发表于 2010-5-23 17:01:23
补充一下: 错误提示
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off roundshift -c roundshift
Error (10170): Verilog HDL syntax error at roundshift.v(7) near text "for"; expecting an identifier ("for" is a reserved keyword ), or "endmodule", or a parallel statement
Error (10170): Verilog HDL syntax error at roundshift.v(8) near text "}"; expecting ";", or ","
Error (10112): Ignored design unit "roundshift" at roundshift.v(1) due to previous errors
Info: Found 0 design units, including 0 entities, in source file roundshift.v
Error: Quartus II Analysis & Synthesis was unsuccessful. 3 errors, 0 warnings
Error: Peak virtual memory: 194 megabytes
Error: Processing ended: Sun May 23 16:45:32 2010
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 5 errors, 0 warnings |
