library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity LCD is
Port ( CLK : in std_logic; --状态机时钟信号,同时也是液晶时钟信号,其周期应该满足液晶数据的建立时间
Reset:in std_logic;
LCD_RS : out std_logic; --寄存器选择信号
LCD_RW : out std_logic; --液晶读写信号
LCD_EN : out std_logic; --液晶时钟信号
LED: out std_logic;
LCD_Data : out std_logic_vector(7 downto 0)); --液晶数据信号
end LCD;
architecture Behavioral of LCD is
type state is (set_dlnf,set_cursor,set_dcb,set_cgram,write_cgram,set_ddram,write_LCD_Data);
signal Current_State:state;
type ram1 is array(0 to 30) of std_logic_vector(7 downto 0);
type ram2 is array(0 to 30) of std_logic_vector(7 downto 0);
type ram3 is array(0 to 30) of std_logic_vector(7 downto 0);
constant cgram1:ram1:=(x"46",x"50",x"47",x"41",x"2f",x"43",x"50",x"4c",x"44",x"20",x"73",x"74",x"75",x"64",x"79",x"20",x"20",x"42",x"79",x"20",x"4d",x"49",x"41",x"4f",x"53",x"48",x"41",x"4e",x"4c",x"49",x"4e");
--显示我的名字的汉语拼音,以及FPGA/CPLD study by MIAOSHANLIN
constant cgram3:ram3:=(x"68",x"74",x"74",x"70",x"3a",x"2f",x"2f",x"6d",x"69",x"61",x"6f",x"73",x"68",x"61",x"6e",x"6c",x"69",x"6e",x"2e",x"61",x"6e",x"79",x"32",x"30",x"30",x"30",x"2e",x"63",x"6f",x"6d",x"2f");
--显示我的主页:http://miaoshanlin.any2000.com/
constant cgram2:ram2:=(x"51",x"51",x"3a",x"33",x"33",x"30",x"34",x"39",x"35",x"39",x"30",x"38",x"20",x"20",x"20",x"20",x"54",x"65",x"6c",x"3a",x"31",x"33",x"39",x"33",x"36",x"35",x"30",x"39",x"33",x"38",x"31");
--显示我的QQ号码和手机号码:QQ:330495908 Tel:13936509381
signal CLK1 : std_logic;
signal Clk_Out : std_logic;
signal LCD_Clk : std_logic;
signal m :std_logic_vector(1 downto 0);
begin
LCD_EN <= Clk_Out ;
LED <= Clk_Out;
LCD_RW <= '0' ;
process(CLK)
variable n1:integer range 0 to 19999;
begin
if rising_edge(CLK) then
if n1<19999 then
n1:=n1+1;
n1:=0;
Clk_Out<=not Clk_Out;
end if;
end if;
end process;
LCD_Clk <= Clk_Out;
process(Clk_Out)
variable n2:integer range 0 to 499;
begin
if rising_edge(Clk_Out) then
if n2<499 then
n2:=n2+1;
n2:=0;
Clk1<=not Clk1;
end if;
end if;
end process;
process(Clk1)
variable n3:integer range 0 to 14;
begin
if rising_edge(Clk1) then
n3:=n3+1;
if n3<=4 then
m<="00";
elsif n3<=9 and n3>4 then
m<="01";
m<="10";
end if;
end if;
end process;
process(LCD_Clk,Reset,Current_State)
variable cnt1: std_logic_vector(4 downto 0);
begin
if Reset='0'then
Current_State<=set_dlnf;
cnt1:="11110";
LCD_RS<='0';
elsif rising_edge(LCD_Clk)then
Current_State <= Current_State ;
LCD_RS <= '0';
case Current_State is
when set_dlnf=>
cnt1:="00000";
LCD_Data<="00000001";
Current_State<=set_cursor;
when set_cursor=>
LCD_Data<="00111000";
Current_State<=set_dcb;
when set_dcb=>
LCD_Data<="00001111";
Current_State<=set_cgram;
when set_cgram=>
LCD_Data<="00000110";
Current_State<=write_cgram;
when write_cgram=>
LCD_RS<='1';
if m="00" then
LCD_Data<=cgram1(conv_integer(cnt1));
elsif m="01"then
LCD_Data<=cgram2(conv_integer(cnt1));
LCD_Data<=cgram3(conv_integer(cnt1));
end if;
Current_State<=set_ddram;
when set_ddram=>
if cnt1<"11110" then
cnt1:=cnt1+1;
cnt1:="00000";
end if;
if cnt1<="01111" then
LCD_Data<="10000000"+cnt1;--80H
LCD_Data<="11000000"+cnt1-"10000";--80H
end if;
Current_State<=write_LCD_Data;
when write_LCD_Data=>
LCD_Data<="00000000";
when others => null;
end case;
end if;
end process;
end Behavioral;
现在程序自动显示三屏内容,我想对每一屏都加一个按键控制,比如按1键直接跳到1屏内容,按2键显示2屏内容,不按键的话程序还是轮流显示三屏内容,显示程序已经验证过了,但是控制不知道加到哪里,请高手帮忙看看啊 |
