.
\typedef prog_void
Type of a "void" object located in flash ROM. Does not make much
sense by itself, but can be used to declare a "void *" object in
flash ROM.
typedef void PROGMEM prog_void;
\typedef prog_char
Type of a "char" object located in flash ROM.
typedef char PROGMEM prog_char;
\typedef prog_uchar
Type of an "unsigned char" object located in flash ROM.
typedef unsigned char PROGMEM prog_uchar;
\typedef prog_int8_t
Type of an "int8_t" object located in flash ROM.
typedef int8_t PROGMEM prog_int8_t;
\typedef prog_uint8_t
Type of an "uint8_t" object located in flash ROM.
typedef uint8_t PROGMEM prog_uint8_t;
\typedef prog_int16_t
Type of an "int16_t" object located in flash ROM.
typedef int16_t PROGMEM prog_int16_t;
\typedef prog_uint16_t
Type of an "uint16_t" object located in flash ROM.
typedef uint16_t PROGMEM prog_uint16_t;
\typedef prog_int32_t
Type of an "int32_t" object located in flash ROM.
typedef int32_t PROGMEM prog_int32_t;
\typedef prog_uint32_t
Type of an "uint32_t" object located in flash ROM.
typedef uint32_t PROGMEM prog_uint32_t;
\typedef prog_int64_t
Type of an "int64_t" object located in flash ROM.
\note This type is not available when the compiler
option -mint8 is in effect.
typedef int64_t PROGMEM prog_int64_t;
\typedef prog_uint64_t
Type of an "uint64_t" object located in flash ROM.
typedef uint64_t PROGMEM prog_uint64_t;
#else /* !DOXYGEN */
typedef void prog_void PROGMEM;
typedef char prog_char PROGMEM;
typedef unsigned char prog_uchar PROGMEM;
typedef int8_t prog_int8_t PROGMEM;
typedef uint8_t prog_uint8_t PROGMEM;
typedef int16_t prog_int16_t PROGMEM;
typedef uint16_t prog_uint16_t PROGMEM;
typedef int32_t prog_int32_t PROGMEM;
typedef uint32_t prog_uint32_t PROGMEM;
#if !__USING_MINT8
typedef int64_t prog_int64_t PROGMEM;
typedef uint64_t prog_uint64_t PROGMEM;
#endif /* defined(__DOXYGEN__) */
/* Although in C, we can get away with just using __c, it does not work in
C++. We need to use &__c[0] to avoid the compiler puking. Dave Hylands
explaned it thusly,
Let's suppose that we use PSTR("Test"). In this case, the type returned
by __c is a prog_char[5] and not a prog_char *. While these are
compatible, they aren't the same thing (especially in C++). The type
returned by &__c[0] is a prog_char *, which explains why it works
fine. */
* The #define below is just a dummy that serves documentation
* purposes only.
/** \ingroup avr_pgmspace
\def PSTR(s)
Used to declare a static pointer to a string in program space. */
# define PSTR(s) ((const PROGMEM char *)(s))
/* The real thing. */
# define PSTR(s) (__extension__({static char __c[] PROGMEM = (s); &__c[0];}))
#endif /* DOXYGEN */
#define __LPM_classic__(addr) \
(__extension__({ \
uint16_t __addr16 = (uint16_t)(addr); \
uint8_t __result; \
__asm__ \
"lpm" "\n\t" \
"mov %0, r0" "\n\t" \
: "=r" (__result) \
: "z" (__addr16) \
: "r0" \
__result; \
#define __LPM_enhanced__(addr) \
(__extension__({ \
uint8_t __result; \
__asm__ \
"lpm %0, Z" "\n\t" \
: "=r" (__result) \
: "z" (__addr16) \
__result; \
#define __LPM_word_classic__(addr) \
(__extension__({ \
uint16_t __result; \
__asm__ \
"lpm" "\n\t" \
"mov %A0, r0" "\n\t" \
"adiw r30, 1" "\n\t" \
"lpm" "\n\t" \
"mov %B0, r0" "\n\t" \
: "=r" (__result), "=z" (__addr16) \
: "1" (__addr16) \
: "r0" \
__result; \
#define __LPM_word_enhanced__(addr) \
(__extension__({ \
__asm__ \
"lpm %A0, Z+" "\n\t" \
