回复: 19
ICD3使用注意事项
发表于 2010-5-12 16:27:09 | 显示全部楼层 |阅读模式
ICD3使用注意事项
点击此处下载 ourdev_553456.pdf(文件大小:327K) (原文件名:ICD 3 使用注意事项.pdf)
 楼主| 发表于 2010-5-12 17:33:04 | 显示全部楼层
如果大家使用过程有心得的,可以写出来,让我们少在工具上浪费时间...
发表于 2010-5-13 08:49:35 | 显示全部楼层
http://www.pic591.com/articleshow.asp?id=171&class=news。贴一个。
发表于 2014-7-11 14:45:49 | 显示全部楼层
我的ICD3已经怀过2次了,真心不敢用了
发表于 2015-3-26 13:18:55 | 显示全部楼层
我的ICD3现在坏了 不知道要怎么办了 楼主有解决办法吗?现在ICD3可以连接到电脑上 但是找不到目标芯片
发表于 2015-3-26 14:01:43 | 显示全部楼层
弱弱的问一句这是干啥的
发表于 2015-3-26 17:28:07 | 显示全部楼层
飞思卡驴 发表于 2015-3-26 14:01
弱弱的问一句这是干啥的
PIC单片机实体仿真器
发表于 2015-3-28 09:21:06 | 显示全部楼层
zhou_kefei 发表于 2015-3-26 17:28
PIC单片机实体仿真器
好吧,我农民了
发表于 2015-3-30 13:26:36 | 显示全部楼层
ICD3用的累,联不上时就闹心。
发表于 2015-4-1 00:52:16 | 显示全部楼层
真的要好好看 ICD3 有甚麼使用上要注意的問題?!
发表于 2016-3-1 05:29:33 | 显示全部楼层
>我的ICD3现在坏了
Microchip provides free replacement, go to ticket center, generate a case number.
Then you can get a free replacement.
发表于 2016-3-1 07:12:07 来自手机 | 显示全部楼层
funnynypd 发表于 2016-3-1 05:29
>我的ICD3现在坏了
Microchip provides free replacement, go to ticket center, generate a case number. ...
可以换新的????
发表于 2016-3-1 08:27:27 | 显示全部楼层
Sure.
You got free replacement, may not be a new one, but it must be a working one.
发表于 2017-9-25 09:05:11 | 显示全部楼层
谢谢分享,收藏了
发表于 2017-9-28 10:11:47 | 显示全部楼层
看来还是PICKIT3耐用
发表于 2017-10-25 23:50:28 | 显示全部楼层
http://www.microchip.com/Develop ... spx?PartNO=DV164045
The MPLAB® ICD 4 In-Circuit Debugger/Programmer is Microchip’s fastest, cost-effective debugging and programming tool for PIC® Microcontrollers (MCUs) and dsPIC® Digital Signal Controllers (DSCs). This speed is provided by a 300 MHz, 32-bit MCU with 2MB of RAM and a high-speed FPGA to yield faster communications, downloads and debugging. It debugs and programs with the powerful, yet easy-to-use graphical user interface of MPLAB X Integrated Development Environment (IDE). The MPLAB ICD 4 is connected to your PC using a high-speed USB 2.0 interface and is connected to the target with a debugging connector which is also compatible with the MPLAB ICD 3 or MPLAB REAL ICE™ In-Circuit Emulator systems. The MPLAB ICD 4 also works with JTAG interfaces.
出20入12汤圆
发表于 2017-10-26 07:39:45 | 显示全部楼层
mobile02 发表于 2017-10-25 23:50
http://www.microchip.com/Developmenttools/ProductDetails.aspx?PartNO=DV164045
The MPLAB® ICD 4 In-C ...
看上去虽好,仍用mplab8的底眼了,因为不支持.
发表于 2017-10-26 12:17:02 | 显示全部楼层
一直在PICKIT3,ICD3感觉确实不皮实又炒鸡贵。
发表于 2017-10-26 12:42:38 | 显示全部楼层
这几年公司攒了五六个坏的ICD3,前段时间一起打包寄给厂家维修了。
最近换PICKIT3用,挺好用的,但好像在烧录的时候不能保持内部EEPROM。
发表于 2017-10-26 13:32:06 | 显示全部楼层
最近换PICKIT3用,挺好用的,但好像在 ...
我用的MPLAB IPE来烧录,在memory选项卡里边,可以选择烧录的方式。把烧录EERPOM选项的勾选去掉,就可以了。
PICKIT3烧录功能还算很齐全的,目前唯一不足就是:烧录滚码的时候,只能从LSB>MSB,而不能LSB与MSB自由设置。
GMT+8, 2024-7-23 01:18
