大家有用过HS162-4液晶的吗?我写了个驱动控制程序,但是始终显示有问题。本来想显示“FEIYONG:”但是最终显示的是“:F E I Y O N G "中间空格的地方会出现一个认不到的图案,大家帮忙找找原因啊!谢谢了!原程序如下:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity lcd1 is
Port (sysclk:in std_logic;-----20兆赫兹晶振
reset:in std_logic;
lcdda : out std_logic;--寄存器选择信号
lcdrw : out std_logic;--液晶读写信号
lcden : out std_logic;--液晶时钟信号
date : out std_logic_vector(7 downto 0));--液晶数据信号
end lcd1;
architecture Behavioral of lcd1 is
type state is (set_qp,set_gn,set_xskg,set_xsaddr,set_cgram,write_date,ting);--7种状态分别为清屏,功能设置,显示开关,设置CGRAM,独处数据,
停止。
signal current_state:state;
type ram2 is array(0 to 7) of std_logic_vector(7 downto 0);
constant cgram:ram2:=(("01000110"),("01000101"),("01001001"),("01011001"),
("01001111"),("01001110"),("01000111"),("00111010"));--字符数据存储器分别存储了“FEIYONG:”
signal cnt:std_logic_vector(24 downto 0);
signal clk1:std_logic;--状态机时钟信号,同时也是液晶时钟信号,其周期应该满足液晶数据的建立时间
begin
process(sysclk)-----2/3赫兹分频
begin
if sysclk'event and sysclk='1' then
if cnt=14999999 then clk1<=not clk1;cnt<=(others=>'0');
else cnt<=cnt+1;
end if;
end if;
end process;
lcden <= clk1 ; --液晶时钟信号
lcdrw <= '0' ; --写数据
control:process(clk1,reset,current_state)--液晶驱动控制器
variable cnt1: std_logic_vector(2 downto 0);
begin
if reset='0'then
current_state<=set_qp;
cnt1:="111";
lcdda<='0';
elsif rising_edge(clk1)then
if cnt1="111" then
date<="00001111";--0fH
current_state <=ting;
lcdda <= '0';
else current_state <=set_cgram;
end if;
case current_state is
when set_qp=>
date<="00000001";--01H
current_state<=set_gn;
when set_gn=>
date<="00111000";--38H
current_state<=set_xskg;
when set_xskg=>
current_state<=set_xsaddr;
when set_xsaddr=> --从第一行的起始地址开始显示
date<="10000000";--80H
current_state<=set_cgram;
when set_cgram=> --向CGRAM中写入
lcdda<='1';
date<=cgram(conv_integer(cnt1));
cnt1:=cnt1+1;
current_state<=write_date;
when write_date=>
lcdda<='1';
date<="00000000"; --写入字符
when others => null;
end case;
end if;
end process;
end Behavioral;
HS162-4液晶显示使用说明ourdev_555015.doc(文件大小:159K) (原文件名:HS162-4液晶显示使用说明.doc)
我最终想实现液晶能有2部分显示,第一行显示“FEIYONG:变化的数据”;第二行显示数字时钟;(“FEIYONG:”这段字符是静态显示的,其他的都是动态变化的)。大家能帮下忙实现下嘛?帮忙改改代码!或者帮忙写段代码(本人初学,请稍加注释)!加我QQ:403246557.或发到我的QQ邮箱里都行。不胜感谢! |