"lpm %B0, Z" "\n\t" \
: "1" (__addr16) \
__result; \
#define __LPM_dword_classic__(addr) \
(__extension__({ \
uint32_t __result; \
__asm__ \
"lpm" "\n\t" \
"lpm" "\n\t" \
"lpm" "\n\t" \
"mov %C0, r0" "\n\t" \
"lpm" "\n\t" \
"mov %D0, r0" "\n\t" \
: "1" (__addr16) \
: "r0" \
__result; \
#define __LPM_dword_enhanced__(addr) \
(__extension__({ \
__asm__ \
"lpm %B0, Z+" "\n\t" \
"lpm %C0, Z+" "\n\t" \
"lpm %D0, Z" "\n\t" \
: "1" (__addr16) \
__result; \
#if defined (__AVR_HAVE_LPMX__)
#define __LPM(addr) __LPM_enhanced__(addr)
#define __LPM_word(addr) __LPM_word_enhanced__(addr)
#define __LPM_dword(addr) __LPM_dword_enhanced__(addr)
#else
#define __LPM(addr) __LPM_classic__(addr)
#define __LPM_word(addr) __LPM_word_classic__(addr)
#define __LPM_dword(addr) __LPM_dword_classic__(addr)
\def pgm_read_byte_near(address_short)
Read a byte from the program space with a 16-bit (near) address.
\note The address is a byte address.
The address is in the program space. */
#define pgm_read_byte_near(address_short) __LPM((uint16_t)(address_short))
\def pgm_read_word_near(address_short)
Read a word from the program space with a 16-bit (near) address.
#define pgm_read_word_near(address_short) __LPM_word((uint16_t)(address_short))
\def pgm_read_dword_near(address_short)
Read a double word from the program space with a 16-bit (near) address.
#define pgm_read_dword_near(address_short) \
__LPM_dword((uint16_t)(address_short))
#if defined(RAMPZ) || defined(__DOXYGEN__)
/* Only for devices with more than 64K of program memory.
RAMPZ must be defined (see iom103.h, iom128.h).
/* The classic functions are needed for ATmega103. */
#define __ELPM_classic__(addr) \
(__extension__({ \
uint32_t __addr32 = (uint32_t)(addr); \
uint8_t __result; \
__asm__ \
"out %2, %C1" "\n\t" \
"mov r31, %B1" "\n\t" \
"mov r30, %A1" "\n\t" \
"elpm" "\n\t" \
: "=r" (__result) \
: "r" (__addr32), \
"I" (_SFR_IO_ADDR(RAMPZ)) \
: "r0", "r30", "r31" \
__result; \
#define __ELPM_enhanced__(addr) \
(__extension__({ \
uint8_t __result; \
__asm__ \
"movw r30, %1" "\n\t" \
"elpm %0, Z+" "\n\t" \
: "=r" (__result) \
: "r" (__addr32), \
: "r30", "r31" \
__result; \
#define __ELPM_word_classic__(addr) \
(__extension__({ \
__asm__ \
"elpm" "\n\t" \
"in r0, %2" "\n\t" \
"adc r0, __zero_reg__" "\n\t" \
"out %2, r0" "\n\t" \
"elpm" "\n\t" \
: "=r" (__result) \
: "r" (__addr32), \
__result; \
#define __ELPM_word_enhanced__(addr) \
(__extension__({ \
__asm__ \
"elpm %A0, Z+" "\n\t" \
"elpm %B0, Z" "\n\t" \
: "=r" (__result) \
: "r" (__addr32), \
: "r30", "r31" \
__result; \
#define __ELPM_dword_classic__(addr) \
(__extension__({ \
__asm__ \
"elpm" "\n\t" \
"elpm" "\n\t" \
"elpm" "\n\t" \
"elpm" "\n\t" \
: "=r" (__result) \
: "r" (__addr32), \
__result; \
#define __ELPM_dword_enhanced__(addr) \
(__extension__({ \
__asm__ \
"elpm %B0, Z+" "\n\t" \
"elpm %C0, Z+" "\n\t" \
"elpm %D0, Z" "\n\t" \
: "=r" (__result) \
: "r" (__addr32), \
: "r30", "r31" \
__result; \
#define __ELPM(addr) __ELPM_enhanced__(addr)
#define __ELPM_word(addr) __ELPM_word_enhanced__(addr)
#define __ELPM_dword(addr) __ELPM_dword_enhanced__(addr)
#else
#define __ELPM(addr) __ELPM_classic__(addr)
#define __ELPM_word(addr) __ELPM_word_classic__(addr)
#define __ELPM_dword(addr) __ELPM_dword_classic__(addr)
\def pgm_read_byte_far(address_long)
Read a byte from the program space with a 32-bit (far) address.
#define pgm_read_byte_far(address_long) __ELPM((uint32_t)(address_long))
\def pgm_read_word_far(address_long)
Read a word from the program space with a 32-bit (far) address.
#define pgm_read_word_far(address_long) __ELPM_word((uint32_t)(address_long))
\def pgm_read_dword_far(address_long)
Read a double word from the program space with a 32-bit (far) address.
#define pgm_read_dword_far(address_long) __ELPM_dword((uint32_t)(address_long))
#endif /* RAMPZ or __DOXYGEN__ */
\def pgm_read_byte(address_short)
#define pgm_read_byte(address_short) pgm_read_byte_near(address_short)
\def pgm_read_word(address_short)
#define pgm_read_word(address_short) pgm_read_word_near(address_short)
\def pgm_read_dword(address_short)
#define pgm_read_dword(address_short) pgm_read_dword_near(address_short)
\def PGM_P
Used to declare a variable that is a pointer to a string in program
space. */
#ifndef PGM_P
#define PGM_P const prog_char *
\def PGM_VOID_P
Used to declare a generic pointer to an object in program space. */
#ifndef PGM_VOID_P
#define PGM_VOID_P const prog_void *
extern PGM_VOID_P memchr_P(PGM_VOID_P s, int val, size_t len) __ATTR_CONST__;
extern int memcmp_P(const void *, PGM_VOID_P, size_t) __ATTR_PURE__;
extern void *memcpy_P(void *, PGM_VOID_P, size_t);
extern void *memmem_P(const void *, size_t, PGM_VOID_P, size_t) __ATTR_PURE__;
extern PGM_VOID_P memrchr_P(PGM_VOID_P s, int val, size_t len) __ATTR_CONST__;
extern char *strcat_P(char *, PGM_P);
extern PGM_P strchr_P(PGM_P s, int val) __ATTR_CONST__;
extern PGM_P strchrnul_P(PGM_P s, int val) __ATTR_CONST__;
extern int strcmp_P(const char *, PGM_P) __ATTR_PURE__;
extern char *strcpy_P(char *, PGM_P);
extern int strcasecmp_P(const char *, PGM_P) __ATTR_PURE__;
extern char *strcasestr_P(const char *, PGM_P) __ATTR_PURE__;
extern size_t strcspn_P(const char *s, PGM_P reject) __ATTR_PURE__;
extern size_t strlcat_P (char *, PGM_P, size_t );
extern size_t strlcpy_P (char *, PGM_P, size_t );
extern size_t strlen_P(PGM_P) __ATTR_CONST__; /* program memory can't change */
extern size_t strnlen_P(PGM_P, size_t) __ATTR_CONST__; /* program memory can't change */
extern int strncmp_P(const char *, PGM_P, size_t) __ATTR_PURE__;
extern int strncasecmp_P(const char *, PGM_P, size_t) __ATTR_PURE__;
extern char *strncat_P(char *, PGM_P, size_t);
extern char *strncpy_P(char *, PGM_P, size_t);
extern char *strpbrk_P(const char *s, PGM_P accept) __ATTR_PURE__;
extern PGM_P strrchr_P(PGM_P s, int val) __ATTR_CONST__;
extern char *strsep_P(char **sp, PGM_P delim);
extern size_t strspn_P(const char *s, PGM_P accept) __ATTR_PURE__;
extern char *strstr_P(const char *, PGM_P) __ATTR_PURE__;
#ifdef __cplusplus
#endif /* __PGMSPACE_H_ */ |
